Panasonic 37inch plasma TH-37PW4 picture going large and small
SOURCE:
leethedeuce
  • 4472 Answers
SOURCE: My panasonic high definition plasma
It is possible to be repaired. Though I don't know about the availability of the screen. How long have you owned the tv? Your best bet may be to sell it for parts and purchase a new tv. If you have any questions or need any other assistance please let me know.
Thanks,
Lee
Posted on Sep 07, 2008
  • 3 Answers
SOURCE: Panasonic TH-50PZ Plasma TV won't come on.
what is a UPS?? mines doing it too
Posted on Oct 05, 2008
  • 106 Answers
SOURCE: Blinking Red Standby Light - No picture
The six blinks indicates that an internal fan is either bad ot blocked by dust or debris, You should be able to look in the back of the unit and see some cooling fans. Chances are one on them is not turning and will need to be replaced
Posted on Nov 26, 2008
  • 53 Answers
SOURCE: (panasonic TH-42PZ77U plasma) the tv will power on
in protective mode the tv does not turn on and light is blinking, typically we must proceed by elimination as some faulty sections are preventing the tv to switch on. unplug the output power connectors from the power supply until the latter stop clicking. if it is still clicking after every of the output rail have been disconnected, then the power supply itself is faulty.
hope this helps!
Posted on Mar 21, 2009
  • 9 Answers
SOURCE: Panasonic TH-42PX60U PLasma - 1/2 screen blacked out
If the screen split is exactly 50/50 top/bottom You are not getting SU or Scan Upper drive.
These are lovely set to work on.
Most likely is SU board itself - Not repairable just to be replaced.
Sorry I work in the UK so I can only guide that the UK part is around £30
SU may have been damaged by failure if the PDP (Plasma Display Panel) but is 9 years only had 2 screens damage the SU board.
There are several setups to do after fitting a PDP. If you don't have the service data - Do not risk it, Reduced life of the Panel and a safety risk.
Posted on Aug 14, 2009
There is no zoom or aspect ratio on my Panasonic Vierra remote and the picture is too large for the screen. How can I fix this problem
Try exploring the picture set up menus on the device that is supplying the picture, it may be a cable box or DVD player or other. Change it to 16:9 ratio on that device. Does the problem exist for all types of devices supplying pictures to your TV or just one?
Dec 15, 2013 | Panasonic Viera TH-42PX80U Plasma TV
The on/off switch doesn't work on our 37inch Panasonic plasma tv
There should be some fault with its main power supply regulator board. Check it. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 05, 2013 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic TH-C42HD18 42 In. Plasma TV inputs not working
yes. you find the main board for you panasonic plasma tv from shopjimmy.com.. good luck!
Sep 03, 2012 | Panasonic TH-C42HD18 42 in. Plasma TV
The picture on my 42"
SHOULD BE A BUTTON ON THE PANASONIC REMOTE THAT SAYS "FORMAT" OR "SIZE" OR "WIDE" OR "ASPECT" PRESS THAT BUTTON UNTIL DESIRED PICTURE IS ACHCEIVED.
Dec 17, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic plasma goes dark
sounds faulty. contact your retailer.
Apr 11, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic plasma
go in to your tv's menu and go in to picture settings , you either have the zoom function on or its been set on 4:3. check these and if zooms on turn it off or if 4:3 is on switch to 16:9
Nov 28, 2007 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
VERTICAL LINE ON TH-42PX70B
there is nothing you can do.the display  panel is defective and you must replace it
Oct 28, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Ekse
