I have a Rinnia LPG Gas heater model no RCE671TR and I want to change it to Natural Gas
  • 521 Answers
SOURCE: rinnia 516tr gas heater
Check the secondary gas pressure change when the set temperature is changed
Posted on Aug 14, 2008
  • 2464 Answers
SOURCE: Just need to no what is required to convert a
hi change the burner injector and the pilot and the reg or the spring inside , you should be able to buy a kit for this.
Posted on May 07, 2010
  • 736 Answers
SOURCE: I have bought a natural
at the end of the pipe that loosely goes into the burner assembly, there is a nut or metal part that has a small hole that the gas goes through ... that is the "gas jet" .. they have different size holes for natural and lp gas .. the manufacturer should have both .. usually it just unscrews and the new one screws in its place .. there would be one for each burner .. if there is only one burner then you need just one replacement jet with a hole size suitable for Lp gas .. you might be able to get the new jet from a local hardware store if you take the old one with you so they can get the size and style right ..
Posted on Oct 09, 2010
jdhnmi
  • 143 Answers
SOURCE: I have wall mounted Vulcan
there is a difuser where the gas comes out and there is a different part for each type of gas. the gas regulator should stay the same you will need a new difuser. dont know if i spelled it right but that is what it is
Posted on Mar 26, 2011
Testimonial: "thank you very much...."
  • 5 Answers
SOURCE: I have a Bonaire RT21/NG
Most of the time, all there is to do is remove the regulator spring and replace with a kit for the specific model of valve you have cause there are a lot of them out there regardless of who made it. So yes it can be done easy and for peanuts but one has to know is way around gas to do the job safely. A picture of the gas train and the valve would help a lot. Remember, 1 manufacturer can use many types of valve depending on where it is sold due to local rules & regulations. Hope this helps Regards from Canada Guy
Posted on Aug 12, 2011
Is model no. GFC101W0 propane or natural gas
the difference between natural and lpg is the jet size and it would not be cost effective to produce specific models when all that is required is a change of jets
there may be a stick on tag on the back which states it if is lpg or natural gas but I suggest that because it is gas that you have a gas fitter come in and inspect it
Oct 14, 2015 | Kitchen Ranges
Hi, I have Osaka Gas Heater model 43-540.
A natural gas heater can only burn natural and vice versa unless there are changes such as orifice and regulator. They can easily be converted to use either fuel, but you have to know what fuel supply you have, and what the appliance is set up for. Since you've already tried LPG, if it turns out the appliance is natural gas, then replace the spud (burner nozzle) before trying to operate it again. LPG cannot pass through the small nozzle hole in a natural gas appliance.
Nov 25, 2013 | Heating & Cooling
Hello Everyone, I have a Totum Patio heather the Natural Gas models. I now have to move to a condo with no natural gas access. Can I convert this Natural Gas model with the LPG models that uses Liquid...
It can be done but you will need a professional gas fitter to do the job. It will need different jet sizing and the air mixture tube adjusted to compensate for the different jets.
Oct 27, 2013 | Barbeques Galore Totum Hls 35,000 Btu...
Rheem 300170 HWS service manual
1) Rheem does not post service manuals.
Call Rheem and ask why, since the other big manufacturers, AO Smith and Bradford White do post service manuals.
2) You need new propane gas control valve, and matching combustion parts to fit existing tank.
http://waterheatertimer.org/pdf/Rheem-Water-Heater-parts-catalog.pdf
http://waterheatertimer.org/images/IMG_1826-LP-burner-450.jpg
3) Rheem does not recommend changing gas type, especially from natural gas to LPG.
LPG is higher pressure, and burns much hotter and requires cast iron burner, unlike the lighter-weight metal used for Natural gas burner.
The manifold tube and thermocouple must match the gas control valve, and gas-type and have correct thread for propane.
The combustion chamber and heat transfer surface can also be heavier metal for propane heaters.
Feb 08, 2013 | Water Heaters
Lpg heater conversion to natural gas
You will need make, model, serial number and name of heater to obtain your kit.
Try National energy the sell spares and they are on line , The how well that is a Gas Fitters job.
Mar 03, 2012 | Heating & Cooling
Model reu2402w need jets for lpg the unit at the moment is natural gas still going but need to run it on lpg
Who is the manufacturer of your heater? Unfortunately, the model number alone doesn't help much. Also, you said you need the "jets" to convert it to LPG. Did you mean you needed the burner Orifices?
Please advise. Thanks
Mar 25, 2011 | Heating & Cooling
329H portable heater Can this be converted to a gas bottle fitting will it be ok what is the use age and how many watts of power to run the electronics etc
You need to convert the unit if you are changing from Natural gas to LPG. This involves getting a full conversion kit for your model and changing burner , gas pressures and electronic settings.
Power draw on high remains at 22Watts. Input is almost identical for either natural or LPG gas as you would expect but running costs depends on how much you pay for your LPG. For example in Australia we use 45kg bottles of LPG, they retails at about A$110 delivered. One of these would last about 170 hours running a 329 on high.About 2 litres of LPG per hour
Aug 26, 2010 | Heating & Cooling
Just need to no what is required to convert a Rinnia energy saver 1001ft space heater from natural gas to LPG?
May 07, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
