Question about IBM (33P0825) Motherboard
The heat sink is heated when we start the pc.The fan is moving in normal speed.Then after few minutes the PC autometicaly get stopped.
  • IBM Master
  • 32,281 Answers
Your CPU fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust.
Posted on May 19, 2011
Frozen screen when hot
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer atleast two hour a day.
Most of the time, PC starts running slow and freezing by lots of reasons. Corrupt registry, unnecessary applications, as well as too many start-up items would be the major reasons contributing to this problem. Many PC users simply utilize PC yet never consider how to maintain and optimize PC performance. I would suggest you to download any reliable program to fix registry, to manage unnecessary applications & start-up items like am using Reginout since 2011. Many programs are available in market which can perform these steps, but don't believe on free products. Now its up to you. :-)
Good Luck.
Nov 12, 2013 | Dell Latitude E6510 Laptop
Overheating issues with laptop
Following are the reasons for overheating, just take care of these things::
Use High Speed fans
Make sure your dint restrict the speed of CPU fan.
Use proper ventilation in your room
Shut down your computer at least two hour a day
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of overheating
Sep 23, 2013 | Toshiba Satellite Computers & Internet
Sony VAIO VGC-RA810G Desktop overheats and freezes.
- Make sure your dint restrict the speed of CPU fan.
- Use Additional Cooling Units
- Shut down your computer at least two hour a day
Finally i will suggest you to get system utility program like PC Fresher. because it is a very useful tool that cleans your computer of temp files, history and cookies. Its also used to fix any registry errors that cause of overheating
Sep 16, 2013 | Sony VAIO PC Desktop
When i turn on my pc all seems well for about 5 secs then the heatsync fan and the tower fan stop moving and at that point my video card fan starts spinning 5 times faster what would cause this
1. Stop Overclocking your CPU
2. Make sure your Heat Sink is placed properly above the processor
3. Clean the Processor fan, Heat Sink and other peripherals
4. Use High Speed fans
5. Use CPU Heat Sink Paste in the processor
6. Make sure your dint restrict the speed of CPU fan.
7. Use Additional Cooling Units
If such problems occurs due to internal errors then i would suggest to perform a full computer scan with pc optimization tool like PCFresher for an instant fix.
Feb 18, 2013 | Compaq Presario CQ5110F (NP185AA ABA) PC...
The computer powers up as normal but fan speed incrases to extremely high speeds and just shuts off after about 10-15 min max
sounds like a heat sink problem you will need to get some heat sink paste remove your heat sink (static guard required) put a small dot on top of your CPU and replace heat sink should fix your problem if not let me know
Nov 21, 2012 | Gateway GT5674 Desktop PC
Overheat and shuts down
  • Stop Overclocking your CPU
  • Make sure your Heat Sink is placed properly above the processor
  • Clean the Processor fan, Heat Sink and other peripherals
  • Use High Speed fans
  • Use CPU Heat Sink Paste in the processor
  • Make sure your dint restrict the speed of CPU fan.
  • Use Additional Cooling Units
Also use a system utility tool like PCFresher to fix windows errors.
Apr 25, 2012 | Computers & Internet
My hp dx2000 starts but stops but the chassis fun stop running just after 5 minutes. I tried to change RAMS, HHD, Power supply, fun but no avail. Sometimes it stops immediately it tries to load Windows...
The heat sink may be clogged with dust and ifthe BIOS temperature sensor controls the fan speed then it may be compensatingfor the reduced cooling by the dust build-up.
Jun 01, 2011 | Computers & Internet
My hp media center m7160n computer powers up, has a definite fan sound, normally the fan sound diminishes and the computer boots up. For the last several months, the high speed fan sound would not diminish...
How did you clean it?
The last one I worked on had the fins of the Heat sink totally blocked with dust. This will make the fan scream trying to push air thru the heat sink to cool the processor. If it isn't cooled it will shut down in short order.
You must BLOW it out. Use a pressurized air can. Better if you have a compressor with a nozzle.
The other issue may be the interface between the CPU and heat sink is defective. Heat sink moved or become loose.
Of course by this time the processor could be dead also.
May 17, 2010 | HP Computers & Internet
After moving PC it won't fully boot
There is a possibility that something has shook loose during the trip to your new home.
You will have to take the side panel of the tower and check the CPU fan and heat sink to make sure it hasn't become loose or fallen off. Also check all the connections regarding the hard drive cables.
It is most likely the CPU fan and heat sink as when the processor reaches critical temperature it will shut down in a very short space of time.
Also give the unit a little time to settle down first.Leave it to settle for a couple of hours.
Regards.
Feb 25, 2010 | Computers & Internet
4600 Sluggish Boot Up
sounds to me like a failing psu, you may need to test it with a psu tester if you have one available, if not any local pc repair shop should have one
Oct 31, 2009 | Dell Dimension 4600 PC Desktop
IBM (33P0825) Motherboard Logo
2,139 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
