Question about Car Audio & Video
Need to know how to instal what the specs are all positions of wiring diagram basically also the watt of the amp
  • 2,098 Answers
To assist you further with an expert, please re-post your problem but this time indicate the brand and model no. of your unit.
Jdvillanueva
Posted on May 19, 2011
I need a diagram for the lighting harness and list of what each wires controls. i also need a list of the colored wires to determine what wiring effects. my dashlights are out.
It may be helpful to know the make of the vehicle, year, model, engine????
Free Automotive Wiring Diagram for ALL Make & Model ...
www.wiring4cars.com/
Free Automotive Wiring Diagram in Full Color for ALL Cars, Trucks, Vans and ... who just need to trace down one circuit (i.e. radio wiring diagram, a/c circuit, ...
How To Wire Fog And Driving Lights Harness Wiring Diagram
www.accessconnect.com/fog_driving_lights_wiring.htm
Position the lamps at an equal distance from the center of the vehicle and as far apart as ... Note: This is a general wiring diagram for automotive applications.
Automotive Wiring 101 - OnAllCylinders
www.onallcylinders.com/.../wiring-101-basic-tips-tricks-tools-wiring-veh...
Dec 5, 2013 - Automotive Wiring 101: Basic Tips, Tricks & Tools for Wiring YourVehicle ... This chart can be used to determine proper wire gauge. First .... A factorywiring harness includes the necessary wiring for standard electrical ... The gauge youneed depends on the current draw of the accessory and the wire length ...
Jan 23, 2016 | Cars & Trucks
Can someone please show me how to wire my subs to amp.. i have a 2600 watt planet audio 2 channel amp (2 ohm stable) and my subs are soundstream tarantulas t4 12s 900/1800 watts total. they are 1 ohm subs...
for your subs and amp the best way would be for the speakers to be wired in series1ch (mono or bridged)to have a 4 ohm load to your amp stable at 2 ohms
see pic for wiring diagram for 2 1 ohm dvc subs wired in series.
you will need more than one speaker wire for wiring the subwoofers coils(positive & negative terminals) together
hope this helps :~)
Mar 03, 2014 | Car Audio & Video
I have a orion xtr 2150 and a hcca 10.4 what is the best way to wire this combo?
Hello. Quick answer...bad sub and amp combo due to fact that your sub needs a lot more power than this amp can produce (I'll explain later). But here is how you can do it: You can wire this dual 4 ohm sub in parallel or series. Parallel wiring would be to wire two the positive terminals on the sub to each other and wire two the negative terminals on the sub to each other. Thus wiring down the sub to 2 ohm. This what the amp would see. Series wiring would be to wire the positive and negative terminals on the same side of the sub to each other. Then wire the positive and negative terminals on the other side to the amp. Thus wiring the sub to 8 ohm. This what the amp would see. Illustrations can be found here: http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=42#results
Your sub specs are 1500 watts rms (how many watts your sub needs to operate efficiently or its minimum requirement. It has the a peak wattage at 3000 watts that it can accept in short duration. Your amp can only produce 300 to 600 watts at 2 or 4 ohm respectively. So you would be greatly under powering the sub which would produce a weak unfulfilled sound. You need an amp that produces a true 1200 to 1800 watts rms. There is a great selection out there.
Sep 01, 2012 | Orion HCCA 10.2 Car Subwoofer
Need help wireing sub
Is the speaker a dual voice coil speaker? If so you can wire it up a couple of diferent ways, go to rockfordfosgate.com they have a woolfer wiring wizard that can show you the different ways to wire for 8 ohm.....4 ohm.....2 ohm....and 1 ohm...I would figure out how to get the most power out of the amp in mono mode, take that ohm load from there and see if you can wire your speaker to match it.
Oct 08, 2009 | Car Audio & Video
I need to install a power converter in my truck.Can any one help me with the basics? Please get back to me. Keith
What is it exactly that you want to accomplish? It looks like this unit is powered by the electrical system of your truck, but if it indeed can provide 2500 Watts of output power, its input demand from your truck electrical system will be in excess of 200 Amps!!! You'll need some pretty hefty wiring to support that type of demand, and I doubt if your alternator can put out that amount of current.
Are you sure you want/need to do this - and run it off your truck electrical system?
Sep 22, 2009 | Xantrex Technology DPS350KB 2500-Watt...
Bridging amp/sub
wire speakers in series google it to find diagrams
Jun 30, 2009 | Car Audio & Video
DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
May 10, 2009 | Visonik V900XD Car Audio Amplifier
Amp issues
i myself would run a parallel bridged ciruit. basically run the speaker wires one positive on the right speaker side and one negative on the left side.
thanks
tom
Dec 23, 2008 | Car Audio & Video
Bridge subwoofers
Without looking up the individual specs of your speaker and amp, I'll offer a few basics when it comes to bridging an amp.
Most important...find out what impedance (ohm) that your amp can handle bridged!! If you go below this rating, you will run the risk and most likely eventually overheat and short circuit the amp. You must also know the impedance of your sub (which can come in a variety) to be able to match them. Depending on this impedance match-up, it may be less beneficial to bridge the speaker to this amp. For example if there is an impedance mismatch you'll either get less power from the amp or short circuit the amp. If you know these I can help you come up with the best solution.
If you know bridging is the best option, then you'll have to know which terminals on the amp to use in order to bridge. This is how it normally works. On a 2 channel amp...you would normally take the positive from one channel to the positive on the speaker, and the negative from the OTHER channel to the negative on the speaker...and this is how you bridge the amp. The other two channels would remain UNCONNECTED. BUT!!! you have to make sure you use the correct 2 channels...it varies from manufacturer. But take heed not overload the amp...and not to overpower the sub. There are a few different ways that you can configure the subs if you find it beneficial to bridge your amp, these would take long to explain and would depend on the impedance of your subs and specs of your amp...these wiring configurations is how you match the impedance of the speakers input to the amps output (and is very important to do correctly) Look up "parallel and series" wiring configurations. Let me know if this helps, or if you need further help. Find out the impedance of your subs and the specs of your amp and i'll be able to assist you more. Hope this helps.
Mar 27, 2008 | Car Audio & Video
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
