Question about IBM Computers & Internet
A friend gave me an ibm k8m800-m3 mainboard (no case) i am just looking for the panel connector pin-out to install in a case and set up for my kids. any help appreciated, thx
  • 749 Answers
If this looks like it, then use it
if not, post it again
Posted on May 19, 2011
Trying to install an ASUS H81M-C Mainboard with Intel core i5-4460. No way to turn on. Mainboard's Power led is on. Nothing happens at all. All connections are OK. Anyone has an idea? Thanks.
When you say that all connections are ok, you understand that we have to verify as this is the most common problem that occurs when installing motherboards. Obviously you have the large connector from the power supply plugged in since you have the power led on the motherboard. This is good. There is also the ATX 12V CPU 4-pin power connector that must be connected just above and to the left of the CPU. But the most often messed up arrangement are the front panel connections to the motherboard at the lower right corner. This is a 9-pin connector block (actually 10, but top right corner pin not there and bottom right not used).
In the link attached, go to page 26 of the pdf, which is page 1-18 of the manual. At the top of the page is a drawing of the connector block. The green power led takes the first two pins in the top row from the left. The connector plug should have a green and a white wire. The green is the positive and goes on the left pin of the pair.
Right below that is the two pins for the HDD light. This plug should have red and white wires. The red wire is positive and goes to the left pin of the pair. Going back to the top, the power button is the remaining two pins. These wires can vary in color from case to case, but if you don't see a label, just follow them back to the power switch to figure out which pair they are. This connector can be installed either way, there is no fixed polarity. The remaining two pins are for the reset switch, which some cases have and some don't. This connection does not to be used.
If you have everything correct and the unit still won't power up, then you need to verify that the power switch is working. If you have a reset switch, it is easy to test, just switch the reset and power button connectors and press and release the reset button and see if the board powers up. If you don't have a reset switch, remove the connector from the power button pins and carefully short them together for a brief second, which simulates pressing the power button. If it still doesn't power up, then there is something wrong with the motherboard.
One last thing, if the front panel connectors are all installed into one plug (which some manufacturers like DELL does, and you are installing this motherboard into their case, be sure to verify that the wires on the connector goes to the appropriate front panel switches/indicators, as these connector blocks are not fully standardized.
Nov 23, 2015 | Intel Computers & Internet
Wiring diagram for ms 7069
Hello here is the homepage:
http://www.nec-computers.com/support2/pib.asp?mode=default&platform=platform_callisto_g_mt
This mainboard is a OEM manufactured by msi for NEC.
The support belongs to nec, and there is nothing to be found at the msi homepage.
Basicly its just to connect the 20 or 24 pin power connector, and the 4 pin atx power supply.
Next connect the power to the dvd and harddrive.
Then connect the data cable from the drives to the mainboard.
The front panel connector looks like this:
This is basicly the same for all msi mainboards.
Next you can power up the pc, and enter the bios and set the boot order ( press the delete button when posting )
Lay the windows disk in the dvd drive, and leave the bios and save your settings.
Now your ready to install windows.
The drivers can be downloaded here:
http://www.nec-computers.com/support2/pib.asp?platform=platform_callisto_g_mt&mode=2000&title=Downloads
Best of luck
Mar 18, 2013 | MSI : MS-7061-020...
Dont seem to have enough front panel pins for all my case wires
Hi Greeneyedbj,
What kind of I/O connectors are you looking for *********** board sir?
The image above has the following for your I/O connectors.
1. Three usb headers up to 6 additional devices, most casing can support 2-4 pins. 2. Front Audio Connector. 3. Front Panel Connector. Power Sw, Reset Sw, Powed Led, HDD Led
Branded casing has the following I/O connectors.
1. Esata 2. Firewire (Dont use the USB headers, firewire use a different pin-layout) 3. Chassis Intrusion Alarm Header.
Hopefully this information helps.
You can ask for more help.
