Cracked liquefied control display - Computers & Internet
  • 32,281 Answers
Po301 number one plug on block 2003 ford windstar v6
the code means a misfire has been detected it could be a few things so check for (a) take out the plug/s and check the boots for cracks by flexing the boot back n forth and by squeezing it the littlest crack will leak voltage from + to the - and thus a misfire (b) a antifreeze leak that is running down into the cylinder will show a wet plug === instant misfire (c) to much dielectric grease on the plug wire boots will liquefy and run down the plug from a running hot motor====instant misfire (d) cracked insulator on the plug (porcelain white part)====instant misfire(e) plug wire insulation is burned or melted ==== instant misfire (f) coil towers has a hairline crack here's one /or the plug is broken on the inside you must use a magnifier glass to find them and this is best for all crack finding issues anything you suspect in the slightest crack is definitely the cause (g) dirty injectors will do it too so you see it's not as easy as you may think please post back with progress and all symptoms still present after work done I'm a 40 year taxi/regular mechanic and every thing will be done for you till we get there even at 3 a.m. we'll get to the cause stephen
Mar 07, 2015 | 2003 Ford Windstar
Is 32c normal for the exhaust temp for a house propane furnace?
32 Celsius = 89.6 Degree Fahrenheit; sounds low:
Liquefied-petroleum gas-fired heating appliance with draft hood Exhaust Temperature: 360 (oF) 182 (oC) Reference link:
Fuels Exhaust Temperatures
Jan 08, 2015 | Heating & Cooling
Orifices L.P. convert
This natural gas range is NOT designed for conversion to Liquefied Petroleum Gas. Sorry.
Oct 20, 2013 | Frigidaire PLGFMZ98GC Kitchen Range
Orifices natural convert
This natural gas range is NOT designed for conversion to Liquefied Petroleum.
Electronic heating & air control unit screen went blank - but unit still controls
Check connectors on display for any corrosion and any cracked or broken solder points, if it they are, resolder or replace digital display.
Mar 25, 2013 | 1999 Buick Century
My patio heater says it burns LPG. what does that stand for?
LPG stands for Liquefied Petroleum Gas, it is very common in patio heaters
Jan 23, 2013 | Patio Heaters
Need to replace screen
You can connect a second LCD screen to your laptop.
The video cable from the monitor connects to the Blue connector on the laptop.
now go to Control Panel\All Control Panel Items\Display\Screen Resolution
Select duplicate display settings.
It should display what is on your laptop screen to the monitor
Dec 28, 2011 | Dell Studio XPS 1640 Laptop
What does LP mean
It really should be LPG of Liquefied Petroleum Gas it is actually a by product of oil refining.
heataman101
Oct 02, 2010 | Kenmore Washing Machines
Defrost
You will need to get this kit part number 4F1Z-14421-AA from your ford dealer.
  1. Place the replacement terminal over the original tab location making sure the conductive areas of the terminal will be on a good conductive area. Do not place the terminal tab foot on the original location which does not have conductive material (figure 4).
    Figure 4 - Article 04-24-5
  2. Hold the terminal in place with an item such as regular lead pencil at a 90 degree angle from the terminal. (Terminal type B can be held in place with tape.) (Holding at other than a 90 degree angle may allow the terminal to slip when the solder liquefies).
  3. Place the soldering gun tip on the top of the terminal but not on the painted areas of the tab. Energize the soldering gun and watch for the painted area of the terminal to liquefy and change color. The paint should liquefy in approximately 25-45 seconds after heating. As soon as the paint color completely changes on either side of the terminal, de-energize the soldering gun and continue to hold the terminal in place with the soldering gun and pencil for an additional thirty (30) seconds.
  4. Remove the soldering gun and pencil from the terminal. The terminal should be allowed to cool for another two (2) minutes before the wiring lead is attached to the terminal.
  5. Attach the electrical lead connection to this terminal, turn on the rear defroster, and verify operation.
Feb 27, 2009 | 1998 Ford Explorer
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
