Question about Thomson Washing Machines
My front loader hydrax model washing machine cannot open its door even after the washing cycle has completed I have tried to contact the local dealer and is taking a very long time to come inspect and my clothes have been there for almost a week please tell me how to unlock the door manually
  • Thomson Master
  • 17,130 Answers
If the drain pump/alve has worked and the water has drained off the machine then you can reset the door switch by pushing the safety lever down to release the lock on the door .
Now this can be done only if you can observe very carefully using a good position and light to locate the door lock and release lock lever from the program controller.
Once this is done , check the program without clothes on a low wash and see if the door jams or if this is a fault on the program controller unit.
Posted on May 19, 2011
How do I increase water level in my wfxd8400uc?
I get this complaint a lot from home owners , I take it you have just got your first front loader washer , and you don't think it adds enough water to wash anything , this is the water saving feature of front loaders
but a simple test I tell most folks to do if they think there water level sensor is not working right
set washer to auto load sense on water level , normal wash cold water, permapress add nothing to drum completely empty! no soap unless you have a auto soap dispenser then it wont start to you add some and close door
start cycle wait till fill is complete just as it goes to agitate stop cycle (plug can be pulled for this if buttons have locked out )and open door see if water level is two fingers wigth under door seal , if its close your ok if it's a long way off then contact a repair department to look at auto sense water level
May 07, 2015 | Washing Machines
Whatever the cycle you choose, the door open light turns on, even though the door locks when you start the cycle
I take it that it is a front loader, what make and model machine do you have?
regards
Graeme
Apr 20, 2008 | Washing Machines
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Door won't open and is jammed.
We have an electronic Sears front load model with which that happened. . If this is a Sears machine contact the service number located in your manual and they should be able to talk you through it. For us it ended up being a door switch that had become misaligned. Make sure the machine spins the water out of the tub before you try to open the door if it is a front loader.
Apr 02, 2012 | Amana Washing Machines
HI, i have a zanussi FJDR1466s washer which is now 7 years old and i have grey lines on washing after a wash also there is grey grunge in the door seal. Can you tell me what i should do to correct this...
Hello, W/D here.
We use bleach to clean the washer from time-to-time.
1. Mix bleach 50%50% with water, and wipe the door seal and bellows liberally.
2. Pour the remainder in the tub, along with one additional cup of straight bleach.
3. Fill all of the dispenser cups with bleach.
4. Run the hottest cycle available for your machine, and the hottest rinse cycle available. For our machine, this is the "sanitary" cycle.
5. When this cycle has completed, run a regular cycle to purge out any residual bleach.
5. Leave the door open between wash loads. This allows the moisture to evaporate, and keeps the mold from developing. This wasn't ever an issue with top loaders. Most people left the lid open! It's more of a problem with front loaders; there are more places where water can collect and pool.
IF you don't get relief by performing the above steps, you may have to replace your bellows seal (the part between the door and the tub). I have seen where some folks' smell problem just won't go away, and that's how they cured it. Normally, the bleach wash and leaving the door open will do the trick. You may even have to do this several times to get the full effect, but it's worth a try, and is much less expensive than replacing a bellows. Like I said, it usually works.
Best regards, --W/D--
Feb 07, 2011 | Zanussi FJS1225W Front Load Washer
I have a front loader washer...it was in the middle of the cycle and starting beeping. The dr (door) signal is flashing. Cloths are wet and i can't get any cycle to go now. Any suggestions?
Unplug your machine.
Open the top of the machine.
Open door
Remove the door lock assembly
Check contacts of the door switch.
Replace if faulty or try to clean with electronics cleaning solvent.
Jun 23, 2010 | Frigidaire Affinity ATF6000F Front Load...
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
The door on my Smeg Allegra front-loader washing does not open
SOME MACHINES HAVE A DELAYED OPENING TIME SO THE DOOR DOSE NOT OPEN WHEN BUTTON PRESSED LOOK IN MANUNAL TO SEE IF THIS FEATURE IS ON MACHINE IF NOT PROBLEM THEN NEW DOOR LOCK WOULD BE IN ORDER
Dec 30, 2009 | Washing Machines
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Sep 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
130 people viewed this question
Top Thomson Washing Machines Experts
highlander28
Level 1 Expert
Garth Jackson
Are you a Thomson Washing Machine Expert? Answer questions, earn points and help others
