Question about Stanley Bostitch N88rh Framing Nailer Driver Piston 158582
Gun miss fires several times and then fires one nail and repeats the cycle. Can you help? Thanks
  • 1 more comment
  • mrbillg581 May 22, 2011
    I tried all you mentioned and cleaned and lubed all parts in the nailing and feeding area but still not working.
  • mrbillg581 May 24, 2011
    I did all that and still no differences. I did notice that the trigger sometimes makes a click and sometimes not. Could that be a problem?
  • mrbillg581 May 27, 2011
    I think you may be right about the nails I use, although I've tried several brands. I tried firing one single nail and no problem. When I put a stack in, the second nail gets in the way of full compression of the point not allowing it to fully retract unless I press really hard on the gun
    then it fires every time. Do you agree that nails are the problem?
  • 2,176 Answers
Could be a couple items. First I assume that you are using the right nail collation. Next UNPLUG the air and remove all the nails, do they slide in the magazine freely if not that could be one cause. If they do next look at the driver blade is it all the way up to the top of the nose, pull back on the nail follower to get a peak. Next GENTLY tap the nose on a block of wood and does the driver FALL down easily and if so the oring is worn not pulling the driver back up to allow the next nail to advance. Lastly look for a partially jammed nail in the nose area that might not allow free movement of the driver blade after shooting. I would have to think it is in the o ring/piston area. Let me know if you need more assistance
Posted on May 19, 2011
  • David Ford
    David Ford May 23, 2011
    did you recheck the nails? they can cause a misfeed if not moving freely in the magazine. Also did you check the condition of the driver/piston if it does not retract fully on the first shot it might take a couple times to fully retract to allow the next nail to advance. I think it is going to be one or the other.
  • David Ford
    David Ford May 24, 2011
    the click would probably be from the safety. You indicated the gun was firing but misfiring some nails. If the gun won't fire/drive piston every time then that is a different problem and I would recommend buying a rebuild kit and replacing all the orings. If the gun fires all the time but won't advance the nails it has to be in the areas I mentioned. Do the nails slide freelly and there are no obstructions/jammed nail in the path, the only other area I see is that the piston is not retracting enough to allow the next nail head to come under it ready for firing.
Air comes out the nose of my dewalt framing nailer
Again sounds like blown O ring give it a squirt of 3in1 oil and fire it several times (if oil is compatible in your gun). Repair center if that doesn't work. Trash can also get in the air orifice and stop moving parts from moving.
Dec 07, 2013 | Dewalt Air Tools & Compressors
Why does my Hitachi nv45ab gun double fire nails?
This gun should be bump-fired only. Do not place the gun on the work and press trigger. Make sure that the safety spring is in place and has good tension. The spring helps to push the foot off the trigger so that it fires once. You could also adjust the screw that pushes on the firing valve. Turn in or out several turns till head of nail is correct when bump firing then lock the nut. The safety foot fits rather loose on the gun and should still work ok but can get so loose that it falls off the nose. Good luck
Jan 23, 2013 | Hitachi Air Tools & Compressors
Miss fires and wont sink nails depth set deep and pressure over 120 psi
If no air is leaking from gun, miss-fire is usually caused by worn or too tight piston oring or lack of lubrication. Easy test. Disconnect airline, remove nails, point nose of gun up then down. Driver should stay in uppermost position. If driver moves up then down within gun replace piston oring and retest. Set pressure to about 100psi. Good luck with repair.
Oct 14, 2012 | Porter Cable Coil Roofing Nailer
Nail gun problem
This is a bottom fire tool. (NV83A2) You need to hold the trigger down and then as you place the nailer to the wood the safety will depress and it will fire once. This is usually done in one, swift action. If you do this in the opposite way by placing the tool to the wood and then pulling the trigger they often will double fire.
Jul 05, 2012 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
I have a Max cn70 nail gun. When trying to fire the gun, air seeps from the trigger assembly and will not fire. Help!
Hello, sounds like a nail is jammed in the chamber. Happens frequently. What you do first is disconnect the gun and empty any nails. Then, with a screwdriver or a big nail hit the ram driver back down . Reconnect and test by depressing safety latch and pulling trigger. Repeat. Hope this helps. -ROB
Feb 10, 2011 | Air Tools & Compressors
Hitachi NV50AP3 1-1/4-Inch to 2-Inch Cap Nailer Brand new gun, just bought it. Gun does not always cycle properly or cleanly cut the plastic caps off of the roll. Many times the cap just nailed is still...
Several of my customers are having the same problem here in New Mexico. If your air temperature is around 95 degrees or higher the plastic the caps are made of becomes too pliable to break off when the nail is fired through it. If you cool or freeze the cap roll, the caps will break off however this usually impractical. Get in the habit of moving the gun forward after firing a nail/cap to break the cap off. If you pull up or backwards you get a string of caps pulled out of the gun.
Sep 08, 2010 | Hitachi NV50AP3 Cap Nailer
Fires 2 & 3 nails every so often.
Most all nail guns can be converted to single fire, however, usually parts must be changed. Some brands have two positions on the trigger, others have a button position near the trigger to accomplish same. Check with dealer or email your gun model # and I will explain your to fix. For now you can replace the spring on the safety with one slightly stiffer. Also try nailing with trigger depressed and quickly bump the gun to fire, this method usually works better than placing the gun in position then firing. Good luck with your repair.
Jun 24, 2010 | Hitachi 3 - 1/2" Full Roundhead Framing...
Feeding nails
Your nailer shares design features with Milwaukee and Ridgid. All three brands experience the same issue. Lets go thru a series of simple tests to determine the problem. First and most simple test, manually load the nails and fire the gun untill miss-fire. Upon mis-fire disconnect air, open latch and check if the driver is all the way up into the cylinder or is partially down blocking next nail. If driver is down blocking next nail, replace the driver oring and retest. If driver is up all the way, remove nails, reconnect airline, leave latch open and fire gun against rubber (old tire or coiled up waterhose/airhose) this time holding the gun down and keeping the trigger depressed. In this position, the driver will remain down and feeder will remain retracted. With feeder retracted and screwdriver in hand carefully check the spring tension on the feeder (should be rather firm tension on spring and the feeder must retract with good force). If no tension or weak, replace feed spring. When you finally release the trigger, the driver will retract and the feeder should return with good force. If feeder does not return with force, replace orings and spring behind feed piston. If all tests are ok, remove head, check lower bumper in gun for cracks or missing pieces. Replace as necessary. Lube all orings with silicone lube available at Lowes in the plumbing department. (Danco brand) Good luck on your repair and email your questions.
May 06, 2009 | Porter Cable Cable RN175AR Reconditioned...
Stanley Bostitch N88rh Framing Nailer Driver Piston 158582 Logo
67 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
