Question about JVC TH-A25 System
Hello, I have a problem with my jvc-tha25 on having started on the screen there appears (protection) and desconecta.he proved without the altaboces and follows equally the only thing that and I dress is that to the principal relay they come to him 14v instead of 12v is this reason?
2 Suggested Answers
SOURCE: JVC XV-THA25
Fixed it by replacing a burned resistor.
100ohm 1 wat designation PR010 on the main pcb.
Posted on Aug 11, 2008
How to remove protect sign from JVC KDR-416
Sounds like you have a speaker wire shorted or touching. Pull stereo out of Dash But leave wiring harness plugged in. With stereo off unplug positive and negative of one channel or speaker then power on to see if it starts to work. If it still says protect shut back off wire that channel back up and go to the next Channel. As you do this one speaker output should be the culprit. If you go through all 4 and it still says protect then it may be a problem within the unit itself
Oct 01, 2016 | JVC Car Audio & Video
Hello, I'm not able to play files on my Sony walkman NWZ-B133F MP3 Player. Please help, the error being shown is "Boot Eeror"
boot_error
Yo tenia este problema y esta solucionada.
Sigue los siguientes pasos.
1- Baja firmware nwz-b133f (firmware nwz-b130 v-1.01)
2- Baja firmware nwz-b103 (firmware nwz-b100 v-1.3)
3- Primero ejecutar firmware nwz-b100 , conecta tu walkman
cuando pida conectar por favor el dispositivo luego pida formatear
el dispositivo vas a perder toda la informacion has click en
aceptar.
4- No desconectas tu walkman espere hasta que formatea
todo y carga todas su datos , este era necesario para el puro
formato porque el firmware nwz-b130 no lo hace.
5- Desconectas tu walkman y vas a ver que no enciende (logico no
es su firmware)
6- Ahora ejecutar firmware nwz-b130 , conecta tu walkman cuando
pida conectar por favor el dispositivo , no desconectas tu
walkman espere hasta que carga todas su datos.
7- Cuando termina desconecta tu walkman de manera segura.
8- Listo como nuevo.
Saludos Quicktronics aqui desde mexico.
Espero que la gramatica esta bien , soy Holandes.
Aug 28, 2010 | Sony NWZB133F MP3 Player
My jvc 56" proj. tv pops several times when i turn it on but the screen stays blank
Ok, I suspect one of the two convergence chips is shorted, this is usually the most common reason the light (blue?) just blinks.
I can tell you in a easy way how to prove this without replacing any part--
What kind of skill do you have?
This entails removing the front grill under the screen and disconnecting the Convergence board behind the inspection plate.
I am here to help--
SD TECH
Oct 11, 2009 | JVC AV-56WP74 56" Rear Projection...
No audio
The word PROTECT appears because there is a short. It can be in your speakers, try running it without the speakers plugged or check to see if your speaker wires are touching (shorting).
If it still says PROTECT, its because there is a short somewhere in the system, probably from the output section.
The system does this to prevent anything from damaging the electronic components inside.
Mike
Sep 26, 2009 | JVC MX-K3 CD Shelf System
Jvc model no.ca-hxd7 system no. hx-d7
Check back speaker wires! this is protection mode! There is a short circut! look for stray wires touching metal or each other!
if this does not do it then unit will have to be fixed by a pro!
Please use the ratings and help keep this area FREE!
Jan 23, 2009 | JVC MX-GT88 CD Shelf System
I TURN MY STEREO ON AND A MESSAGE APPEARS ON THE SCREEN THAT SAYS "PROTECT" AND IT POWERS DOWN. JVC MODEL NO. CA-HXD7 SYSTEM NO. HX-D7
OK this is the protection mode! There is a short circut! unplug and check all back speaker connections making sure no stray wires are touching metal or each other ! if this does not help the short is inside of unit and will have to be fixed by a pro!Please rate my answer and help keep this area FREE! THANK YOU!
Adjusting screen brightness and contrast
press F2 when the computer starts, the bios page will appear, ALT+P to change the pages until you see the screen bightness options, then you can change it as you want. I hope this will help
Oct 04, 2008 | Compaq Evo N800v Notebook
No audio from dvd player
you wil get the sound from the surround speakers only but not from tv first connect all the speakers that are given to the player correctly then you can get perfect sounds with dts...
May 04, 2008 | JVC TH-A25 System
JVC XV-THA25
Feb 09, 2008 | JVC TH-A25 System
JVC TH-A25 System Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
