I HAVE A E63 NOKIA WHEN I PUT ON THE LOCK CODE 12345 IT SAYS CODE ERROR EVEN WHEN I HAVE FOMATTED IT,IT STILL DOES THE SAME THING CODE ERROR,WHAT CAN I DO PLEASE HELP ME.
You can format your Nokia E63 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YES
IMPORTANT!
Formatting the device will permanently erase all user data and settings as well as add-on applications and operator specific settings.
formatting it would solve your problem!! press * key with number 3key and call button while switching on the phone it would do the trick. make sure you have charged well before doing it.
If this solution helpful/useful for you please rate mysolution. THANKS FOR USING FIXYA.
Those codes you were imputing are not the correct lock code. 12345 and 00000 are security locks, mostly for when you set a password on your phone so no one else uses it.
If you're looking to unlock you phone to use on other carriers, then you would need to contact your carrier for a "Carrier Unlock code" or find a reputable GSM Unlock website to unlock your phone. Usually they will ask for your "IMEI" serial number which is the sticker behind your phone to unlock your phone.
This is security code reset details*#7328748263373738# . After doing this your Default security code is 12345. If you want to unlock code for network lock for your nokia e63, you can get it from TheUnlockArena.com .They need your current network details and imei of your nokia e63..After getting these details, they provide unlock code for you..
Please note that,12345 is the factory master code for nokia.
If fails, get the code at www.nfader.su
If still fail , get it unlocked at www.unlock-zone.com
Hi, the standard master reset code for nokia is 12345. But if fails, you can get the code here for FREE*) : www.nfader.su Jay *) need to key in your IMEI #
