Question about Frigidaire FGR231A Gas Dryer
Frigidaire Gas Dryer - Heats for 1-2 minutes then gas shuts off
I have a Frigidaire Gas Dryer with the lint trap located in by the fron load door. When I turn it on it seems to work fine however it does not seem to be drying the clothes. I pulled the entire fron panel off cleaned it and jumed the door switch wires so I can see it operate. When it is started the glow plug turns on and the gas valve opens and burns for about 2 minutes before the flame goes out and the dryer continues to tumble. Any advice on which component it is that is causing the gas valve to shut prematurely?
Thanks in advance for any help you could provide.
  • 2 more comments
  • Anonymous Aug 25, 2008
    same Problem.
  • Anonymous Sep 16, 2008
    Dryer seems to heat for the first minute, then stone cold :(
  • Anonymous Sep 20, 2008
    lints trap behind the dryer drum inside the dryer where it smell burnt lint on the clothes how can i remove those lint
  • Anonymous Dec 09, 2008
    drier flame lights but then goes out after awhile
    Problem Solver:
  • 14 Answers
Most of the time, the culprit is a bad gas valve coil(s). Replace those, and your dryer should return to normal operation.
Posted on Jan 25, 2009
SOURCE:
Dryer heats short time when first started then no heat rest of cycle
Well if it's a gas dryer and if your dryer tumbles, but there is no heat or less heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information and please don't forget to give some information about the brand and model number.....
Good Luck!!
Thanks for using FixYa!!
Jan 25, 2011 | Dryers
Dryer runs but no heat this is a gas dryer
Well if your dryer tumbles, but there is no heat then you may please check out the following -
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Jan 25, 2011 | Whirlpool LGR3624JQ Gas Dryer
Dryer heats up for a couple of minutes and then stop heating and blow cold air
Try cleaning out your Lint Trap, this will be either on the door inside, or inside at the back of the dryer, this should just pull off, remove the built up lint and replace.
Nov 02, 2010 | Hotpoint NWSR483GBWW Gas Dryer
My dryer runs but no heat.maytag neptune gas dryer.
Good Luck!!
Sep 22, 2010 | Maytag Dryers
Roper gas dryer will not heat. Igniter?
Good Luck!!
Sep 10, 2010 | Roper RGX4634KQ Gas Dryer
MDG850 Gas Dryer: will not get hot
Good Luck!!
Sep 09, 2010 | Maytag Atlantis MDG8400AW Gas Dryer
Gas dryer not heating all the time
Good Luck!!
Jan 27, 2010 | Whirlpool LGR5636PQ Gas Dryer
Gas dryer quit heating
Good Luck!!
Nov 01, 2009 | Whirlpool GGQ8831L Gas Dryer
My amana gas dryer is not heating
Good Luck!!
Sep 04, 2009 | Amana NDG5800 Gas Dryer
Gas dryer heats fine but shuts down before the drying cycle is over taking longer to dry clothes. Lint trap and exhaust tube cleaned out.
You are going to most likely need a vent cleaning. The dryer is getting too hot and shutting off because it is not exhausting good.
Apr 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Frigidaire FGR231A Gas Dryer Logo
282 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
