Question about ViewSonic VA1912wb Monitor
Hi Expert, I'm using this monitor with my desktop. You may be aware that, this monitors comes with default speakers mounted on it!!! I can't here any sound...could you please help me to activate these mounted speakers in monitor? Appreciate your early response. Thanks
  • ViewSonic Master
  • 32,281 Answers
If you have not connected an audio cable to the monitor then you cannot get any sound from the speakers.
Connect an audio cable from the audio out jack on your computer to the audio in jack on the monitor.
Posted on May 19, 2011
Are there built in speakers in my desktop?
Desktop units don't have buit-in speakers.
Will will need to purchase a pair.
Take care!
damnor01
Sep 16, 2012 | HP Compaq Presario SR1738nx-b Desktop...
My computer is a SyncMasterP2570HD i cant get any sound to come out but it is detecting sound how do i fix it
The Samsung SyncMaster P2570hd is a monitor with speakers; it isn't the computer itself. I'll assume that you are dealing with a computer connected to the monitor and not a set-top box. Make sure that Mute is not enabled on the computer. There should be an icon on the lower right hand side of a Windows desktop. If the mute is enabled, it will have a red circle with a diagonal line through it. Left click on the icon to remove the mute (change the volume or click on the mute icon). Test the monitor's speakers by connecting it to another device with known good audio output.
Next how are you connecting the monitor to the computer (VGA, DVI or HDMI)? If you are using VGA or DVI (including DVI to HDMI), you need to connect an audio patch cable (3.5 mm) between the speaker (green port on the back of a sound card) or headphone jack of the computer and the audio input jack of the monitor. The audio input jack is between the DVI and VGA ports. You can test the output of the speaker jack on the computer with regular computer speakers. Plug in the power cord (or USB cable) for powered speakers. If the free-standing speakers work, check the volume setting on the monitor with the +/- buttons to the right of the menu button. Do not press menu first, though. If that doesn't solve the problem, continue using the separate speakers. (Unless the monitor is still under warranty, it usually isn't worth taking apart a monitor to replace the speakers. You may be able find replacement parts online.)
If you are using an HDMI cable, check the output audio setting to see if the HDMI audio is available. For Windows, click on Start > Control Panel > Hardware and Sound (Windows 7). Then click on Manage Audio Devices under Sound. In the Playback tab, check what available audio devices you have. Make the HDMI the default device by right-clicking on it and selecting Make this the default device. (Other versions of Windows will a slightly different route to this panel.) You may need to restart the computer to get the audio signal on the HDMI cable after setting this. Note: not all video cards/computers support HDMI audio. If you don't see HDMI listed in the Playback devices, connect an audio patch cable as with a VGA or DVI cable, described above. Use stand-alone speakers if the monitor's speakers are bad.
I hope this helps.
(I have had the speakers fail in monitors; <$30 separate speakers are an adequate replacement for those built into a flat panel monitor.)
Jun 26, 2012 | Audio Players & Recorders
I cannot hear any sound from my Dell monitor 1702FP. Are there speakers installed within the monitor?. VGA cable is connected. When I use a spare monitor using the VGA cable the sound is loud and clear. ...
The Dell 1702FP doesn't have speakers.The specs of the Dell 1702FP are available here: http://support.dell.com/support/edocs/monitors/1702fp/en/specs.htm . (BTW neither does the Dell 1704FPT.) However, some Dell monitors can have a sound bar (speaker set-up) mounted on the monitor.
VGA cables don't carry sound. Check if a second cable (an audio patch cable is connected to the computer and the second monitor). (There are some cables that actually bundle the 3.5 mm patch cable with the video cable for convenience. (I've seen a number of DVI cables with that bundle option.) The plugs will separate into separate units at each end.
Other monitors do have speakers built in - look for a 3.5 mm audio input jack with the rest of the input connections on your monitor. There are some monitors that accept an HDMI input with a 3.5 mm audio out jack; these monitors don't have speakers and thus are enabling a daisy chain to connect the speakers to the monitor. So you do need to be careful and look for the audio in label.
You can attach a set of speakers to your computer using the audio out (look for a lime green 3.5 mm jack on the back of a desktop). For laptops or to use the front audio ports, look for a headphone jack.
I hope this helps. Please add a comment with more information about your monitor and computer for additional assistance.
Mar 11, 2012 | Computers & Internet
I have a HP Pavilliona630n and I would like to hook up speakers to this computer. My monitor is a HPS2031 and it does not have speaker inputs or outputs. What type of speakers and cables do I need to buy...
The HPS2031 monitor has a audio-in jack port behind the monitor. You just need a audio cable male-to-male to connect from monitor to the cpu. Make sure the audio drivers for the computer are installed
Jun 28, 2011 | HP Pavilion a630n (PC109A#ABA) PC Desktop
I have internal speakers on the monitor and I can't get the external speakers to work. There are no troubleshooting directions.
Try to check what type of connection you're using if its HDMI, DVI or VGA. If happens you're using HDMI it has a capability to give sound you just have to check the settings on the monitor or on the pc tower unlike the VGA and DVI you need to use speaker jack to have a sound on your monitor.
Example Pics.
HDMI connector
DVI connector
VGA connector
Hope I've helped you somehow.
AnEspera
May 08, 2011 | Computers & Internet
Hi can you help me
Yes, I"m sure some Fixya expert can help you if you describe
your problem. Please use complete sentences - like "When I turn my computer on the power light comes on and the fans start but the monitor screen remains dark." Not something like " Don't work"
Tnx
Apr 21, 2011 | HP KQ495AA Pavilion A6500F Desktop PC
Is there any way to use headphones on the HP 2159m computer monitor? possibly external computer speakers? I have a desktop computer connected to the monitor by a HDMI cable.
There is no audio output on that monitor. So decoding the HDMI into analog is out. However, the simple fix is to plug your speakers or headphones into the green 3.5mm headphone jack on the back of your computer, and change the default audio device in windows. You can use both audio cards at once for different tasks, such as having someones voice come over your HDMI cable on the monitor, while listening to music on the audio out of your computer.
If you need any help setting the audio card, let me know.
~KenjiFox
Jan 07, 2011 | HP 2159M Monitor
Dimension 8400 PC Desktop: Where do I connect the monitor mounted speakers to...
you connect the monitor's speaker lead to the speaker jack or line out jack on the sound card.
May 03, 2010 | Computers & Internet
Cannot get any sound from my Dimension 3100
Speakers are not built into the box itself. They may be in the monitor, or completely separate.
Did you get this directly from Dell, or from a third party. Dell would have shipped you speakers with it, or a monitor with speakers built-in. Purchased from a third-party you might just get the box itself.
If you have a monitor with speakers, you still have to connect the sound output from the box to the monitor.
Mar 05, 2008 | Dell Dimension 3100 PC Desktop
No sound coming from new hp monitor through windows vista
Alright, I got the answer for ya, first, go into your control panel. Click on Sounds and Audio Devices. Listed in this window should be the name of your sound card. Under that, should be Device Volume, and at the bottom, should be the Speaker Settings, click into Advanced, next to speaker volume. It should show you a diagram of a monitor with the amount of speakers it has selected shown next to it. Where it says Speaker Setup, click and then scroll down until you see 3 settings labeled Monitor Stereo, Monitor Stand Stereo, and Monitor Mounted Stereo. Whatever one enables the sound will be the one you want to stick with.
Feb 25, 2008 | Gateway Essential 500 PC Desktop
ViewSonic VA1912wb Monitor Logo
107 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
