Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
My top drawer is continously turning off and on. I have cleaned it thourougly, wiped around the sides and the control select panel inside and it hasn't helped. I have turned off the power and turned it back on. Can't seem to get it to behave. Botton drawer no problem. Any solution?
    Problem Solver:
  • 7 Answers
Could have a water leak from one of the drawers, Do you get an F1 code? That indicates water on the floor in the base.
Posted on May 19, 2011
I have the F&P single drawer dishwasher, works great, I love it. BUT I can't get the remote to stop the operation so I can open the drawer. It has a new battery and the red light flashes...??
Try gently wiping off the window over the remote control receiver on the dishwasher. Use a dampened soft cloth with mild dish soap, then gently wipe with a cloth dampened only with water. If you can't identify the remote control window, wipe the entire control panel; just be careful you don't get liquid running into any buttons.
You can also clean the window on the remote control transmitter (hand-held unit), with the same precaution (if you want to be really careful, point the window end at the floor so any excess liquid will not go inside the remote control).
Jun 12, 2017 | Dishwashers
Fisher paykel dishdrawer
It is likely the top panel of the drawer needs cleaning.
First turn off the mains power to dishwasher and take the plug out if accessible. Wait a little and put the plug back and turn on the mains power. If this does not fix the problem, then get clean damp cloth and wipe the panel buttons on top inside of drawer.
May 17, 2013 | Fisher and Paykel 24 in. DS603H SS...
I cant reset the dish washer is operating in 11 minutes which is rinse only??? I have turned it off, but it doesnt reset. can you please let me know how to reset it?
The reason for the dishwasher to default to Rinse only cycle is likely the heater is faulty. Does this happen with both the drawers?
Also make sure the top panel switches are clean. Use a damp clean cloth and wipe the top panel inside drawer.
By the way Fixya policy does not allow people to respond on direct email addresses. Sorry can't email you directly.
Feb 24, 2013 | Fisher and Paykel DD605SS Stainless Steel...
Why won't my top drawer start
I am assuming you have a double drawer unit DD603. A drawer will not respond when you press Start button for several reasons. Assuming the panel lights are on, there could be a problem with the lid seal motor or the sensor that detects drawer is closed or blocked outlet hose or dirty panel. Take a damp clean cloth and wipe the inside of the drawer door panel. The dishwasher is very smart and checks for the condition of the dishwasher before starting. If turning off the mains power and turning it back on does not change the situation you will need a technician to attend to it.
Feb 07, 2013 | Fisher and Paykel Dishwashers
My single draw dishwashing wont start i turn it on it beeps 3 times then turns off
This could be caused by some sensor problem which prevents the controller from starting.
Please provide model number. Take a clean damp cloth and wipe all the buttons around the drawer panel including the edges.
If this makes no difference then most likely the problem is more deaper. Things like drawer close sensor or lid seal actuator could be faulty.
Jan 07, 2013 | Fisher and Paykel Dishwashers
Top drawer on F&P dish drawer stuck on cycle & continuously beeping
You could isolate the top drawer by taking the controller power cable out. DIsconnect mains power to dishwasher, open top drawer and remove front cover carefull after removing 2 plastic pins on each side with plier. Controller box is on left top side, remove bottom connector and cover with insulation tape. Put things back and turn power back on.
But if you want to find the fault with top drawer then that is very trick if there is no fault code on panel except beeping First clean the top panel inside door with a clean damp cloth. If this does not change the situation, then it is very likely the controller is detecting some faulty sensor - and will need to find one by one. Are you ready for it?
Dec 17, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Have a Fisher & Paykel two drawer built in, each drawer will start running, but stops many times thru the cycle and starts beeping.
The dishdrawer is a very sophisticated dishwasher and is very sensitive to dirt collecting inside and in the drain hoses. My suggestion would be to first clean the drawers from inside with damp cloth, especially around the top panel. Buy Finish dishwasher cleaning kit (one for each drawer) from the supermarket. Select longest cycel on dishwasher and run each drawer with the cleaning kit inside as per instructions on the kit.
See if this makes any difference.
Dec 11, 2012 | Fisher and Paykel Dishwashers
I have a Fisher and Paykel 2-drawer dishwasher. The top drawer is stuck in the rinse cycle and I cannot change it to another cycle. Please advise.
Assuming the controller of the top drawer is still ok, take a clean damp cloth and wipe the top panel where the program keys are located.
If nothing happens, you will have to check if the controller connector is not loose. Take the front cover off and check the controller connectors.
Please rate this solution to help fixya serve you better in future.
Sep 16, 2010 | Fisher and Paykel 23 in. DD603H SS...
Top draw on our dishwasher isnt working .bottoms fine.wont start just beeps and the numbers /display is jumbled
If this has stopped working suddenly then most likely the controller on the top drawer has packed up. Before panicking, take a clean moist kitchen wipe and clean the edges inside around the drawer including the touch buttons inside. Sometimes the grime confuses the controller. Best of luck.
Oct 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
