Question about Parker Pen 30316 Ball Point Ink Refill
Parker duofold ball point pen. How do I open it to put in a new refill cartridge/
Writing tip on pen will not come out when I twist the bottom
Pull up the top of the pen (with the clip). Remove the refill cartridge and examine it. If it is not damaged put it back in and fasten it in place by twisting. The cartridge comes with a colored plastic top. The cartridge must be inserted with the plastic on.That top must not be removed.
Nov 09, 2013 | Cross Century II Classic Ball-Point Pen
Pen won't write though plenty of ink
There are a couple reasons a pen refill won't start writing right away. The first thing to check is the tip--often there is a bit of glue or plastic over it in order to prevent leaking.
If that doesn't work, then try one (or both) of the following two methods:
1) Place the refill (but not the tip) in some warm water. Heat will allow the liquid in the gel pen to become thinner and flow more naturally.
2) Hook a rubber band around the middle of the pen, using tape to ensure safety, and wind the pen while holding the rubber band on either side of the pen. Make sure the cap is on the pen. When the rubber band is tight, when you pull straight out on the rubber band from both sides of the pen, it should spin very quickly. The centripetal force will cause the liquid in the pen (at least half of it) to move toward the tip.
Make sure you fasten the rubber band to the pen with tape or something similar; otherwise the pen may go flying off at someone nearby. Also, again, make sure the cap is on to prevent any ink spraying out--this is unlikely in a gel pen, but it could happen.
Jun 13, 2011 | Sanford UniBall Gel Impact Rt Retractable...
How do you refill the black HP 940 ink cartridges? Where is the hole?
While "Solution #1" is true for the older cartridges like the 96 and 57 (I have filled many), the 940 is completely different.
First of all you turn the cartridge upside down, cut the label in between the 940 and the colored rectangle. This simply allows you to pop the cover off (it will still be held by the back label).
Once open, you will see a stem with a silver ring on top, an oval black rubber plug, and the refill hole with a very small rubber ball plugging it. To refill the cartridge you must get this small rubber ball out. You can you a sewing needle or some other sharp object. Be careful not to damage the plug too much - you must put it back in and it can not have a hole throught it. You fill the cartridge through this "port" once the ball has been removed. Then you put the rubber ball back in - use a ball point pen to push it in so you do not damage it.
If you damage the ball, you can purchase more, but obviously you cannot use this cartridge while you are waiting to get a new ball.
May 24, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Tried to install a refilled ink cartridge. Then
The printer working does not depend on its cartrage... Cartrage is just like ink in ur pen... If the nib of ur pen breaks then u cant blame on ink... Check whether the gare of ur printer moves if its nt then there is some problem in gare shifting ic or the rotator machine check it by giving it to some computer service shop
Aug 03, 2009 | Office Equipment & Supplies
Won't play
Only one of two things. either a bad cartridge or your transport has given up. Slide open the cartridge door and look for a small inset dimple below the cartridge, it's a reset. push it with a ball point pen and hold for 3 seconds, the unit will reset. if you have another cartridge try it, if not, go to any car audio dealer that sells sony and see if you can try one of theirs to try. Also, these units are notorious for scratching CD's. If you have had the same discs in there for a while pull them out and observe the scratches in the discs. You can improve their ability to be played by using liquid car wax on the disc itself (just a dab is all it takes) and wipe clean with a microfiber towel. Hope this helps. If not, it needs to be serviced by a Sony service ctr. They will put a new transport in it. $100-$150 repair.
May 24, 2009 | Sony CDX-565MXRF 10-Disc CD Changer
Can I refill the original ink cartridges on my HP Officejet Pro 7500 Series Regards Dontacho
Step 1) Put the cartridge on some paper towels in an area where you can tolerate a spill such as a sink. Be sure that you are wearing old clothes, since the first time you fill the cartridge, you will probably get some ink on your clothes and hands. You may wish to wear rubber gloves if you don't want to stain your hands. I also don't recommend refilling as a family project. Step 2) Look at the cartridge. Near the bottom of the cartridge you will see a horizontal break line in the plastic where the two parts of the cartridge snap together. Step 3) Using a sharp knife or scissor blade, cut the label on the front of the cartridge along the line where the two parts of the cartridge come together. Step 4) Using a knife,screwdriver, or just your hands pry the cartridge open along the line. Let it hang by the backside label. Step 5) The exit port is the point where the ink comes out of the cartridge. It has an obvious stem. Place this stem to your right. Step 6) You will also see a rubber oval-shaped bulb. To the left of this bulb is the fill hole. You will see a small ball in this hole. Stick a pin or the end of a sharp knife into this ball and pry or lift it out of the hole. (Saundra recommends a sharp steak knife. (*** Don't stab or cut yourself!***) Don't lose the ball! Step 7) Fill your syringe bottle with the appropriate ink. You'll need about 30 ml (1 full syringe bottle) for the regular cartridges, about 75 ml (2 1/2 syringe bottles) for the high capacity black cartridge. Step 8) Insert the needle 1/4 to 1/2 inch (5-10mm) into the fill hole. Be careful not to puncture the bag, especially if you have a sharp needle. Step 9) Inject the ink into the opening. Step 10) Tilt the bag so that the opening is at the top. This will let the air bubble up and out. Step 11) Using the syringe, suction about 1 ml (1/4 teaspoon) of ink and air frothy mixture out of the top of the bag. Step 12) Inspect the ball. If it has been damaged, you should use a new ball or the damage may cause a slight leak. (We have additional balls for sale.) Step 13) Replace the ball in the cartridge. Saundra says, "The tip of a retracted ball-point pen is ideal for this." Step 14) Turn the cartridge upside down (stem down) and gently squeeze to check for leaks.
If you see a leak there are three possible problems.
1. The bag inside the cartridge has bursted or is punctured. There is no fix for this: the cartridge is dead.
2. While refilling you allowed ink to escape and get on the white collar surrounding the exit port, bulb and fill hole. The ink has now leaked between the bag and the sides of the cartridge. Even though this is usually only a small amount of ink it will act like you poured an entire pint in there! The solution is to remove the bag. Please do this over the sink. As you are looking at the cartridge you will notice that the sides are long ovals. Hook your thumbs inside the ovals and pull as if though you are going to pull the cartridge apart. You will see two plastic tabs. Release one and then the other. Using the bulb frame as a gripping point, pull straight up and lift the bag. This will be messy. Rinse the outside of the bag and the inside of the cartridge shell. Try not to get water on the copper chip while you are working. Using an old towel or a paper towel, dry off the bag and dry out the inside of the cartridge.
3. You have not pushed the ball into the hole securely. Push it in again and wipe up the excess ink. Squeeze the cartridge to make sure you have it sealed tightly before putting it back in the printer.
If there are no leaks insert your cartridge into the printer and print.
The light on your printer warning you that the ink is low will remain ON. This is normal. Do not panic: just see if it prints
Apr 23, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
My Cross pen fell on the floor and won't work
was it a ball-point or ink pen tip???
if it is ball-pint. then all you have to do is get a refill cartridge from any of the office supply store or specialty shop.
if it is a fountain pen tip, then you have to send it back to cross for repair.
Feb 09, 2009 | Cross Pen Computers & Internet
Parker Pen 30316 Ball Point Ink Refill Logo
440 people viewed this question
Top Parker Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Parker Office Equipment and Supply Expert? Answer questions, earn points and help others
