Sharp arc 260m error code H4-01? can I fix - Office Equipment & Supplies
  • Office Equip... Master
  • 808 Answers
This is a fuser error. You will need to buy a new fuser and fit it.
Posted on May 19, 2011
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Refilled the black toner for my ar-260m. but says replace toner. what do I do to reset the cartridge?
try to unplug it for a little while and plug it back in this should work let me know
Dec 23, 2010 | Sharp AR-C260M All-In-One Printer
I have a Sharp ARC 150 with a H 4 00 code
Hello sir;You may reset this error code as follow;
press "program", "interrupt", "clear", "interrupt",the display will go off, then enter "14" then press start. machine will go back to normal.
Apr 10, 2009 | Sharp AR-235 Copier
Sharp arc 270 error code l4-04
Possible bind in one or more of the developer units. Replace as needed. Sec. 11 Page 11-61 it talks about Paper Feed Drive Motor, it is the same motor as the Black Developer Drive Motor.
For L4-04 swap those two motors around to troubleshoot bad motor
Feb 03, 2009 | Sharp AR-C270 Color Copier
Error code H5 01
It means you have had 5 jams in a row in the fusing unit. Open the left side door of the copier (roll the finisher out of the way if you have one). Open the green handle on the top of the fusing unit and carefully remove all of the pages stuck in there. You can use the green wheel at the back to turn the rollers if need be. If you have no jam, then someone already removed it and you just need to reset the code. to reset the code, push P * Clear * on the numeric pad. when it says enter simulation number, enter 14 and push the Start button for black and white copies. The machine will reboot and your code should be gone.
If you keep getting jams, you may have knocked the Fuser exit sensor arm out of place.
Please don't forget to rate your answers.
Dec 22, 2007 | Sharp AR-BC260 Color Copier
Arc 260m network help?
You will need to use the Sharp Network configuration program. This should allow you to setup the printer for network printing. You will want to use 'manual' settings for the IP. Example
IF DHCP is used, you will want to switch to Manual and put in a 'correct' ip.
IP Address: 192.168.1.189
Subnet:      255.255.255.0
Gateway:    192.168.1.1
The Gateway will not be necessary if you do not plan to use the advanced functions to e-mail scans, and prints.
Sharp Network Administration software link
http://sharp-world.com/products/asia-doc/c/download/license_01.html?link=http://www.sharp.co.jp/print/document/download-e/utility/Sadmin.ZIP
Oct 10, 2007 | Sharp AR-C260M All-In-One Printer
46 people viewed this question
k24674
