Question about KitchenAid KUDS01FKSS Dishwasher
The dishwasher will fill with water but when it trys to start the wash cycle it just makes a huming noise like you would hear when an electric motor is frozen. you can cancel and and it will drain with no problems. i checked the chopper and it spins freey and it appears that the shaft driving the chopper is not frozen. just curious what parts i need to purchase. thanks very much. richard lester
    Top Expert:
  • KitchenAid Master
  • 25,692 Answers
You need to find out what is wrong first.
Check there is power to the water pump firstly and work your way around from there.
Posted on Aug 06, 2017
reg501
  • 413 Answers
SOURCE: Kitchenaide KUDM24SE1 dishwasher will not fill with water
It may be the water inlet valve or the electronic control board. To check, remove the bottom toe panel. The valve will be on the left side. There will be live power, so use extreme CAUTION. Start the DW, 1. if you can hear the valve humming or the valve coil is getting warm, replace the valve. 2. Using a device with wires to check the power at plugs, connect to valve power connection, if power is present, replace valve else replace electronic control board.
Posted on Jun 07, 2008
SOURCE: dishwasher not cleaning/water sprayers not spraying it appears
I had the same thing recently. Everything appeared fine mechanically, but no water would spray. I inspected the bottom arm as closely as possible and actually found a half melted clear plastic straw inside of it. 30 minutes, tweezers and a small pick eventually got it out and all is fine.
Posted on Sep 14, 2008
  • 37 Answers
SOURCE: kitchenaid dishwashes makes wining noise during wash
It sounds as if there is something in the bottom part of the dishwasher arm (it sprays the water around the bottom of the dishwasher). I would suggest that you take out the baskets and then remove and clean all of the parts that water comes out of as well as the bottom drain. If this works or does not, I would also suggest that you run an empty load using 1/4 cup vinegar. Hope this helps!
Posted on Mar 16, 2009
  • 672 Answers
SOURCE: KitchenAid dishwasher allows water to drain while washing
Your dishwasher is siphoning the water out. The drain hose should turn upward, nearly to the bottom side of the counter top, before it attaches to the drain or disposal. If it has an independant drain it still needs the rise and also needs an air break to stop the siphoning.
Posted on Jul 18, 2009
john631068
  • 172 Answers
SOURCE: dishwasher makes grinding noise
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Posted on Nov 19, 2009
DISHWASHER GE PDW7800J00BB DOES NOT WASH ,FILLS WITH WATER BUT NO WASH
It is unclear from your description if the wash pump starts and pushes the water around but never stops cycle or the dishwasher stops as soon as the water is filled.
If you do not hear the wash pump start then it is possible the wash motor is faulty. But if the wash pump starts and never completes the wash cycle then it is possible the heater is faulty and dishwasher is waiting for water to heat up before it can go to next cycle.
See the attached diagram for location of wash pump motor and heater.
Hope this helps you find the problem. Please rate the solution if you found it useful.
Oct 10, 2010 | GE 24 in. Profile PDW7800 Built-in...
When the dishwasher starts or when water starts to enter dishwasher there is a loud noise.
ther could be something stuck n your drain pump.
the way it works is first the unit drains,the it fills,then it start to wash. now if you hear this noise after it drains then it could be your water valve or after it fills when it starts to wash it could be your circulation pump. it depends on what cycle you hear the noise. let me know if this help by posting 4 thumbs up for this answer, thanks
Feb 28, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwasher not working. lights come on but dishwasher will not start. when you hit cancel/stop, 2 minutes appear and there is a huming sound and it counts down and goes off. When u turn on the wash cycle,...
the dw is probably full of water because the motor didnt pump it out
because the impellor on the motor has stripped thread and not drainning the water when u hit cancel /stop the timer is asking the d/w to drain and end the cycle. If u wait 2 mints after u start the machine do u then here a hum from the motor trying to wash
if the d/w dosnt have water in it and you turn it on it should fill or there is a problem with the inlet water valve or timer or no power to the water valve a appliance tech should determine this probably more than normall person should attempt
( solv ya prob)
Oct 18, 2009 | Kenmore Dishwashers
Dishwasher makes squeeling noise when filling with water
if the dishwasher is only filling when u hear the noise it could be a bad water valve or if you are lucky it could be the screen in your water valve is dirty, however if it is filling and washing at the same time and you hear a noise like sqeeling it could be your motor, before u replace the motor. check the water valve or screen on valve may be dirty
Sep 16, 2009 | Frigidaire 24 in. GLD2350RC Energy...
Dishwasher water level low and making strange noise.
Hi, This d/w is designed to run with low water level. The noise you are hearing might be the wash motor. Do you know if this has the single or dual motor setup?
The dual motor style are not the greatest. The wash motor is known to go bad. You can remove the housing below the spray arm and see if anything has lodge in the in impeller. Please let me know if I can assist you further.
Vic
Jun 12, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Dishwasher hums
empty out the unit and recheck the arm and rack then start it up empty and check operation --if huming but working properly --stated it does drain so motor is operating ---then its operating normal ---if arm still not working will need to remove arm and check gear or shaft for damage
Apr 16, 2017 | Kenmore Dishwashers
Hotpoint bwm129 making huming noise
Sounds like the rinse water can't come. Maybe the solenoid for cold water got stuck or a water filter needs cleaning? If the humming is louder, perhaps the drum motor (or drum) needs a little care or cleaning.
If all else fails, download the user manual and check the trouble checklist index. (Or; try learning your kenpo succession move sparring against laundry to clean it.)
Apr 14, 2008 | Hotpoint BWM12 Front Load Washer
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Open Questions:
KitchenAid KUDS01FKSS Dishwasher Logo
56 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
