Question about Car Audio & Video
HI! HAVE A QUANTUM AUDIO QA 1800D MONOBLOCK AMP. HAD IT PUT IN CLOSET PULLED IT OUT I FORGOT HOW TO HOOK IT UP TRIED MY MEMPHIS 12'' SUBS 200W THEY STARTED SMOKING AND NOT WORKING ANYMORE. IS THE AMP BAD OR I HOOKED THEM UP WRONG? ANY IDEAS FEEL FREE TO TELL ''THANKS''
SOURCE: nedd help with my car audio
Here's your best bet. Crutchfield magazine has THE best site for training. The link to the page for you is http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html
You will need to know how many voice coils your sub has, how many ohms and how many channels you amp has, then click the appropriate link. Good luck and don't forget to leave "FixYa" for feedback.
Posted on Feb 08, 2008
SOURCE: subwoofer/speakers are hooked up to my amp but making bad noise
it sounds like you have some wires crossed or a bad ground
Hope this helps
Posted on Jan 26, 2009
  • 18 Answers
SOURCE: i want to hook up my 2 quad coil woofers to a 1ohm amp but
I would look up "series" and "parallel" wiring on the net. Parallel will lower your ohms, which is good- especially for you since your amp is 1ohm. use 1 channel of your amp (unbridged...bridging an amp could increase output, but will Raise the ohms) connect the positive terminal with a wire that goes to the positive on your first sub, and from there, connect a wire from that same positive terminal to the positive terminal on your second sub. do the same thing with the neg. wire. This is called parallel wiring.
Posted on Aug 10, 2009
  • 33 Answers
SOURCE: how many different ways can you wire a 12 memphis subwoofer
you need conneciton to amp streit from battery terminal but make sure you put an inline fuse in the main wire first for safty
Posted on Oct 07, 2009
  • 21 Answers
SOURCE: My amps and subs are working, but my subs aren't hitting.
Try bypassing the remote wire staight to power instead of the stereo
Posted on Oct 27, 2009
HI! HAVE A QUANTUM AUDIO QA1800D MONOBLOCK AMP FORGOT HOW TO HOOK IT UP HAD IT IN THE CLOSET PULLED IT OUT TRIED TO HOOK UP MY MEMPHIS 12'' 200W AND THEY STARTED SMOKING AND WON'T WORK ANY...
Sound like both. But the amp is fried now. It is fixable you have to replace the transistors that is attached to the heatsink. Its a job and a half and need soldering skills.
Parts are just a few bucks on line. What you need to do is open up the amp and disasemble the whole thing. Take the motherboard off completly and look at the transistors for the part number. find the part number and go to this website for a cross-refference fot an NTE part number. http://nte01.nteinc.com/nte/NTExRefSemiProd.nsf/$$Search?OpenForm. Once located the NTE part number. Go to http://parts-express.com/ and search the NTE part number in the search box. Hope this helps.
May 19, 2011 | Car Audio & Video
What would the best way hooking up a 15" memphis dual voice coil sub ran with a 1000 watt memphis d amplifier??
If the amp is a 2 channel I would hook up each voice coil to a different channel. Also, make sure you hook your amp up as close to the sub as possible. With a sub that size you need to eliminate any delay in signal transfer because the sub is so larg.
May 02, 2011 | Car Audio & Video
Subs just rumble at higher levels...??? help!
there is a loose piece inside my 10" cozmik series. how do i get it out?
Mar 12, 2010 | Quantum Audio Cozmik QCA2300 Car Amp
How to hook it up to system with two 10s 400 watts per sub and two 6x9s at 200 watts each?,subs behind seats, 6x9s in doors. IF i need another amp i have one,to help push. But either way i need your help...
Hello www_mitzjohn,
I'd definitely use another amp.
The 2-channel Sony is well suited for powering the 6X9's but a monoblock would be better for the subs. The different types of speakers running from the same channel will not sound very good and likely it'll be impossible to get the impedances to match.
You'll want to set the Sony to send higher frequencies to the 6X9's, but not to the subs. You can't adjust the channels individually. So, just connect each 6X9 to one channel of the Sony and use a monoblock subwoofer amp for the subs.
Hope this helps.
Oct 31, 2009 | Sony XM-2150GSX Car Audio Amplifier
I have a 08 L7 15 hooked up to a 3500W monoblock class D SPL amp, its been working fine for several months until today now the voice coil is fried, what can i do? I also never set the gain more than half...
if it was not a new sub it could had bin used hard and all it needed was one good hit to blow. and if it was new it could had bin a refurbished they tend to blow quick and thats amp is too much of that sub thats good just keep the gain like u have it what ill do go Memphis that is a good 15"
Jul 02, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
2 L5 12'S 2OHM
I like JL Audio's products and in this case a 1000/1 would match these subs really well considering that each sub is rated at 600 watts RMS. I know that you want to bring these subs to the max and if you're not worried about blowing them up you can use two JL Audio 1000/1's, the JL amps have something called ohm matching and can put out 1000watts RMS at any load between 2ohms and 16ohms. A very use full feature - as well as a subsonic filter that can keep out the bass you can't hear and thus keep your subs alive longer especially if you plan to max em' out. Check out Ebay for good prices on JL Audio. Another choice might be an Audiobahn 2300, or preferably an 1800d. D class amps are best for max output and I've wired an Audiobahn 1800d down to a 1 ohm load (to two dual 4 ohm 15" Cerwin Vega Strokers paralleled down) and it was able to stay alive, but this was not used for prolonged listening (Short bursts for SPL comps). Good luck and I'll leave you with an old trick I used to use on my clients SPL Comp cars. Run an in-line fuse to each sub - start at about a 100amp fuse (1,000w @ 12v = 120 amp draw) and move it up if it blows too early, fuses are cheaper than subs! Let me know what box you are running as it must be built specifically for running the subs all-out. You can e-mail me @ (dynami28@charter.net) for free specs on basic enlosures.
-Dynami
Apr 05, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Ma audio hk 4000d
you have definately blown a output channel, or power supply. Send it in for warranty.
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
Help connecting the sub
Your sub or amp is probably blown. Do you get any power to the amp? try hooking up another speaker and seeing if you get any signal at all.
Jun 24, 2008 | MTX TA4501 Thunder 4501 MonoBlock Car...
ELA 500.I
While I don't have any first-hand experience with either Bazooka amps or Memphis subs, this review pretty much says what I initial thoughts were. The amp will do the job without much fuss, so it mainly depends on whether you can get it for a good price.
BUT........
There could be a issue with your sub. According to Memphis, your sub (assuming it's the single voice coil version) is only good for about 250W RMS (let's ignore peak power for now). The ELA500.1, on the other hand, puts out 375W RMS at 4 ohms. You could very easily overpower your sub with that amp.
Mar 13, 2008 | Bazooka (EL10190PP) Car Audio Amplifier
Car Audio & Video Logo
51 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