Thank you for using FixYa.
Sep 23, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
I need ibm x3200 m3 (7328) setup installation image?
IF you are looking for fresh installation , you need server guide cd which has the option to create raid and contain all drivers for the server
Download it from the below link
Hey its a image file , so download it and write it in cd. Make boot option from cd then.
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-5079561
Hope this would help
Thanks
Feb 15, 2011 | IBM System x3200 M3 7328 Server tower ...
Driver mainboard PM - 865G1 REV 2.7
it's the same motherboard of IBM ThinkCentre M50 you can download all driver from the website of Lenovo. To make it quick download from here : http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-50534
cheers
Feb 07, 2011 | IBM 89P7663 Motherboard
Ibm netvista x41 wont power up
measuring 12v at the psu is not enough. the psu have several voltage outputs ranging from 12volts to 3.3 volts and maybe even 2.2 volts.. firstly, check all onboard USB ports, a bent or shorted pin in a USB port will prevent the psu from operating. next, the psu has a safety connection to the mainboard, this is called the power good signal ( pwrgd) and it is a signal from the psu to the mainboard and tells the mainboard that everything in the psu is functioning correctly. If the powergood signal is lost ( drops from 5volts to zero volts) the mainboard will issue an interuppt to the cpu and the cpu will shut down, this will also shut the board down to prevent damage and data loss. mainboards all use pretty much the same connectors so your board will have either a 20 pin power connector or a 24 pin one. It may also have an additional 4 pin connector to power the cpu and northbridge functions. use a known good psu and plug this into your board along with the 4 pin connector and attempt a switch on. If the system begins to boot, replace the psu. if not, try unplugging or removing everything connected to the board, pay special attention to expansion cards and usb ports. remove the ram sticks and video cards if fitted, then attempt to boot again. if the system does not respond, replace the main board. if it now begins to boot, refit everything one item at a time and try starting the machine. turn off before refitting the next item and start the machine up again. when you get to the problem item, the machine will stop starting. If all else fails, replace the mainboard or take the machine to a reputable repairer..
Oct 30, 2009 | IBM NetVista X41 PC Desktop
Acer m464 front panel connectors
Sorry in the 1st instance for my lack of specific knowledge when it comes to ACER hardware.
Is the model of your MOTHERBOARD - Acer m464?
If so do you happen to still have a manual that came with the motherboard?
Sometimes you can see the pinout in white writing on the mainboard itself near the connector block... have a close look and see if it is there.
The pin out for the connector block will definately be in the mainboard manual. If you don't have the manual then you'll need to do a little searching for it... I'm sure a .pdf of it will be floating around... i guess start at the ACER site.
On the rack mount chassis, are the plastic chassis connectors grouped (ie. 2 wires into 1 connecter for pwr led, etc) or are they individual single pin connectors?
Either way for each group, one should have a little TRIANGLE on the opposing side to the writing. Conventionally this is your positive (+) pin when looking at the pinout diagram. Ensure you have correct polarity for all ur connections obviously.
See how you go mate.
Mar 25, 2009 | Acer Computers & Internet
IBM Clicky Model M Keyboard
Viewing the male connector (on the keyboard or mouse cable), the pinout is:
In both cases, the pins are normally used as follows:
pin function
1 data (yellow)
2 (reserved)
3 gnd (blk)
4 +5v (red)
5 clock(white)
6 (reserved)
try to interchange wire from pin 1 and pin 5 if doesn't work.
Dec 27, 2007 | IBM (02K0806) Keyboard
IBM NetVisat 02R4084 Mainboard
With the power on cross the pins with a slide on connector. When it fires on you know which one is the sw. When you cross the reset it will restart. When you try the HD the light will come on during HD activity. And the power light will work when you have the power light plugged. It isn't to hard. Just be careful.
Sep 27, 2006 | IBM (02R4084) Motherboard
Computers & Internet Logo
769 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
