My samsung wont accept the disc dvd-r that i have recorded, it is a samsung130dvd recorder. what do i do.
  • Televison & ... Master
  • 17,130 Answers
Please check the format that was recorded on the disc. play the disc on a PC and see the properties, Now check if this was acceptable on the player.
If your Samsung plays all other discs then give it the benefit of doubt and redo the recording on the accepable format.
If none plays there are faults in the optical head or the main processor board.
Posted on May 19, 2011
Samsung dvd_vr330 wont play pre recorded discs
The VR330 has several problems similar to this, and some can be "fixed" by unplugging the unit and let it set for anywhere form 5 mins to several days.
I think the control software gets messed up.
I had 3 - one wouldn't play a "video" movie, another would record RAM, and another wouldn't do DVD-R/RW.
Surprisingly one day I accidentally put a DVD-RAM with recordings on it and the unit accepted the RAM. The disk had been protected on another device.
On that particular unit I had neglected to set the time which was at factory 2006, so I left it there.
Mar 03, 2013 | Samsung DVD-VR330 VCR and DVD Recorder
Trying to record on a DVD-R , after several minutes trying to load i get a msg saying it can neither read nor play this disc , check disc,,please help
I've had this problem with trying to record on CD-Rs also. DVD and CD recorders can be very fussy. You just have to get a piece of dust or a fingerprint on the CD or DVD that's being recorded onto and it gets kicked back as a check disc or blank disc..
Another problem is some recorders will only accept certain brands. I've had problems recording onto a SONY CD-R with a SONY recorder! So, in summing up, try a different brand or make sure the disc is clean. Sometimes just taking the disc out and putting it back in in a different position will make the recorder think it's an OK disc. Hope this helps.
Jul 22, 2012 | Samsung DVDR120 DVD Recorder
DVD recorder won't format discs or record
check what kind of blank dvd your dvd recorder accept.
Jun 07, 2011 | Samsung Televison & Video
I am not able to use a DVD-RW ?? The disc is not accepted ? What type of DVD-RW I need ?
This unit allows you to record and playback high quality
digital images on DVD-RAM/DVD}RW/DVD}R discs.
You can record and edit digital images on DVD-RAM/
DVD}RW/DVD}R discs.
Mar 05, 2011 | Samsung DVD-R155
DVD will not recognise discs
I think that moisture has formed on the boards.
The best thing to do is to take the recorder
and put in a warm room,connect it and leave for 2-3 hours.
Then try with a disc again.
I hope i`ve helped!
Nov 29, 2009 | Samsung DVD-HR730 DVD Recorder/HDD...
When I put a DVD-R into the DVD-R 155 recorder to copy a TV program after a few minutes of the blue disc at spinning at the top right of my TV screen the disc is ejected with the message 'disc cannot be...
This is a Samsung DVD recorder - I've had the exact same problem - By the way, don't you mean "this disc cannot be recorded" ? These DVD recorders are known to reject certain type of discs.
* Have you updated your Samsung with the latest firmware ?
http://www.samsung.com/ca/support/download/supportDown.do?group=&type=dvdplayers&subtype=recordable&model_nm=DVD-R155&disp_nm=DVD-R155&language=&cate_type=all&dType=D&mType=FM&vType=&prd_ia_cd=03010300&model_cd=&menu=download
Follow the instructions carefuly and please understand the risks involved in flashing your drive - Do not interrupt the process, it can take long.
* here are the brands of DVD-R I have used successfuly with this recorder int he past:
Taiyo Yuiden DVD-R 4x / 8x (the optical drives used in those recorders are outdated, their writing strategies are never up to date and may not recognize some type of discs)
Maxell DVD-R 4x / 8x
Verbatim DVD-R 4x / 8x
Try another blank disc - maybe it will accept it - if it keeps rejecting all your blank DVD-R no matter what brand, you have a bad drive inside your recorder - the samsung recorders are **** - I have ever since gotten rid of that piece of **** and now use a Sony HDR-780 HDD/DVD recorder, uses pioneer components and is great !
Avoid those lens cleaners - they can do more harm than good!
I hope this helps.
Try different brands of DVD-R, avoid the cheap generic **** - drives like best Taiyo Yuden & Verbatim media id codes - they should recognize Maxells, verbatims, sony, taiyo yuden, ritek. if it keeps spitting out all discs you use, you have a defective unit. The latest firmware on that drive should also help !
Good luck :)
Aug 22, 2009 | Samsung DVD-R155
How to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
did you try a lens cleaner disc?
Jul 30, 2008 | Televison & Video
My samsung dvd-hr735 now region free wont let me record onto dvd
Could be your using the wrong disc.
type is DVD-R where - is a minus as distinct from DVD+R
Feb 09, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
