I have a pioneer elite television. The red standby light is on, everytime I push power button it goes off. Cant get the blue light on for the tv to work. Think its stuck on standby mode. tried unplugging but did nothing.
  • Televison & ... Master
  • 17,130 Answers
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Posted on May 19, 2011
Why does my pioneer elite pro-ro6u have a red light that says standby instead of blue light which is on??
proubly just the design my kenwood has a red light for standby and goes out when turnd on
Sep 07, 2014 | Pioneer Audio Players & Recorders
SD P50A3 Q red Standby is on....will not power up.
ok sir you have defective power supply at hot side section! and the power oscillstion circuit! your unit need to diagnos to know the exact defective parts!
Oct 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
I have a Pioneer Plasma 428 XG. It has a problem that it does not start up. When I switch the power on from the mains the red LED light comes on (standby mode). However, when I try to switch on the TV (i.e...
It could be either the main or power board causing this...if your able and comfortable doing it remove the back and look for PSON on the connector legend and test the voltage on that pin, it should change when you push the power button, when I say change some sets use negative and some positive signal to tell the power board its time to come out of sleeping mode and go to work..if you see for example 6 volts with it off and it goes to 3 then the main is working or if you see 3 when its off and it goes up to 6 its also working, you want to see a change in that rail...if you see it change then the power board is bad and needs replacing
Feb 11, 2018 | Pioneer PDP-4280HD 42 in. Plasma...
Pioneer Elite. Loud popping sound and picture disappeared
Power supply board is dead.The board where the power a/c cord plug into it.Replace the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 30, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Plasma tv no longer powers up
The gas has leaked out and can't be fixed unless you pay to have a new panel assembly put in. Sorry its trash now as you can replace it cheaper now a days.
Mar 15, 2009 | Pioneer Elite PRO-940HD Television
TV will not turn on
Hey guys this one is a no brainer when you push power button AND STANDBY LIGHT COMES ON NEXT PUSH THE BUTTON ON THE LEFT NEXT TO POWER BUTTON AND WALLA IT TURNS ON
Nov 11, 2008 | Televison & Video
Pioneer Pro-118 won't turn on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine. Check all three fuses while you're in there.
Feb 12, 2008 | Pioneer PRO-200 60" Rear Projection...
Tv refuses to turn on
your tv is defected need to take in to the tech for repairs.power supply problem or related circuit.good luck
May 20, 2007 | Pioneer SD-P62A5-K TV
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
