Question about Toshiba TDP-S8 Multimedia Projector
Toshiba Lamp Reset - How?
Hi there, how to reset the lamp counter in Toshiba TDP-S8? Thankx /gasior78
  • 1 more comment
  • Anonymous Feb 01, 2009
    i change a new lamp but how to reset the lamp, (toshiba tdp-s8)
  • joe lim Feb 01, 2009
    i chance my toshiba lamp but how to reset
  • Anonymous Mar 25, 2014
    lamp reset
  • 52 Answers
Not positive, but I would assume the same as my Toshiba.
With the on, input, and menu buttons held down, insert the power cable.
Hope this helps, NGK
Posted on Sep 03, 2008
How do i reset the lamp hour counter on a Toshiba TDP SB20 or a Smart TDP SB20
Make the beep or tone function is on. I can't remember which button on the remote it, maybe the help button. But hold one of the buttons down till you hear a beep. Release and hold again till till you hear a second beep.
Aug 26, 2014 | Office Equipment & Supplies
How do you reset lamp hours on a Toshiba TDP-Tw420 projector?
1. Turn-off the projector by pressing the "ON/STANDBY" and unplug the power cord.
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord .
3. The lamp operation counter will automatically turn to zero.
4. Check if the lettering "0H" appears on the lamp operation counter in the status display.
Jul 31, 2011 | Toshiba TDP-TW420 DLP Projector
I want to rest the Lamp timer of Toshiba Projector TDP-TW95 after replacement of New Lamp
hi
reset ur lamp timer through the following procedure
p { margin-bottom: 0.21cm; }
1. Turn-off the device by pressing the "ON/STANDBY" and unplug the power cord
5. After the lamp operation counter has turned to zero, turn off the projector by pressing "ON/STANDBY" and unplug the device.
ok
Jan 06, 2011 | Toshiba TDP-TW95 DLP Projector
How to reset lamp counter of TDP S8 Toshib Projector
It would be in the manual
aboutprojectors (dot) com has them if you dont
PLease rate my help if this helps
Thanks
Aug 25, 2010 | Toshiba TDP-S8 Multimedia Projector
A new bulb has been fitted and the screen is now green?
reset the lamp timer and change the settings to factory default. let the lamp burn in a bit. if you still have a green problem, you'll need to replace the main board.
Nov 02, 2009 | Toshiba TDP-S8 Multimedia Projector
Toshiba tdp-t90 projector. I rplaced the lamp on
set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
Aug 02, 2009 | Toshiba TDP-T90 Multimedia Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Standby light for toshiba
probably power supply or ballast (starts the lamp)
either would be $600.00 or so to repair, probably costs more than the projector is worth.
Jul 15, 2008 | Toshiba TDP-S8 Multimedia Projector
Name
Hi j cwff
Ok this would be a faulty lamp if you can spot bubbles or vein like looking marks on it in either black or white.
I'm sure you'll solve this by just replacing the lamp and resetting the lamp timer.
May 26, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Dec 09, 2007 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-S8 Multimedia Projector Logo
745 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
