I have a Rinnai Avenger 25 Gas heater which was clean for dust and all of a sudden it works find first thing in the morning yet in the evenings it only lasts for around 5 mins and thens switches off whit a number 13 falshing in the temp screen.
    Brigadier General:
  • 4,736 Answers
Tony, the number 13 represents an Error Code - Combustion Control Faulty . Which may indicate that the Pilot is dirty and needs cleaning or the Thermocouple and/or the Thermopile are failing.. However, you said, "it works fine in the morning, yet in the evenings it only lasts for around 5 minutes", which would seem to negate that theory. Unless, you only use the heater briefly in the morning and longer in the evenings. In any event, according to your Owners Manual (see link below), the solution is Service Call, by a qualified Rinnai Service Technician.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Portables/CI_Avenger_Blaze_Dynamo_Enduro.pdf
Hope this helps you troubleshoot and solve the problem.
Posted on May 19, 2011
Rinnai natural Gas Heater 25 TR (Avenger RCE 670)
this is all I could find it looks like an earlier model, but it may be helpful. sorry it is such a long link. it's the download link for the manual, hope it helps.
http://www.google.com/url?sa=t&rct=j&q=rinnai+natural+gas+heater+manual+avenger+RCE+670&source=web&cd=3&ved=0CC4QFjAC&url=http%3A%2F%2Fwww.finesgas.com%2Fproduct_extra_files%2FRinnai-RCE-592.pdf&ei=rzZgUMbfKpLI9QTwx4DwCQ&usg=AFQjCNGPoBENsIVWy_-1GG94mowsXBSosg&cad=rja
Sep 24, 2012 | Rinnai Heating & Cooling
Where can I buy an extension pipe for my Rinnai Avenger 25. I live in Post Code 2017
Go to the auto store. The gas and fuel lines will work on the low pressures. Double check to be sure.
Jul 16, 2011 | Rinnai Heating & Cooling
We get a horrible smell occasionally with our Rinnai Avenger 25 nat.gas heater when alight. The filters are clean & was serivced last winter. It was making the smell at times even after the service. It...
From what you have described, it sounds like a case of delayed ignition or as the Owner's Manual calls it a "Combustion Control Fault"or "Incomplete Combustion". This can be caused by several things: A change in the gas pressure; dirty or clogged burner, electronic fault in the combustion controls.
Despite having it cleaned an services last Winter, 12 months have elapsed, with the unit just sitting and collecting dust and spiders. Portable Heating units should be serviced annually. Usually in the early Fall, before firing it up for the heating season.
Hope this helped you ... Cheers.
Jul 06, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a Rinnai Avenger 25 gas heater. We turned power and gas off after last winter, now we cannot get it to light. It will light for roughly 10 secs and then goes out. There are no numbers set in timer.
Since the gas has been OFF since last Winter, I suspect that there is air in the gas line that needs to be purged. In addition, if it has not been cleaned and serviced annually, the pilot and the burners need to be cleaned. Spiders & other insects love to build nest in them while they are off. Not to mention, accumulated dust. Unplug the unit before attempting any service work.
Purging and cleaning should solve your problem.
Apr 12, 2011 | Heating & Cooling
Rinnai Avenger 25 error 13!
thermocouple high cut out on convection fan rinnai fitters job , have to wait sorry , it is in the manual under fault codes .
Jul 06, 2010 | Heating & Cooling
I cannot get the Avenger 25TR to turn on
Heres a link for the manual for you direct from the Rinnai web site.
Hope you already got this fixed. A good safe heater this one.
Bit biased i suppose as I work for Rinnai.
Have a good day.
May 14, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Code 11 on Rinnai Avenger 25 gas heater
11 means no gas / failed to ignite - check the bayonet is fully plugged in properly, they can be hard to plug/unlpug - otherwise you wilol have to take it in for service.
Aug 19, 2009 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Rinnai Avenger 25 switching off
I had the same problem.
Try cleaning the two filters at the  back of the heater very thoroughly. It worked for me.
Apr 24, 2008 | Heating & Cooling
Heating & Cooling Logo
184 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
