When i went to bed, i turned the Daewoo TV off. Then when i tried to turn it on in the morning there was no power. No lights come on but the fuse is fine.
  • Televison & ... Master
  • 17,130 Answers
A total failure can be a result of a power failure in the TV. so to check the main power which is a SMPS unit - switch mode power supply- remove plug, remove the poser section and check;
check for tips on the link below;
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on May 19, 2011
My polaroid lcd tv, wont turn on, its 16 months old, any ideas?
Try plugging it into another outlet - one which you are certain is working. If that doesn't work, you might have a bad fuse inside your TV. If that isn't it, the power supply board may have failed.
May 25, 2014 | Polaroid Televison & Video
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
II turned my tv off to go to bed but when I went to turn it on this morning it would not come on.
going to have to look inside the set, follow the power cord to the main ac fuse and see if bad or good.
Dec 22, 2012 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
Last night I was watching TV just fine. I turned off the TV when I went to bed and then tried to turn it back on this morning when I got up. It wont turn back on and I have checked to make sure that there...
Check ur power source?Tries tv unplug,replug the tv back like about an hour later.Now the tv are resetting it self back to the factory setting.The tv should work now.If still have the same problems,some how ur power supply board is causes and is not providing the tv the wright voltages anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 09, 2010 | Mitsubishi LT-40133 40 in. LCD HDTV
It won't start. Could it be the lamp?
I have a 36" Panasonic TV (manufactured in 2004) that suddenly stopped working. It was working fine up until I turned it off one evening before going to bed. The next morning, when I went to turn it on, NOTHING. No power indicator light, NOTHING. I'm a big "do-it-yourselfer", so I took off the back cover of the TV case and discovered that it was just a burnt-out fuse. It is a small "snap-in" glass fuse that should be mounted to a circuit board near the area where the main power chord enters the back of the TV. I found the replacement fuses at Radio Shack. The fuse came in a package of 4, for $2.99. Cheap fix and works great! The biggest problem I had with the fix is that the TV weighs 386 lbs., so I had to get help lifting it out and back into the entertainment center.
BK
Dec 08, 2010 | Panasonic Televison & Video
Alba 42"lcd tv watching tv it just went off,
Alba is now a product of Argos, their low cost help line number is 08456040105
Nov 18, 2010 | Televison & Video
Toshiba 57H81, power to transformer and flyback.
IF YOU REPLACED THE SAME PICO FUSE, YOU PROBABLY HAVE A BAD CONVERGENCE IC AGAIN . DID YOY SNUG UP THE IC TO THE HEAT SINK AND USE THERMAL HEAT COMPOUND ON THE NEW IC'S? ALSO CHECK SOLDER CONNECTIONS TO C810 AND C809 THE FUSE BY THE CAPACITORS MAY BE OPEN.
Jan 22, 2009 | Toshiba 57H81 57" Rear Projection...
TV will not come on.
check to see if the power cord is pluged in firmly
Dec 17, 2008 | Sylvania 6427GFG 27" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
