Question about Hitachi L32HP01 32 in. HDTV-Ready LCD TV
Hitachi L32HP01U sometimes will not start - Hitachi L32HP01 32 in. HDTV-Ready LCD TV
How to fix Hitachi Miter that won't start sometimes?
Replace the brushes and it will work like new. Easy and cheap job.
Apr 24, 2014 | Hitachi Saws
When i switc on my hitachi 42pd5200 tv the standby light turns green but the tv does not start up, any ideas of how to resolve the problem?
if the LED turns green and remains green that means the TV is likely starting up just fine.
if you can shut it off (i.e. turn it back red) and then back green, i.e. if you get it to respond to your command that means the TV is actually operational.
What is NOT operational is part of it , that is not central to the main board's functionality, e.g. the circuits that have to do with the display itself.
In your hitachi that is most commonly the buffer boards and the Y-Sustain board, which sometimes fails and sometimes does not when the buffers fail.
Sep 25, 2012 | Hitachi Televison & Video
My Hitachi twin stack air compressor is very hard to start and it frequently trips the reset switch when getting started first thing in the mornings. Even in warm weather i sometimes have to put a heater...
2 things The check valve on the tank will not close for 100% rust parts from some metal parts in the pressure pipe metal rings can be used and give problems over time , or under voltage on the power group. are sometimes things that are hidden and not seen .
Feb 17, 2018 | Hitachi EC89 4 Gallon Twin Stack Air...
What is the tv code for Hitachi model 42PD7200
what you will want to do is go into the users guide and find the reset factory defaults option usually it involves holding a button or two while starting the device however are sometimes very different
hope this helps
Robb
Oct 03, 2010 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
I have a Hitachi compressor EC12. Sometimes when
you may have some water build up pull the cover apart look at yor pistons for build up
Jan 07, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Flashing green light
The TV is on protect mode. This happens when an internal fault is detected. Start leaving the TV unplugged overnight. This will drain power discharging capacitor and internal circuits, and sometimes can solve minor problems. If the TV still does not start , it must be taken apart and tested. Parts that commonly fail are the PSU, controller board, low buffer and sustain boards. If the TV is only 13 months old, then it is worth calling Hitachi and asking for a warranty extension or a discounted repair. Regards.
Jun 04, 2009 | Hitachi 42HDT79 42 in. Plasma Television
Hitachi 32'' lcd tv picture runs slow sometime and goes dark
go in touch wit HITACHI costumer help and service and tell them ur problem u have.....how old is ur TV?
hope u get a answer from hitachi....and good luck
Mar 12, 2009 | Televison & Video
Hitachi 65F59A turns itself off
The power supply may be failing.
Sep 02, 2017 | Hitachi 65F59A Television
- SKY REMOTE CODES
I own a One-for-All universal remote (model URC-4220), and my booklet says the setup code for a Hitachi TV is either 0000 or 0145. If these numbers do not work, then I would buy a newer universal remote. They can purchased at Walmart for less than 10 dollars.
Jul 11, 2008 | Hitachi C25-RF35S 25" TV
Grid showing on screen
You have a defective light engine and you do not have to be under warranty for Hitachi to replace this part. We just went through this and here's what you need to do. Call Hitachi's customer relations department at 800-654-7013 and tell them that you have a defective light engine. They will act like they've never heard of this problem but they have. They will give you the names of some certified dealers in your area to call. Once a tech comes out and confirms that it's the light engine, call Hitachi back and they will send a brand new light engine to the dealer and Hitachi will cover the cost of the part (cost $1500).
Here is the deal, if you're under warranty, Hitachi will cover the part and the install. If you're not under warranty, all you pay is the install. Our install cost $400. Others on this site have paid $200. Do not let anyone tell you that you have to pay for the light engine part...you do not. Hitachi has not recalled this part but they are replacing it for free. Also, deal only with Hitachi customer realations number that I listed. Good Luck
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi L32HP01 32 in. HDTV-Ready LCD TV Logo
77 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
