HD52W67 Hi I have a RCA HD52W67, Chassis#ITC222A. Would you be able to lookup the Power Supply Board Part Number for me. If you can also tell me where to order this part, that would be great. Thank you very much for your time.
Due to alignment required, not recommend unless you are a technician. sorry
Posted on Feb 11, 2009
Where is the supply board to replace the capacitors ?
Need the model number of the set to help with the issue, But usually there are three caps on the deflection board if you have the ATC221, ITC222 0r ITC222a chassis rca
Mar 23, 2012 | RCA Televison & Video
My RCA R52WH74 chassis # ITC222A wont turn on. The green power light comes on for about 10 seconds then shuts off. No picture, no sound. How do I fix it? Buying a new TV just isn't in out budget!
That model is famous for having issues with the deflection board failing. Replacing the deflection board should solve the issue. You can get replacement deflection board for the ITC222A chassis from www.tvrepairworld.com under the RCA circuit boards catagory.
Aug 05, 2011 | RCA R52WH73 Projection Television
Part number and price for main board
Thats the ITC222A chassis the deflection board youre needing is no longer available new, But you can get your board rebuilt at the following link and the boards are fully guaranteed for 6 months after rebuilding them.
http://servicemanuals.vstore.ca/
Aug 26, 2009 | RCA HD52W56 52" Rear Projection HDTV
Will not fully come up.
2200mfd cap on the HV Power Supply board about mid way on the chassis, if it is bulged at the top, REPLACE IT.....Let me know! Also, cold solder joints on same...
Feb 03, 2009 | RCA D52W19 52" Rear Projection Television
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
Part?
Go to Tritronics or Union or Andrews electronics for RCA parts. They all have websites.
Jun 08, 2008 | RCA HD52W59 HDTV Projection Television
Service Manual
You can get the service manual emailed to you at the following link. The manual is listed under Thomson the ITC222 chassis is a thomson which is RCA It cost 12.99 but they provide free on line tech support to help you with your diagnosis and repair and they also sell parts with free installation instructions.
Apr 13, 2008 | Televison & Video
Convergence
Okay, usually the parts that go bad to make the convergence option drop from the menu are the following. Fusible Link (FL1231) Diode (DP1231) and capacitor ( C1230) the numbers in parenthesis are the actual component locations on the board. These items fail causing the set to think its a direct view set instead of a projection unit.
Tv will not power up
Flyback transfromer is bad,part number 259296,part is around 60.00,you might find it at mcm electronics,phone number is 1-800-543-4330
Mar 28, 2008 | RCA HD52W59 HDTV Projection Television
Convergence
Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link:
Feb 21, 2008 | RCA HD52W66 Projection Television
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
