Question about Tefal Irons
How to clean lime scale out of iron tank - Tefal Irons
    Genius:
  • 1,044 Answers
All you need for this is a cotton cloth and white vinegar, a small amount. And you have to rub with cotton cloth for the limescale. Vinegar will act and the limescale will disappear from here.
If it doesn't help you can mix the vinegar with baking soda and it will be a good start point.
When you have finished to polish and to clean the outside, you can clean your iron from inside. For this you have to put a small amount of vinegar and you have to mix it with water.
You have to switch it on to wait. And press the steam. All the limescale will come out of there.
You see? And your iron is shiny and clean, from inside and from outside as well. .
Posted on May 19, 2011
Clean distilled
Use CLR or any other lime scale remover you can find. Pour out any water in the bottom chamber and put some CLR into it. leave it for 10 minutes to an hour. Run it to have some CLR so though any passages, then pour out any remaining CLR and replace with water again to wash out the CLR. When you are satisfied that the CLR is all rinsed and replaced with clean water, then it is safe to iron again. CLR can alway be put on a cloth and wipe the iron surface or any deposits.
Oct 15, 2013 | Tefal GV7070 Iron
Steam comes out of the place where you put the water in
check the holes in the hot plate are not blocked with lime scale...sounds like you have a back pressure problem
Dec 29, 2012 | Rowenta DG5030 Iron
Steam generator iron is blocked with lime scale any suggestions ?
Fill it with a 50/50 solution of water and white vinegar. Heat it up and run the steam through. After it cools a little bit, clean any clogged ports with a paper clip and repeat the process. Once it is cleared out, run 2 or 3 tanks of plain water through it to eliminate the vinegar smell. The vinegar is harmless to the iron but it melts the deposits. This method can also be used on coffee makers. It's totally non-toxic.
Dec 27, 2012 | Irons
My Rowenta Expert steam generation iron (seperate tank for the water type) is starting to spit ever so often brown water out. I only use filtered water. How can I clean the actual Iron, the water tank is...
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Mar 16, 2011 | Rowenta DG-980 Iron
Water shoots out when trying to steam.
You are getting a lime (scale) build-up in the iron. Best to try a clean, either with a self-clean function, or buying a lime remover solution for kettles and irons.
Dec 09, 2010 | Black & Decker D2030 Iron
We own a SmartLiving Steam Mop, and have really enjoyed it. It suddenly quit steaming. We tried putting vinegar through it in case it was hard water deposits, but no luck. Any siggestions?
yep i have one,,,,,dont use vinegar,,,thats good on chips? no good in steam mops!
go get yourself some kettel cleaner ,,,the stuff for cleaning the lime scale off the inside of your kettel,,,,mix it up in a jug with warm water,,,,and tip that in your steamer,,,dont breath the fumes?
this will clean out any lime scale for you,,,next time fill it with rain water,,,,there is no lime scale in rain water?
Nov 27, 2010 | Hamilton Beach Steam Excel 14770 Iron
My iron is spitting after working faultlessly for 3 years what can i do?
get some kettel cleaner mix it up in a jug first with warm water then fill the iron up with this and run it through catch it in the jug so if needs be you can run it through again till it cleans out all the lime scale out of the iron,,,its all down to using hard water in your iron?
Jun 20, 2010 | Rowenta Irons
The sole plate of my steam generated iron is clg
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Jan 18, 2010 | Maytag MLI7500A Iron
There is a grey substance coming out from the steam holes
this is scaling. Just descale it properly if there is a provision in ur press. or just wipe it and leave it
Aug 05, 2009 | Irons
How to use the calc-clean button
Calc-Clean function
The Calc-Clean function removes scale and impurities.
To do so, set the steam control to position '0', set the temperature dial to 'MAX', and fill water tank up to the 'MAX' level. Then heat up the iron until the pilot light on the handgrip goes out.
Remove the mains plug from the wall socket and hold the iron horizontally over the sink. Then press and hold down the 'CALC CLEAN' button.
Move the iron forwards and backwards while boiling water/steam squirt from the holes in the soleplate to wash away impurities/scales.
When the water tank is empty, heat up the iron to dry it.
Finally move the iron to and fro on a piece of cloth to dry the soleplate. Repeat the process if necessary
May 05, 2009 | Philips HI-296 Iron
Irons Logo
374 people viewed this question
Top Tefal Irons Experts
Henry  Thomas
Henry Thomas
Are you a Tefal Iron Expert? Answer questions, earn points and help others
