Question about Gateway Computers & Internet
I just cannot get the harddrive out of this machine. I removed al the scews I can see, but even after removing the front of the case, I still can not get to the scews that prevent me from removing the hdd. Is there a way to pull out the metal caddy that the harddrive is scewed to? I yanked on it but so far to no avail. Am a little frustrated. :)
  • Gateway Master
  • 32,281 Answers
I suggest you go to the Gateway WEB site and download a user manual for your model Gateway computer.
Click on this link select your model computer to download : -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Posted on May 19, 2011
Remove gasket from front loader
disconnect from power
take top of machine look down at gasket thre is a eire clamp locate the screw in the wire and un scew till wire loose enough to come of then remove gasket if srew underneath put top back on and tip machine on one side carefully and look for screw
the wire is just a very large hose clamp
Sep 27, 2014 | Frigidaire ATF6000ES Front Load Washer
How do get at the drive belt
Not familira with a 62802 but most from the front of the machine. Remove scews under edge of top and around door, remove front, you sould see the belt and motor then.
Jul 20, 2010 | Kenmore 62802 Electric Dryer
How do I remove Hard Drivew from 6640C
Here is your link to assist you.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=59928&
Apr 26, 2010 | HP Pavilion 6640C PC Desktop
How do I change the Optic Block Engine on KDF-55WF655
you have to have a long phill scew driver you have 4 sw in front of tv 3 in the back you need a mag tip for this the scew are in dep un hook all wire from the optic block when you remove the eng becaufal not to toch the glass on the optic block you need to remove the front panel you have two scew 4 all to gather to remove the front planel you see four scew in center of the screen thay are black. i hope this help you out your need to be clean to.
Dec 07, 2009 | Sony KDF-55WE655 55" Rear Projection...
Need to replace solenoid valve on asko w6oo .Water no longer entering machine. How do I replace the valve or get repair manuel ?
Quite easy, Valve is removed by loosening two scews/or twisting valve off, remove the 2 hoses too...Remove wiring then refit..Turn off water 1st and electrics....Good luck, parts cost about £10
Nov 02, 2009 | Whirlpool AWM5104/1 Front Load Washer
How do you change the Hard Drive for a Sony Vaio vgn-tt180? And where is the oem hard drive located? Thanks, Mo
Not a recommended thing Mo.
Granted I don't know your computer prowess, but it's an involved task, even for a tech.
First you make a backup of what's on your harddrive now. Burn to disk/s, all of your personal stuff, (If you haven't already done so)
(Everything in your My Documents folder. My Pictures, My Music, My Videos, and documents you have created. You won't be able to transfer downloaded programs, or programs you have installed. Read on for how to do that)
You use an external enclosure, (2.5"), and put the new laptop harddrive in it. Then using a 'mirror' imaging program, like Norton Ghost, Acronis true Image, or DriveImage XML, you make a copy of your operating system, and all programs that are on the harddrive in the Vaio VGN-TT180.
External enclosures are cheap. You want one that is 2.5", and is Sata.
Examples,
Now for the tough part, and the reason I don't recommend it.
With most laptops one removes a couple of screws, and slides the harddrive out of the side of the laptop case. Or remove a panel, and access it. Or, some have it where removal of the keypad grants you access.
Not the Sony Vaio, and especially not the Sony Vaio TT Series.
You have to turn the laptop over on it's top. Remove a series of 7 screws, or so. Six around the outside edge of the case, one in the middle/Front, next to the memory compartment cover. Then the laptop is turned back over, and a small flat tip jewelers screwdriver, is inserted into the slots above the keypad, and the keypad is released, and tilted back. The flat ribbon keypad cable, is then unclipped from the laptop.
There's a small White ribbon cable located towards the speaker grille, that has to be disconnected.
This is what connects the front panel buttons to the motherboard.
Now there's a screw right above the trackpad that has to be removed. (And CAREFULLY! It can easily be dropped inside! To get it back out, you MAY be lucky enough to pick the laptop up, turn it over, and gently shake it out. If you're not lucky, you get to disassemble the whole laptop!)
Next, a flat tip jewelers screwdriver is inserted in the parting line, where the upper half of the case, meets the lower half of the case. Start at the back towards the LCD screen, and ease the top panel up, working your way towards the front. Start on one side. As the top panel comes up a little on this side, go to the other side, and work it up. Bring the top panel up, as even as you can. It's thin, and can twist easily, binding it. The top panel is held on by a series of clips.
Once, you get both sides separated to the point you are at the front, the top panel lifts right off.
Now you can see the harddrive.
To the left side of it are two screws in the corners. These are removed. (DON'T drop them)
To the right, there is a screw in the Front corner. This is removed. The harddrive has a fabric strip attached to it, on the back of the case. You gently pull back, and as the harddrive comes out, you ease the back of it up, and pull straight out. Use extreme caution in this, as the little pins of the harddrive interface, could be bent!
Now you remove tow screws oneach side of the harddrive. This removes the metal frame that goes around it. The new harddrive is installed in this metal frame.
Now just reverse your steps.
Not a job for the timid! lol!
Apr 17, 2009 | Sony VAIO TT Series VGN-TT180N/B NoteBook...
I need to replace a door seal, Hotpoint Ultima WF860
Push the top cover to the rear and lift at the same time, then ease the control panel to the right, you will not get control panel off with the top cover in place.
This will then give you access to the front panel scews, located at the top and bottom of the panel. remove the door seal ,and door lock, then lift the front panel away.
Nov 25, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hard Disk upgrade
Figured this out...
1)  Flip laptop over, keep front of laptop closest to you and hinges away from you 2)  Remove cover with cylinder/harddrive icon (2 screws) 3)  Remove small single silver screw near the front (close to you) of the laptop in the center of the metal harddrive caddy (the caddy may hold one or two hard drives) 4)  Pull the plastic tab on the left toward the outside of the laptop... the whole caddy with harddrive(s) inside will shift to the left, disconnecting it from the motherboard and lining up the caddy for removal. 5)  Lift the entire bracket straight up
To remove the primary harddrive (the only one present in my model) you must remove the blue L-shaped circuit board from the caddy. 1)  Flip the caddy over 2)  Remove the three screws with slightly larger head diameters around the perimiter of the caddy 3)  Push/slide/jiggle the circuit board so the sata connectors release from the hard drive(s). 4)  Unscrew the hard drive from the caddy
Aug 25, 2008 | Acer Aspire 7720 Notebook
Acer Aspire 3680. How do I get the back off ?
For AS 3680,
Removed screen.
1. Open the door on the back to remove the wireless antena cables.
2. Open the power cover (remove 2 scews on the power cover).
3. removed keyboard.
4, remove 4 scews (silver scews) that make screen attched the the laptop body.
5. that's all you can remove the lcd now.
For opening the body,
1. Removed all screw on the back, include 1 screw (small scew) under hard drive.
2. removed 3 screws under keyboard
3. removed 1 scew on top side (close to power port), this scews held uppercase and lower case.
4. removed lcd lid cable from board (close to power port)
5. now you can separate upperbody from lowerbody.
6. removed 2 scews from motherboard.
7. removed modem cable, speaker cable, mic cable from the back.
8. that's all, you can removed motherboard+power board.
i hope this help you, good luck
Mar 02, 2008 | Acer Aspire 3690-2196 Notebook
Removing cover from old Gateway PC to add memory
If your Gateway PC is laying horizontally flat. There will be a black button in front of the PC on the left side of the CD-Rom. Push really hard. And WallAA!
Dec 25, 2007 | Computers & Internet
Computers & Internet Logo
289 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
