When i plug it into my computer it only charges.
    Problem Solver:
  • 18 Answers
Please complete your problem description so that we're able to help you a lot better.
Posted on May 19, 2011
Plugged in not charging
On some devices, like my work Lenovo laptop, it'll stop and just trickle charge when the battery is at 97%. That's a feature, not a bug, designed to help avoid overcharging and damaging your battery and device. Try running on battery for a little while and reconnect the AC adapter. You should notice it's charging again. If it doesn't, post back.
Jan 06, 2014 | Intel Computers & Internet
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
My PRS-300 is not holding a charge nor syncing to my computer. Help please!
To charge a PRS-300, you need an AC-Adapter (wall plug) from a PSP console.
As for the syncing problem, you may need a new USB cord.
Feb 09, 2012 | Sony Reader Pocket PRS-300
Why do you send usb connection to charge jwin jb-th130, why not receptical plug. do i plug into computer and how long to charge?
The standard connection is a USB plug (mini or micro USB style). You can plug it into your computer or any wall plug that has a USB connector on it (the bigger rectangle shaped plug like your computer has). The USB standard is 5 volts so if it comes from your computer or a wall adapter or your car charger - as long as it is a USB connector and likely says 5 volts, they will all work the same way.
Every headset I have worked with seems to charge about 50 to 75% in 2 hours (it is ok to do a quick, partial charge). Leave it plugged in overnight for full charge (8 to 12 hours).
Jun 14, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
Trying to charge battery...red light stays on a while then goes off..turn computer on and it says battery charged..but not doing much..I know it needs 12 hr charge..do I just leave it plugged in with light...
YOU NEED TO GET THE BUTTER OUT LLET HIM ABOU 1DAY OUT THE COPMUTER AND WORK THE COMPUTER WITHOUT PLUG BATTERY AFTER DAY BUT THE BATTERY IN COMPUTER AND POWER WITHOUT PLUG AND CHARGE IF GIVE U EMPTY
Mar 20, 2011 | Sylvania G-Netbook
QUESTION; CAN MY XL GPS BE CHARGED BY PLUGGING IN TO THE COMPUTER?
Yes, you can plug your GPS device into your USB port to charge it. Your computer (if running) will assume you are connecting the GPS device to your computer, and It will start up the program for your GPS device... e.g. to update the map, backup the data, etc. You can proceed to do all that, or ignore those programs. While it is plugged into the USB port on your computer, it will charge your GPS battery. You may wish to "disconnect" the GPS device (properly), but still leave it connected ... to continue charging it.
Another way to charge the GPS device is to get a wall plug USB adapter. This way, you can charge the GPS battery without having to go through the complexity of what the computer does when you plug the USB cable into it.
Jan 02, 2011 | Tomtom GO GPS Receiver
Where do i charge my DSi
Yes youd have to buy a computer plug in. that plugs the dsi to the computer.
Dec 19, 2009 | Nintendo DSi Blue Console
The i pod is not showing that it is charging
Since it has been sitting for so long, try doing this: Connect the ipod to your computer and let it sit for about fifteen minutes. Then it should show up in your computer and under itunes. Usually, if your ipod dies completely, when you try to charge it using a wall or car charger, it will do that, just flashing the apple logo and going back off. Leaving it plugged up to the computer will allow the battery to charge just enough so that it can sync with itunes. While it is plugged into the computer and charging, it should say something like, battery very low, charging. It should work after letting it sit plugged up to the computer.
Dec 30, 2008 | Apple iPod nano
Battery is totally flat and won't charge
The USB cable was having issues with our computer. We could download the music but it would not charge. Had to buy a USB accessible charger that plugged into the wall. I suggest the Sony AC power adapter. It's a USB power supply for Sony and iPod.
Jul 18, 2008 | Audio Players & Recorders
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
