Question about Panasonic PT-61G63 61 in. Rear Projection Television
Panasonic PT-61g63 color is bleeding and blurry
  • Panasonic Master
  • 3,459 Answers
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Panasonic PT-61g63 color is - 69189a5.pngttp://i.fixya.net/uploads/images/69189a5.png" alt="69189a5.png" class="h_mi" />SOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needsPanasonic PT-61g63 color is - 578ba6c.jpgchanged.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Please do us a favor and rate this solution after reading
Posted on May 20, 2011
I have a Panasonic PT-47WX42F with what looks like double vision or color bleeding. How can I fix it?
replace the two convergence chips which are stk=392-110's
Do you know how to solder?
Mar 08, 2012 | Panasonic Televison & Video
I have bleeding colors on my panasonic 53 can I
This problems adjustment well not work.Ur tv have a problems known as convergence problems,and it dead.The tv convergence board must have it 2 STK convergence ICS,and some or all it resistors, must be change.The shop will cost u $300-350 for parts and labors.
May 22, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Black screen
how many times does the red light flash?
Techman
May 16, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Green color outlines images on picture blurry picture on right side of screen
you have a convergence problum. you may need to replace the 2 convergence ics stk392-110
Apr 22, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Very blurry picture all of a sudden
sounds like you convergence generator is gone out, when this happens it is common for one or more of the colors to go out of alignment and not able to adjust, or hold the adjustment. typical cost for this type of repair at a shop is $250-450
Mar 27, 2010 | Panasonic PT-53WXD63 53 in. Rear...
PT L711U + all my black colors are blue
Your projector needs to be aligned and serviced, normal occurrence
after 6 years since service.
Apr 18, 2009 | Panasonic PT L711U Multimedia Projector
PT-61G63 Convergance
Your convergence IC's most likely need to be changed, possibly some resistors as well.
Do you know how to solder and use a meter? If so you may be able to fix this yourself for under $100. If not you will need to repairman to repair it, this should cost around $300-$500 Let me know if you want to repair it so i can get you going.
Tim Nolan
Sep 12, 2008 | Panasonic PT-61G63 61 in. Rear Projection...
Convergence problems
I would suggest the convergence ICs as well as a couple resistors right near the Convergence ICs mst likely. 90 % of the time thats the problem. They are not expensive, if you can solder you can handle it if your careful with your solder and use heat sink compound. The ICs will have a number stamped on them usually STK XXX-XXX on a huge heat sink. The following link will have replacement parts http://electronix.com/ Hope this helps you out
Jan 11, 2008 | Panasonic PT-47X54 47" Rear Projection...
Panasonic PT-LC56U Multiple pictures
iF YOU HAVE SERVICED THE SAME, THEN YOU HAVE TO ALIGN PANELS. CHECK THE ATTACHED CABLES ALSO..
Jan 17, 2007 | Panasonic (PT-LC56U-DEMO) Multimedia...
Panasonic PT-61G63 61 in. Rear Projection Television Logo
32 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
