Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Profile side by side 7 years old Not cold when I came home Cleaned a screen thing, round with a fan on it in the back. Where are the cooling coils. Keeps going into thaw mode 3.o lbs. Is this normal?
    President:
  • 2,468 Answers
Its either the ptc overload on the compressor thats shut down the compressor,or if the inner freezer back wall is frosted over then its the defrost heater or thermostat on the evaporator coil,the heater on these is very prone to burn out,its a glass tube heater about 12" long and the part # is AP3183311 at appliance parts pros for about $50.00
Posted on May 19, 2011
GE Profile temperature going up and down
One of four problems,
1: this box has two sensors in the freezer... one on the top of the evap and one on the bottom left side of freezer cabinet (little small round white things) in the back lower portion of the freezer. These have been know to go bad and cause this problem.
2: you have a defrost problem caused by a bad main board or bad defrost heater.
3: you have a evap fan going bad on you, quits when frig gets to right temps. in other words the fan doesn't like the extreme colds,
4: door gaskets are leaking air around doors.
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a 3 year old GE side by side that isn't cold.
Sounds like a defrost problem or an evaporator fan problem . I would suggest you have a professional check it for you to find the problem and then do the repair yourself . If the fan isn't working , probably a main control board problem and not the actual fan ,which is costly . Also , possible thermistor problem which takes experience to diagnose . Buying parts without knowing which is bad can be realy costly on GE refrigerators .
Jul 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile counter depth side by side stopped
Is the compressor coming on at all? If not a capacitor may be bad .
Jul 05, 2009 | GE GSH22JFR Side by Side Refrigerator
GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My ge profile fridge won't stay cold. the fridge is at 45 deg.
First things first - pull the fridge/freezer out from the wall, and look at the bottom.  You should see a metal coil somewhere - it probably needs to be cleaned.  Next, somewhere around the compressor (the big bulky thing in the bottom of the freezer) should be a fan blowing on the coil - make sure it is running.  That MIGHT have been the buzzing noise you describe - dirt on the fan blades or the fan hitting something.  Additionally, you can check the fan on the inside of the freezer - if it is stuck and/or not working, the air won't circulate properly, and you'll get pockets of different temperatures in your freezer.
Best of luck!
May 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator and freezer stopped making cold over night, its a GE
Try to check for Warranty protection, and if the time coverage has not yet elapsed. If it has not, try to take to service technician, if it has, then the problem is just the Coolant, a chemical liquid that when its volume is expanded, its temperature drastically drops, its called freon. Try see if you can replace the coolant. :)
Apr 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fan in freezer under ice maker won't stop running.
Hi yes the fan blade could be hitting the shield or ice, remove the fan cover & check
Dec 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Oct 13, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Ge side by side not cooling enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting,
Sep 07, 2007 | GE Profile PSS26NGS Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
96 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
