Question about Lenovo IdeaPad Y510 Notebook
How to disassemble Lenovo Ideapad Y510? - Lenovo IdeaPad Y510 Notebook
  • 3422 Answers
SOURCE: How to uninstall Vista and load XP in Lenovo Y510 Ideapad
You can have a look HERE what microsoft says about this error.
You''l need Windows XP SP2 to support a PCI-Express graphics card.
If you are using only PCI-Express graphics card, the only choice is to boot from the complete edition of Windows XP SP2.
If you intend to install with Windows XP or Windows XP SP1 and then use the upgrade kit of SP2, please disable PCI-Express in BIOS before starting the installation.
Under this circumstance, only PCI graphics card can help you monitoring the installation process at this stage. Then, upgrade the version to SP2. After upgrading is successfully completed, you can enable PCI-Express and start using PCI-Express graphics card.
Goodluck.
Posted on May 23, 2008
Geekman
  • 32281 Answers
SOURCE: replace keyboard on Y510
The keyboards on ThinkPads are easy to replace.
On the bottom of the laptop there are screws that hold the keyboard in place (possibly 3 or 4 screws). These screws can be identified by the tiny keyboard symbol next to these screws. Remove these screws, you need a small Phillips screw driver. You can now lift the keyboard off, you may need a small flat screw driver to lift it off. The keyboard is attached to the motherboard by one or two ribbon cables, they are held in place by slide catches, slide these catched to release the tension on the ribbon cable/s so you can withdraw the ribbon cable/s.
When you insert the new keyboard make sure the cable catches are in the released position before you insert the ribbon cable, insert the cable fully home and press the slide catches home to lock the ribbon cable to the motherboard.
At this stage I suggest you power up the laptop and test the keyboard to see if it is functioning correctly. If is not working properly, then the ribbon cable/s may need reseating again. When all is OK now fix the keyboard in place with the screws.
Posted on Mar 08, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Disassemblly of the case of a LENOVO Y510
Well, I have been unsuccessful at getting a good look from a service manual but I might have an answer for you on what is hanging you up. Look in the area near the touchpad on the base. Are there what appears to be two Hex shaped stand-offs screwed to the motherboard in that area. These are generally used to secure Mini-pci cards and they are usually zinc in color. They may even have a plastic support nearby with an arrow by each standoff as a guide to remove them as a matter of case disassembly. Just a thought to look out for something like that.
Posted on Sep 11, 2009
Testimonial: "I'll check it out. The "box" is out in my shop. There are some zinc plated torx standoffs in the areas about 2" away. Thanks!"
  • 643 Answers
SOURCE: my lenovo Y510 ideapad turns on but the screen
The next tim eit is turned on, try shiniing a bright flashlight directly on the screen.
If you can see anything there then the backlight has burned out on the screen, and will need to be replaced.
If you cant see anything, try hooking up an external monitor to the laptop, if you have a desktop the monitor for it will work for the test..
If the external monitor you hook up will work, then you will have to replace the screen..
( or at a minimum the inverter board, or check that the cables are tight that go to the screen)
Posted on Oct 31, 2009
  • 57 Answers
SOURCE: Lenovo IdeaPad Y510 screen will just go black like
I recently worked on this exact problem.
We updated the video drivers to the most recent release.
I thought this fixed the problem but is re-surfaced a few hours later.
Then we flashed the BIOS to the most current version and reviewed the BIOS settings to ensure they were set the way we wanted them.
The problem appeared again the very first boot after flashing the BIOS. We re-booted and it hasn't happened again.
We are cautiously optimistic that the problem has been resolved.
Posted on Apr 02, 2010
Testimonial: "Great information. This helped as our problem seems to be fixed too! "
Stk770d
Please refer to this link to find the exact file you are looking for:
http://consumersupport.lenovo.com/ot/en/driversdownloads/drivers_list.aspx?categoryid=43
Jul 01, 2012 | Lenovo IdeaPad Y510 Core-2 Duo: Y510...
I am looking for lenovo ideapad y510 LCD screen replacement guide. My Screen is cracked
Hi 284607,
I see you need assistance on replacing the LCD screen on your Lenovo Y510 Laptop.
I have a link here that you can got do and download the information on how to replace the LCD screen on your Lenovo Y510 machine but then again just a disclaimer, any damages that may occur during the replacement Lenovo will not be held Liable.
See link for the Details:
LCD replacement Y510
I hope that this helps.
Have a nice day,
mvincentc
May 26, 2011 | Lenovo IdeaPad Y510 Notebook
I need free downloadable PDF files about computer mantanance manual
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=1a6c4f80ee078f5b5a014d5157e4c4e1&modelid=10732267&q=Lenovo+Y510
Aug 17, 2010 | Intel IdeaPad Y510 160GB: Y510 Lenovo...
AUDIO DRIVER
go here to get your download
http://www.laptops-drivers.com/lenovo-laptop/lenovo-ideapad-y510-notebooks-driver.html
Aug 05, 2010 | Lenovo IdeaPad Y510 Core-2 Duo: Y510...
Ideapad disassembly
go to consumersupport.lenovo.com. click on support and downloads. and on the left side look for manuals and user guide. you'll get there the info.
Mar 29, 2010 | Lenovo IdeaPad Y510 Notebook
Lenovo y510 tries to downlaod anything to full system c drive instead of d drive
WHEN DOWNLOADING THE SYSTEMASKS USUALLY WHERE TO STORE THE FILE THAT IS WHERE YOU INDICATE THE D DRIVE
Jul 04, 2009 | Intel IdeaPad Y510 160GB: Y510 Lenovo...
Lenovo touch pad not working properly
Please update the Touchpad driver from www.lenovo.com
May 25, 2009 | Lenovo IdeaPad Y510 Core-2 Duo: Y510...
Where is the cpu located in the Lenovo Ideapad Y510
hi,
I Lenovo Notebooks cpu is located at the extreme left upper corner and when you will open then the heatsink will be visible on it.
after opening the screw of the heatsink simply turn the non removable screw and then lift the cpu.
Dec 26, 2008 | Lenovo IdeaPad Y510 Notebook
Lenovo IdeaPad Y510 Notebook Logo
320 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
