Question about Powerwinch Boating
Horizontal jib sheet power winch
Intermittent failure of motor to turn winch
bruce
  • btux250 Aug 14, 2008
    sometimes i can restart the winch by inserting the winch handle, turning a few cranks, removing the handle and pressing the button again. the winch is activated by pushing one of two start buttons - fast or slow.
    Master:
  • 623 Answers
Try replacing the switches first.
Posted on Aug 18, 2008
  • 87 Answers
Send the photo
    Sergeant:
    Champion:
  • 310 Answers
Can u send the photo of this motor to my mail
khader_abu@yahoo.com
Posted on Aug 14, 2008
  • khader ibrahim Aug 14, 2008
    Change the stater(capacitor) of the motor...
John Deere 2012 648g3 skidder winch will let out, when you try to winch in it will roll slack out of cable, but winch won't lock up and pull hard. How can I fix it?
if your saying that winch will take in and let out ok but wont hold a load in tension , then your winch directional valve or the winch motor is worn out and is allowing oil to pass right thru it regardless of it not being activated as skidder winches don't have a brake like electric winches do it uses the power of the oil locked into motor to hold a load ( that's also why id never stand under a load suspended by one !!!)
Nov 15, 2015 | John Deere Garden
KFI winch won't spool in or out there is power to it I can hear it clicking
If your wiring a remote control to the winch or inside control,,, 4 solinoids type,,make sure the solinoids have ground on the brown wire(warn)...if you don't have a ground all it will do is click,,,even if power is applyed
Feb 19, 2015 | Cars & Trucks
I need a spring that holes brushes in on a gew 9000 winch motor thanks
most winch motors are basic starter motors. Take the remaining spring along to an auto electrician to see if it can be identified.
Contact the winch manufacturer to see if they have a parts catalogue for the motor.
Feb 10, 2015 | Cars & Trucks
Was installing a winch on my 2009 prowler 700 xtx hooked positive cable to selanoid winch did not work,hooked direct to battery,works,rig wont start
Where did you ground the winch motor? You need a separate, heavy duty, switch with a relay to transfer the positive side voltage properly... DO NOT ground to the battery..use a clean, free of paint, place to ground. You may have fried the solenoid..do not connect the positive side to the solenoid. Direct connection to the + battery from the relay is good with a good waterproof fuse in line. Sometimes I have seen the "maint. free" batteries die when used "wrong" and still show 13 volts+.
Apr 08, 2014 | Arctic Cat 2009 Prowler 700 H1 EFI XTX 4x4
Winch won't wind in
Bad ground or check the power to the winch if it has power the motor went bad
Feb 01, 2014 | A3000: Atv 3000 Winches
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Tmax winch no power
The winch has electric solenoids to control the motor. Most of the time when these things quit working, it is either because the solenoid has failed or the wire connections to the solenoids has come loose.
Mar 23, 2012 | Cars & Trucks
Snow Bear Winch..... Will not pick up plow at times. Motor seems strong drum will not turn,,,slips. Is there a replacement part available without buying an entire winch? Thanks
Hi there, I had the same problem, my winch has a chain to lift the plow.I put oil on the chain to keep from rusting and thats what started my troubles.So I took the mount off that holds the chain on the winch and there's a brass piece that is squeezed behind it.Cleaned and tightened it and works fine now. If you take motor off winch to check gears[ DON'T USE GREASE] when reassembling! When its cold it doesn't want to turn, just use motor oil or spray lube
Jan 19, 2011 | 82" TruckSUV Snow Plow
Flashing F1 and beeping, on a GE JRP15 Electric Single Oven. What does it mean?
This is usually a control board failure, but sometimes can be caused by the keypad. There is a procedure outlined in the tech sheet to determine which it is.
best regards,
Bruce
www.fixyourboard.com
Jun 15, 2010 | GE JRP15 Electric Single Oven
518 cat skidder gearmatic winch keeps turning when put in free wheel 1985
pull the secondary clutch apart on the winch and clean with emory cloth or sand paper and u should see a change in this problem
Sep 08, 2009 | Heavy Duty Associated Equipment 6002B...
Boating Logo
Top Powerwinch Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Powerwinch Boating Expert? Answer questions, earn points and help others
