Question about Jabra BT250 Consumer Headset
How can i sync this head set with my phone - Jabra BT250 Consumer Headset
    Genius:
  • 1,622 Answers
Hi, you can use the manual to know how to sync or pair with your cell phone..
http://www.bgolden.com/docs/documentation/Jabra-BT250v_UM_NA_EN_167.pdf
Hope it helped..
Posted on May 19, 2011
Can I connect my Bluetooth earpiece with my Safelink phone?
check the driver to up to date
re install software, but you must remove the old first so you will not continue to have the same issues
can you try sync the devices
you have to look at all anti virus programs and firewall settings
make sure you have fresh batteries in the head phone if the take them.
check the setting in the phone, go to settings than to account & sync
check application setting as well
make sure the program is not already running, look at manager applications also, than also look in the location and security setting under wireless networking
you also need to check the wireless and network settings,make sure the blue tooth is turned on
check the voice input and output section also
need to look on phone see if you 4 little dot on the lower side on either side of the lowest screen move your finger across the screen the screen should move that direction keep moving it until you find display of devices that are running to make sure the blue tooth is high lighted show that the device is on
Apr 16, 2015 | Radio Communications
My htc desire will no longer sync with my PC it asks to insert disk into drive E
Your solution
Setting up HTC Sync to recognize your phone
After installing, set up HTC Sync to recognize your phone.
1. From the Home screen, press MENU, and then tap Settings > Accounts & sync.
2. On the Connect to PC screen on your phone, tap HTC Sync and then tap Done. Your phone attempts to find HTC Sync on your computer. Wait for a few seconds for the process to finish.
3. If your phone displays a message indicating that it's unable to find HTC Sync, try disconnecting and reconnecting the USB cable, and then repeat step 2.
4. When the Phone Connection Wizard is displayed on your computer, click Next.
Enter the name you want for your phone, and then click Finish.
Check the HTC Sync icon at the bottom-right side of your computer screen. If it appears green in color, that means your phone has successfully connected with your computer and HTC Sync recognizes your phone
If still no go try this .
Unplug the phone from the PC, restart both the phone and the PC. When the PC is done booting, plug your phone in and see if the autorun box pops up.
still if nogo try this .
you have to select disk drive (when plugged in via notification area) to be able to view the drive in windows and htc sync to use htc sync.
May 27, 2011 | HTC Desire Cell Phone
How to connect the blue tooth head set to this phone
go to settings, wireless and networks, bluetooth.
make sure bluetooth is on.
turn on your headset, to sync the new headset, normally you have to turn on the device and continue to hold the power button until the headset goes into bluetooth sync mode.
normally around 10-15 seconds of holding the power button.
THen tell HTC to scan for devices. Your headset should appear. if it asks you to type in a code, it is generally 0000 or 1111
Feb 12, 2011 | HTC F3188 Smartphone
I have many issues with my android eris
I had the same problem with my Motorola Droid. The problem is that you have added your own contacts, or worse, copied them over from another phone. You then have undoubtedly synced up Google or Facebook contacts. If the spelling of both names isn't relatively exact, it won't combine them. You can manually force the phone to do this. Go into your contacts, long press and goto edit on a contact. From there, press the menu key on your device. In that menu you will see a Join option. Press this, and then select the duplicate entry to combine. Its a bit of a PITA, but that's what I had to do.
As far as the second issue, the only thing I can think of is that the sync options are set incorrectly in the phone. From your home screen, press the menu key, go to Settings, then Accounts & Sync. From there, make sure "auto-sync" is enabled. Then, make sure your Google account is listed. If so, select the Google account, and make sure that the "sync contacts" option is checked. If all these options were already enabled, then I apologize, and this problem is obviously over my head.
Also, please keep in mind that my experience is with the Motorola Droid, running Android 2.0. The menu system on your Eris will probably vary slightly, so some improvisation may be in order.
Feb 22, 2010 | HTC Droid Eris by
Can i sync my 30 gb zune with my new head set Motoral a9dp hd
No you cant sync files from motorola head set to your zune directly.First you connect your both things to your PC and then tranfer files to each other. Thankyou.. :) Please give high ratings if you like.
Jan 02, 2010 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Unable to sync a bluetooth headset
It appears your phone might not be syncing up with the headset since there might not be any signal at all. Do you have some one else's head set you might be able to borrow in order to test this possible problem? Maybe even stop by a mall phone booth to see if the blue tooth head set they have there for demo will sync up with your phone [besides you can always walk away after you test that and not buy anything just dont tell them before hand..].
See if this helps figure out the problem. It's one of the ways to test the problem and find a solution.
Let me know how it goes!
p.s. sorry it has taken so long for some one to get back to you. Let us know if you found a solution to this problem already in the mean time!
Sep 02, 2008 | RIM BlackBerry 7290
I can not get it to sync
close the mouth piece.
Open the mouth piece 1/2 way, then turn it on ...
Lite on bluetooth should blink rapidly.
turn on phone to sync mode.
http://www.motorola.com/mot/doc/5/5573_MotDoc.pdf
Jun 30, 2008 | Motorola Mobility H700 Wireless Headset
Jabra BT250 Consumer Headset Logo
52 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
