Question about Kenwood KDC-MP208 Car CD/ MP3 Player
What colors are ignition and 12 v - Kenwood KDC-MP208 Car CD/ MP3 Player
    Problem Solver:
  • 11 Answers
Ignition wire for the radio is RED.
The constant 12v is YELLOW.
BLUE is the remote/power antenna.
ORANGE is for the dimmer.
PURPLE pairs are right rear speakers.
GREEN pairs are left rears speakers.
GRAY pairs are right fronts and
WHITE pairs left fronts speakers. Hope this helps.
Posted on May 19, 2011
I have a 1990 Pontiac Firebird.My problem is the engine will not turn over. It's not the Battery, ECU, starter,or the wire that is hooked to the starter. What else could it be.
There are 2 wires hooked to the starter. One from the battery and one from the ignition switch. the small (ignition) wire has a fusible link in it. Check voltage on the ignition side of the link(12 volts), then on the starter side. Less than 12 volts. replace the link with the same color.
Aug 13, 2015 | Pontiac Cars & Trucks
How to replace a factory ignition switch t universal awitch
I think you can get a wiring diagram from the internet. or you can use a ohms meter and volt meter to help check the wires out to see where the go or come from, always use the colors of the wires to help check they are coming from or where they are going to. You really need to find a friend with some knowledge to help you. just remember that you have to a 12 volt line coming in, 12 volt going out #1 to starter #2 to the ignition coil #3 the fuel pump. If you get that right if will at least run. use the color codes to trace to each thing you want to use. GOOD LUCK Jerry
Jul 05, 2014 | 2006 Pontiac Grand Prix
Need to find hot wire for installing radio in 1995 Mustang
get i cheap test light there should be one with 12 volts all the time that should be the memory for radio then turn on ignition to find 12 volts for radio when ignition switch is on black is usually ground there might be a pink or purple or blue wire for power antenna if needed then trace speaker wires if yo dont know on new radio get a manual
Mar 27, 2014 | Shoprider Health & Beauty
Hello... can u help me about the wire code of my car stereo? model pioneer keh-p3750 thanks... ianf
EIA color codes are universal codes:
red +12 Ignition/accessory power on when ignition is on or in accessory
yellow +12 memory always on evern with ignition off
black (-) ground
blue (+12) power antenna
Blue/white (+12) power amp turn on
orange (+12) illumination
orange/white Dimmer
Gray (+) right front speaker
gray/black (-) right front speaker
white (+) left front speaker
white/black (-) left front speaker
purple (+) right rear speaker
purple/black (-) right rear speaker
green (+) left rear speaker
green/black (-) left rear speaker
Jun 20, 2011 | Car Audio & Video
Hooked up a Viper 5301 in a 2004 Nissan Murano. The problem I'm facing is that the unit is only programming when the vehicle is started and running, instead of programming after turning the ignition on...
It sounds like you have your ignition and starter wires reversed. The remote start programs when the ignition wire sees 12 volts and then loses the 12 volts. If you have the remote starts igniton wire on the trucks starter wire then that is why you can prgram it when you start it only... cause you get 12 volt only when the truck cranks and then loses the 12 volts once it is runnng. You may have the right colors from the remote starter correct but check to see if maybe from DEI they have the wires in the wrong positions.
Jan 20, 2011 | 5301 Responder LE 2Way Remote Start and...
Parrot ls3200 displaying goodbye
Good bye appear when the car kit switch off. Then suppose to be in relation with the question of the 12 ignition. If it doesn't disconnect of switch off in relation with the car, maybe the kit has a 12 DC and not an ignition connected.
If you can disconnect the power supply of the kit, just do it, and it should normally coming back to the main screen.
Mar 20, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
Hi,my 96 toyota corolla did not have a digital clock so i bought one off ebay, it has four wires coming out of it do you know were they go? Thanks
one 12 v feed permanant ,one earth ,one light feed and one 12v switchable from ignition switch to make it light up when ignition is turned on --- i think ??
Mar 15, 2010 | 1996 Toyota Corolla
LOOKING FOR COLOR OF WIRE TAKING POWER IN TO THE RADIO.IT IS A KENWOOD KRC-X858
red is the 12 volt power line. yellow is the memory line(constant 12 volts) . small red wire is the switchable 12 volt line that only has 12 volts when keys in ignition
Nov 17, 2009 | Car Audio & Video
1990 explorer color codes for ignition harness
your looking in the right place. stop at a body shop or prts store and ask them witch number or letter it is.they will be able to tell you or show
Oct 21, 2009 | 1991 Ford Explorer
I need the wiring diagram to install an aftermarket dual stereo in a 1996 chevy lumina
first take out the stock head unit, after the colors of the wires originally from the car is usually red black yellow orange blue or gray, blue or gray w/ stripe, and purple or green, and purple or green w/ stripe. the head unit should have a power on it for the speaker wires those are the only tricky ones. color with stripe is negative. yellow for +12 black for -12 ground and red is for ignition, turn the radio on with ignition on. purple is usually rear and blue is usual front
Jul 26, 2009 | Dual Car Audio & Video
Kenwood KDC-MP208 Car CD/ MP3 Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
