Question about Seagate Momentus 5400.6 (ST9250315AS) 250 GB SATA Solid State Drive (SSD)
Seagate Momentus 5400.6 500GB ST9500325AS external drive, when plugged in, starts beeping for a short while then Windows 7 detects it, but can't initialize it in the Disk Management screen. I do not hear drive spinning. It was working yesterday, nothing unusual happened. I had also properly removed via "safely remove hardware" option. I've got all my data on it - is the data gone?
    Top Expert:
  • Seagate Master
  • 26,230 Answers
If you try to initialize it, you will destroy your data.
Try another PC or better still a Mac. You may be able to read it but it should spin up otherwise it could be the usb connector.
Posted on Aug 06, 2017
shadow5599
  • 51 Answers
SOURCE: Seagate momentus 3 60gb problem
What software did you use for the cloning?
Ghost is the preferred method.
Be sure to choose a disk to disk clone, not a partition clone.
It sounds like you may have created a 20G partition and left 40G unallocated.
Partition Magic may also take care of the problem, if you have access to a copy.
Posted on Oct 16, 2007
  • 9 Answers
SOURCE: Seagate Momentus 4200.2 120GB
Some laptop manufacturers use the 4 pins to the side of the data connection to force Master / Slave. Do you have a jumper shorting 2 of these pins? If so, remove the jumper and try it again in your external caddy. Had this problem 2 weeks ago with a Toshiba notebook having the Blue Screen of Death. Removed the jumper and then the disk worked perfectly!! Strange but True.
Cheers
Tim
Posted on Dec 13, 2007
  • 7 Answers
SOURCE: hard drive has a yellow ! in disk management
if you are using notebook, this is possible the solution to crop with,
http://hk.myblog.yahoo.com/xiao-laba/article?mid=1861
Posted on Mar 23, 2009
  • 8 Answers
SOURCE: disk management does not see working hard drive
Are the Hard drives setup as master & slave ? (plastic jumper on Hard drive at cable)..... is the Hard drives connected on separate ide cables... if they are ide drives ?
Posted on Mar 30, 2009
  • 29 Answers
SOURCE: External Hard Drive Beeps and Doesn't Connect
this is very common in the 7200.10 series,there is the bug of the firmware,so u must update ur fw and the your drive will be detected by the bios and pc.
there is many cases in this website:www.salvationdata.com/blog
Posted on Apr 21, 2009
Seagate ST91430AG not detected in Windows 7
people solved this same problem for both windows 32 and 64 bit hope i helped somewhat
@ lbsign fucknikco
^twitter (no spaces)
@ switchblades and *******
^instagram (no spaces)
http://www.tomshardware.com/forum/869-63-seagate-freeagent-windows
Nov 02, 2012 | Seagate ST91430AG - 1GB 4.5K IDE 3.5""...
Seagate external drive Momentus 5400.3 is not recognized in my Win 7 laptop.
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jul 08, 2011 | Seagate Momentus 5400.3 Hard Drive
I pulled the seagate 2.5"
When you use external adapters to plug drives into USB ports the drive needs to be set for mast not slave. The internal drive is one one channel and external drive is on a different channel so neither drive is a slave, both are masters with not slave drive present. Try removing the jumper you installed and try the drive, it should be seen because all windows XP or later do not need drivers for USB drives.
I hope this helps, if so please rate my solution.
BuddyMc
May 06, 2011 | Seagate Momentus 4200.2 100 GB Hard Drive
I have placed this hdd into an external case to use as a portable drive but when i plug it in to my laptop (mac book pro) it starts to beep. Windows is installed on the portable drive i was hoping to plug...
at ATA hard drive there is no master or slave, if you want to make it master connect it at ATA slot 1 at mother board, and if you want to make slave connect it at ATA 2 at motherboard
i hope this helpfull
Jan 19, 2011 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
I was given a seagate momentus 5400.3 hard drive and i want to use it as a external usb drive i bought an external case for it and plugged it into my laptop, it see it but in device manager i am getting a...
Try connecting it to a different computer.
EXACTLY what error-message do you get?
When you double-click that entry in Device Manager, and click "reinstall drivers", allow Windows to connect to the Internet to look for a device-driver for the USB-to-disk-drive adapter (no device-driver is needed for the disk-drive itself).
Dec 11, 2010 | Seagate Momentus 5400.3 Hard Drive
Whats the biggest ram I can put in my HP G7000 note book to replace ST9120822AS which is currently in my machine.
Currently the largest drives for notebooks are are
Hitachi Travelstar 5K500 500GB
Seagate ST9500420AS Momentus 7200.4 500GB
Seagate ST9500420ASG Momentus 7200.4 500GB
Seagate ST9500325AS Momentus 5400.6 500GB
Samsung Spinpoint M7 500GB
Samsung SpinPoint M6 500GB
Nov 13, 2009 | Seagate Momentus 5400.3 ST9120822AS 120 GB...
I need the driver for your momentus 5400.2 hard drive
U have install all drivers properly in ur hard drive it can be work properly
Jul 11, 2009 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
Seagate Momentus 5400.6 (ST9250315AS) 250 GB SATA Solid State Drive (SSD) Logo
467 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
