Downloading deep freeze standard - Computers & Internet
  • 749 Answers
I'm using a low version and has no problems to it..
try this if you like click me
Posted on May 19, 2011
I forgot my deepfreeze and i need to delete it tho it can't be deleted without unfreezing my pc i tried antideepfreeze and it failed for me ....what can i do ?
There's no possible way to recover a lost/forgotten Deep Freeze password. But there are several ways to possibly disable/uninstall DeepFreeze.
Enterprise Version :
Deep Freeze Enterprise users can generate One Time Passwords (OTP) to gain access to deepfreeze. To generate an OTP,
  1. Open the Deep Freeze login dialog on the system for which you need to generate the One Time Password.
  2. Write down the Token code. It is located at the top of the login dialog.
  3. Open the Deep Freeze Configuration Administrator and click the One-Time Passwords tab or open the Enterprise Console and click on Tools > One Time Password.
  4. Enter the code you recorded into the Token field and click Generate OTP. Another code will appear in the OTP field. The second code is the password for the workstation.
The newly generated One-Time Password can then be used to disable, uninstall, and re-install Deep Freeze with the correct password.
For Deep Freeze evaluations (with no License Key entered) :
  1. Restart the computer.
  2. Enter the system BIOS settings.
  3. Advance the clock by at least 60 days and then restart your computer. This will disable the software.
  4. After the system has started, run the Deep Freeze installation program to uninstall Deep Freeze.
  5. After the computer reboots, re-enter the BIOS and reset the clock to the current date. You can then re-install Deep Freeze after restarting.
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options avalalbe to assist you.
Feb 14, 2013 | Computers & Internet
Uninstall deep freeze, forgot password
If you are licensed for Deep Freeze Standard and have forgotten your password, please email technical support at support@faronics.com for further information. Include your license number and organization details.
If you are running a 60 day evaluation version of Deep Freeze and have forgotten your password, then enter the computer s BIOS and forward the system clock 60 days & restart.
I hope this helps, if it does, give me a big thumbs up!
Jun 28, 2011 | Computers & Internet
My deepfreeze didn't show in my taskbar how i can disable it?
I understand that you would like to disable the deepfreeze software installed on the computer.
One or more methods can be employed to enable/disable (Freeze/Thaw) Deep Freeze depending on the version being used.
A) Locally at the workstation (Deep Freeze Standard and Enterprise):
The following steps can be used to disable (Thaw) Deep Freeze:
  1. Hold down the SHIFT key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6. A Password dialog is displayed.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering a password. The Boot Options dialog is displayed.
  3. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. The same steps can be used to enable (Freeze) Deep Freeze. The only change is to select "Boot Frozen" instead of "Boot Thawed".
B) Remotely via Deep Freeze Command Line Control (Deep Freeze Enterprise only):
Deep Freeze Command Line Control (DFC.EXE) can be used to Thaw/Freeze Deep Freeze through a script or batch file. More information about using this utility can be found in the Deep Freeze Enterprise user guide available at:
http://www.faronics.com/documents/DF6Ent_Manual.pdf
C) Remotely via the Enterprise Console (Deep Freeze Enterprise only):
The Deep Freeze Enterprise Console can be used to Thaw/Freeze a workstation using the following steps:
  1. Select the workstations to Thaw/Freeze.
  2. Click the "Reboot in Thawed state" button to Thaw the selected workstations. The workstations should reboot and appear in the Console in a Thawed state.
  3. Click the "Reboot in Frozen state" button to Freeze the selected workstations. The workstations should reboot and appear in the Console in a Frozen state.
Please try the steps and I am sure you would be able to disable the deepfreeze software.
Apr 20, 2011 | Faronics Anti-Executable Standard
I installed my deep freeze software in my laptop.now i forgot that password. so really i cant store anything in my laptop.
Hi!
Sorry I was unable to provide you exact help on this one as I don't know the deep freeze version you are using but you may want to try these steps, if it doesn't work out, please coordinate with us with the version of the deep freeze.
For Deep Freeze Enterprise:
  1. Open the Deep Freeze login dialog on the workstation for which you need to generate the OTP.
  2. Write down the Token code which is located at the top of the login dialog.
For Deep Freeze evaluations (with no License Key entered):
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options available to assist you.
Or if you may want, you can also back up all your files then reformat the computer. Thanks for reading my suggestions.
Hope this helps even a bit.
Apr 17, 2011 | Computers & Internet
I cannot remove deepfreeze
have u the password for the program? if u have then press CTRL+ALT+SHIFT+F6 at main windows.
this will open the deep freeze program. insert the password press OK.
at the deep freeze window there will be option to frozen, thawed, or thawed for next. choose 'thawed' then restart windows.
if you succeed to thawed the deep freeze then find your master program for your deep freeze (master that u use for installation). run the program, there will be choice to uninstall the program. press it.
then it will automatically uninstall.
if u dont have the password, try to download the anti deep freeze first to thawed your PC. this link will help you to download the program:
http://www.softpedia.com/get/System/System-Miscellaneous/Anti-Deep-Freeze.shtml
hope this useful.
Feb 18, 2011 | Computers & Internet
Dear sir i have a problem with my deep freez when i am doing the uninstall process the error has come " deep freez standard must be disabaled for any install/uninstall can proceed" plz help me...
Well, as it's said, you'll have to disable ("unfreeze") Deep Freeze before it could be uninstalled...
To do that, press SHIFT while double-clicking on the DeepFreeze icon on the notification area (near the system clock). Enter your password, and set it to be Thawed. Restart and re-do the unistall process.
If you don't remember the password, you can use DeepFreeze Unfreezer!
Good luck,
Pelu.
Dec 07, 2010 | Computers & Internet
While installing deep freeze my system rebooted and then some error happened. following which it kept on rebooting couple of times, so i used system restore setting to run it. when the system recovered i...
This is the coomon error of the deep freeze . I you can not access deep freeze then download deep unfreezer from http://www.brothersoft.com/d.php?soft_id=171878&url=http%3A%2F%2Fusfiles.brothersoft.com%2Futilities%2Fmiscellaneous%2Funfreeze_quicksetup.exe
Then disable deep freeze with out password after that use the same istaller to unistall the deep freeze which you have used to install .
Nov 02, 2009 | Computers & Internet
Anybody have deep freeze crack serial number
I do have deep freeze installer but never been used the software with a key. Besides, I don't prescribe giving out crack because I for one believe that by doing that is equivalent to committing a hideous crime against the Hackers community and the makers of softwares. However, here is the site to where you can download free installer:
http://www.orbitdownloader.com/freeware-download/Deep-Freeze.html
Just follow this link. Thanks.
Jul 06, 2009 | Computers & Internet
I am looking for a software in uninstall deep freeze v6
Just make a search for anything you want to download - say a software,ebook,movie etc. You will find the links of webpages from where they can be downloaded. To further narrow down search, just click on the relevant category on search page http://indiashomepage.com/browse/links/download/unfiled/17964/G
Jun 15, 2009 | Computers & Internet
How to uninstall deep freeze from your pc?
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
  3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  2. Run the installation file (DF5Std.exe or DF6Std.exe).
  3. Select the option to "Uninstall"
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Apr 08, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
