Question about Canon Office Equipment & Supplies
Hardware Error 03130031-2E23 Turn off printer, wait, then turn on again I done this twice and it does not fix the problem, it just repeats the same message. Any ideas what the problem is?
    New Friend:
  • 6 Answers
This error on the Canon iPF-605 wide format printer means that there is a problem with the paper cutting knife. The knife (black block) should be at the left front side in it's rest position.
Powered the printer down and moved the knife block from right to left, powered on and voila: problem solved ! Thanks Canon support!
Posted on May 09, 2014
I get error 2f1f when i power on the plotter ipf 765 can any one help us to fix it
Posted on Jan 22, 2018
  • Canon Master
  • 17,130 Answers
If this is hardware error then you must start with a check on the mains power , power to the board and the procesor boards, connector and pins. also to confirm this as in most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Posted on May 19, 2011
How do I fix error code 5b02 in Canon mx397?
When you clean the print heads, the ink has to go somewhere. This error code is, "waste pads are full". This is typically something that you take your printer to a service center for.
I did find some instructions for you, though:
How to Replace the Ink Absorber on Canon Printer eHow
Apr 03, 2015 | Canon Office Equipment & Supplies
Tip
Use this method with your own risk!! E2-2 = No paper (ASF) E3-3 = Paper jam E4 =...
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp140
turn off printer.
- press and hold your finger at on/off with reset/stop button together
- turn on printer power switch
- release the button on / off, but at the same time continue to press the stop / reset and then press the button on / off again and continued to hold the two buttons.
- wait a moment
- relese stop/reset button 2X.( you will see the led light blinks twice when you press the stop / reset twice)
- release on/off button.
wait until the screen on the printer control panal shows the number 0.
- after printer panel screen shows number 0.
- press stop/reset button 4x
- press on/off button 1x
- wait until you hear the movement of your printer roller
- when you hear the movement of the roller your printer, wait a while until you do not hear any sound of movement in your printer. :)
- turn off and turn on printer again and your will see your printer back to normal.
Ok world...Good luck
------>>>Download guide to fix waste ink overflow ip1000 Click Here
on Jul 21, 2010 | Computers & Internet
Error 5200
  • down load the file fon the following sit
  • http://www.ziddu.com/download/11944259/PCM_servicetool.rar.html
  • Extract the resetter and double click "servicetool.exe"
  • Click Reload Button and you will get a new USB port.
  • Load some papers in your printer and press the "Main" Button, wait until it shows "error 001" then press OK.
  • Then press "EEPROM" button and the printer will print some text, after that click OK
  • Then power off the printer (sometimes you have to press twice the power button to turn off) and turn on again.
  • That's done.
Aug 05, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Error 6502
Dear Asker
how would i know this error is for which printer so i am assuming it's cannon.
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error mesaages like 6502 or other types of error meaasge to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be releasedbefore doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled,the low ink warnings are showing againand they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be usefull if you need some warranty work done on you printer after the chips had been disabled. Canon does warn that disabling the chips may result in the printer's warranty being voided
Feb 28, 2011 | Office Equipment & Supplies
I have a canon mx320 printer and Im getting a 5200 error. How do I fix it?
Fix it be resetting the printer
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button the the printer is restarting.
3. Wait for a few seconds
Sep 14, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Error code 501 solution
To clear error 5100 clean the surface of the copper contact of the ink cartridges with a moistened cloth and let it air dry. Fix the cartridges to the holder and return properly the cover of the printer.
These 2 reset procedures will help you clear the errors displaying in the control panel of the printer and let you print again.
To clear U053, U051 and U052
To clear error U162 or U163
1. Turn off your printer an turn it on again
2. After the printer initialize try to copy or print. The error will appear.
3. When the error is displayed on the display panel of the printer, Press and Hold the STOP/RESET button and wait until it self restart.
4. Release the STOP/RESET button the the printer is restarting.
5. Wait for a few seconds and the pending print jobs will commence.
Aug 10, 2010 | Canon PIXMA MP180 All-In-One InkJet...
I reset the eeprom windows wont recognise printer on usb
If the printer is not working or if you're getting an error code, please try the steps below:
* Execute the adjustment program (printer must be ON)
* Choose maintenance ink pad menu
* Click read
* Click initialize
* Read(again) after "0" press finish
* Choose set shipping data (bottom menu)
* Choose set
* Wait for a while (about 1 minute)
* If there is a reaction from the printer (it will load some paper or you hear "glodak" sound), the reset process will be done. turn off the printer and then turn on again. repeat read the EEPROM
* If there is no reaction from the printer, repeat step 1
Apr 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Scanner error 5 turn off and on
Recommended action
  1. Verify that the connection cable is not loose or damaged. Replace the cable if necessary, and try the scan again.
  2. If the error continues to persist, contact Hewlett-Packard for technical support to troubleshoot the problem. 52 Scanner Error DescriptionThe device has experienced an internal hardware error. Recommended Action
    1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
    2. there is no much to do, is a hardware error, you must contact hp to your scan unit be replaced
Apr 07, 2010 | HP LaserJet 2840 All-In-One Printer
Brother hl-5270dn is desplaying the error code S01? What does this mean?
S01 = Fatal error EX
1) turn off the printer
2) wait a few seconds
3) turn it on again
H63 = DRAM access error
3) turn it on again
Sep 11, 2009 | Brother HL 5250DN Laser Printer
Managed to get rid of error 1203 message. Now repeatedly getting install colour cartridge into righthand side. I've done this (repeatedly) but it's not recognising the cartridge
It could be Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Jun 24, 2009 | Dell 962 Photo All-In-One InkJet Printer
3,477 people viewed this question
old marine
old marine
