Question about Linksys Wireless-G WRT54G Router
LIMITED OR NO CONNECTIVITY
When i connect my computer the the modem directly the internet works perfectly, but when i connect it to the router i get limited or no connectivity. It has been working fine for the longest, but i all of a sudden have this issue. Also when i attempt to go thru the linksys setup process again, I get stuck at the part where i pick my router from the list. The "NEXT" button just won't work.
  • 298 Answers
The setup will not really work because of the message that you are getting. LImited or no connectivity means that you computer recognized the connection but its not getting an ip address to the router. Have you tried turning off the router and leave it off for a minute or two and see if you resolve this issue? Is your power light solid green right now?
Posted on Aug 14, 2008
I have an Emachine t5226 and have several external drives, a modem (speedstream 5100), and a netgear router attached. I was moving the externals, modem and router to a different area. I shut down...
Hello, Unfortunately, ISP techs often try to put blame on their clients equipment as much as possible. If your computer is showing limited connectivity, then this means that it is able to successfully connect to your wireless router, meaning that its probably not your adapter. Limited connectivity usually is a sign that you cannot reach the internet. This could be caused by multiple issues. In order to isolate the problem, try connecting your computer directly into your modem using the cable from the wireless router. If you can connect to the internet, then it is a configuration problem with your router. If not, then it is something with your connection to your ISP, in which case you need to call your ISP back and explain that situation. If you do happen to connect to the internet, then please reply, and we can go from there.
Feb 17, 2011 | Computers & Internet
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
For no reason, my HP laptop stopped working the internet. It works perfectly otherwise. I hard connected the laptop directly to my wirelessouter as well as my modem, still it will not connect to internet.
Connectivity issues can be many.
I would start my first rebooting the main modem.
Once that is up, reboot the wireless router.
Once that is uo, reboot the laptop.
Try to connect.
If that does not work, eliminate the wireless router and connect the laptop directly to the modem via Ethernet cable and reboot the computer again and see if it works. If it does, then it is something with the wireless router. If it doesn't, i would contact the provider so they can verify that they can see your modem on their network. If they cannot, they will advise you further (hardware/cabling issue). This is all assuming that nothing has been changed on any settings of the laptop, router or modem.
Jul 21, 2010 | HP Pavilion dv6000z Notebook
Router says limited connectivity
Not a lot of info to go on, but I'll give you my thoughts on it. In my experience, limited connectivity indicates the modem isn't connecting up to the internet. You can reset the modem by unpowering it for a few seconds, then seeing if it will connect, but I'm sure you've already tried that. Could be a faulty modem, but I doubt it. Chances are there's a software incompatibility issue between the modem and the wireless card. Was the zonet working with the card before? If it was, you might have to go into Network in control panel and delete the linksys connection, and have windows redetect the Zonet. Sorry, all I can think of, not a whole lot of experience in this arena, and my routers always worked. Maybe someone will have had the same problem and know the solution, that would be the easiest way to go, of course.
Mar 25, 2010 | Zonet ZSR0104CP (zsr0104cp) Router
No connection, cant install the software
You said that when you connect the computer to the modem, you get limited or no connectivity. make sure that your computer will be able to go online when you connect it the modem directly.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 07, 2010 | SMC Barricade 7004VWBR Wireless Router
LImited or no connectivity on wireless router after reset
hi
go to the router wireless settings and check to see if the wireless connectivity has been disabled as a part of default settings
cheers
Pls rate if this was any help
Jul 04, 2009 | Microsoft Wireless Network Adapter Xbox...
Router problem
Hi .
First who is your service provider?
Can you connect to the internet if you directly hook your modem to your computer.
1>If so connect your Modem to your router on the colour code slot on the router which says modem
2>Connect a cable from the router to your computer
3>The lan light on the router should be turned on
4>Check wether your lan says connected . To check that click start-> control pannel -> network connections
5>If it says connected try internet explorer settings
6>If it says limited or no connectivity
Click start ->run -> cmd->ipconfig
7>It should say ip address as : 169.254.x.x.
8>If so type ipconfig/release
9>It shoul say ip address: 0.0.0.0
10>Type ipconfig/renew on command promt
12>Disable and enable lan
Let me know if this helped and also if you dont what kind of messages you get .
Mar 02, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I have had a wireless dynex router for awhile and it has been working fine using wireless then when i plugged in my computer and xbox 360 to the router it has made the computers using the wireless internet...
it is getting limited or no connectivity because it is actually not connected even though it shows.the best resolution is that change your entire wireless settings and then connect all wireless devices like computer and xbox 360 again it will connect.I use to do the same when i use to work for netgear.
that will fix..
Jan 04, 2009 | Dynex DX-E401 Router
Linksys Wireless-G WRT54G Router Logo
199 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
