After installation of a network adapter, that was not compatible with home computer, installation froze. I rebooted and got errors like these: AirGcfg.exe Entry point not found, aps search interface could not be located in the dynamic link library, wlanapi.dll wzcsldr2.exe entry point not found wlanapi.dll these are two of the errors, I cannot manually find this in the registry
  • 917 Answers
Your best bet is to try a system restore to a point before you installed the bad driver.
Click on START, PROGRAMS, ACCESSORES, SYSTEM TOOLS, System Restore. Then select Restore My Computer to an earlier time. Hopefully you will have a restore point dated just before you installed the driver. Restore to that point and see if it fixes the problem.
Posted on May 19, 2011
Resetting the adapter
Use the computer you are on to download the updated driver for the network adapter from the Toshiba Website. After you have the updated driver install it on the computer your having a problem on. Reboot the computer. If the problem is still there and you have a cable connected to the network connection and to the router, uninstall the network adapter from the device manager and reboot the computer. That should detect and install the adapter and resolve the problem. If it doesn't there is a problem with the network adapter and you will need to use the wireless of get a PCMCIA card to use for networking. Toshiba does use a replaceable Network card in some laptops, if nothing else above works and you don't want to get another card to plug in you may want to look into purchasing a new card from Toshiba to replace the old one.
Jul 22, 2010 | Toshiba Satellite A100-S8111TD Notebook
Error 10 Am trying to install on refurb desktop Have installed and uninstalled and installed again
Error code 10 in device manager means that the device cannot start. This is due to either the drivers are not updated, or the drivers are not recognized by the Device Manager.
Try the following:
- Uninstall and then reinstall the drivers.
- Make sure you have the updated drivers and the drivers are compatible with the operating system of the computer.
- Try to install the adapter to another computer, just to isolate the issue if this is a problem with the drivers or if it is a compatibility issue with the PC.
Please note: WUSB54GSC v1 drivers can also work with Win 7 using the Win Vista drivers.
Nov 12, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Install MS office home and student 2007
Reboot
Shut down any active protection software such any antivirus, antispyware, antitrojan, or registry monitoring software.
Try to Unistall by using the install disk. It should detect a previous installation and ask if you want to Install, Repair, or Uninstall.
If that fails, download and run CCleaner - Use the Cleaner and Regisrty modules default settings
http://www.ccleaner.com/
Reboot, and shut down active protection software.
Download and run Windows Installer CleanUp Utility.
http://support.microsoft.com/KB/290301
Remove the applicable entries.
Reinstall
Hope this helps - good luck!
Nov 01, 2008 | 10 10 Computer Network adapter Cable...
Can't install on new computer
Are you running 64 bit Vista?
If so you will need 64 Bit drivers for the device
Download this file
http://www.dynexproducts.com/skins/skin_1/Topics/Drivers/DX-EBUSB_2.03.05_Setup.exe
DO NOT CONNECT THE DEVICE UNTIL IT TELLS YOU
When the windows warning pops up, Install the driver anyway. then connect the device, that should fix the problem It worked on my 64bit Vista Ultimate
Aug 24, 2008 | Dynex Enhanced Wireless-G USB 2.0 Network...
Installed WMP54GS and am getting the following error from Linksys Wireless Network Monitor Access violation at address 0040744D in module WMP54GSv1_1.exe'. Read of address 00000368
Possibly you have installed the WLAN monitor also that is why it is creating the error...try these settings... Reboot your computer in SafeModeUninstall the software for the Adapter from start >> All programs/Remove the Drivers from Device Manager...Turn your computer Off and connect the adapter in a different PCI Slot...Reboot your computer in Normal Mode...
>> Insert the Setup CD in the cd drive>> Click on Exit when the
Linksys welcome screen appears>>Click on start. Unplug & replug adapter ...>> There should be a "" Found New Hardware Wizard ""
that pops up on your screen>> Click on “Install software
automatically “, and then click on next. Once the installation is
complete>> Right click on the wireless network connection icon in the
system tray besides the clock >>Click on view wireless networks and
then connect to your network name...
May 01, 2008 | Computers & Internet
Device will not start code 10 message
Code 10 means DRIVERS COULD NOT BE INSTALLED. Try installing the drivers manually.
Do this if pc is XP.
1.Keep the wireless adapter connected to the pc
2:Go to control panel, add/remove programs. Remove the wireless adapter software
3:Restart the computer, when the found new hardware wizard shows up click on it, click NO NOT THIS TIME, then select install from a list of specific location. On the next page Click on DON'T SEARCH, I WILL CHOOSE THE DRIVERS TO INSTALL.
4.HIGHLIGHT NETWORK ADAPTERS on the hardware type, the CLICK HAVE DISC
5.Click BROWSE to set the location of your drivers
6.Open the driver folder, then the pc should copy the files.
Good Luck
Feb 24, 2008 | D-Link DWL-520 Wireless PCI Wi-Fi...
Netgear GA511 XP Home Installation
you should change your operating system
or reinstall your o/s
Jan 08, 2008 | NetGear GA511 Network Adapter
Targus Adapter is Freezing my computer!
This adapter is obviously not compatable with Vista as it was originally used in Win98, Win2000 and XP and there are no drivers on this site for Vista. http://www.targus.com/us/drivers_manuals.asp?SKU=ACB10US For the price of a new Vista compatible Bluetooth adapter it's not worth re installing another operating system as all adapters should have all the same uses as each other.
Mar 07, 2007 | Targus (ACB10US) Bluetooth Wireless...
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
