Question about Toshiba 2060 Copier
Can i order a thermister? - Toshiba 2060 Copier
  • 1,110 Answers
Http://www.precisionroller.com/search.php?q=toshiba+2060+thermistor
I use them all the time. Great source for parts and supplies.
Good Luck
Posted on May 20, 2011
HOW C3801 BIZHUB 421
Thermisters / Heat Sensors abnormality. Replace the thermisters, in order to get rid of this problem permanently.
May 26, 2014 | Konica Minolta bizhub C351 All-In-One...
Samsung dryer is showing TO, what does it mean?
Dryer thermister is open. Thermister Open. Thermisters will change in resistance with temperature changes. The control relies on reading from this thermister so it can make a determination of whether or not to turn the heat on. If it is open then the control don't know what the air temp is inside the dryer and therefore it shuts down and declares an error. The thermister is mounted on the blower where it gets the air coming out of the drum on the way out the back. The fuse is right next to it. I bet you would like a service manual wouldn't you? SAMSUNG DRYER MANUAL
Note: dryer error codes are on page 32.
Dec 31, 2012 | Samsung DV328AE Electric Dryer
Ned7200tw lights come on but does not start
Replace the thermister on the blower housing. Here is the part to order.
Dec 04, 2012 | Dryers
MDE9700AYW
The thermister, located on the blower housing will need to be checked. This will keep the dryer from running if the thermister is out of tolerance. At room temperature of 77 degrees it should read 10K ohms. If it is out of tolerance, you will need to replace it. Here is the part to order.
Regards,
Richard Roth
http://appliancecafe.com
Nov 16, 2012 | Maytag Dryers
I have a whirlpool cabrio dryer model WED6600VWD. What does the F1 error code mean?
The F1 error code means that the thermister (cycling thermostat) has a open circuit and should be replaced.
To check the thermister you would need to DISCONNECT POWER TO THE DRYER remove the lower small front panel below the main one where the door is at and using a digital meter set to measure ya would remove the wires from the thermister and check for appx. 5,000- 7,500 ohms at room temperature.
If the ohms at within 5 thousand to 7thousand 5 hundred at room temp. the thermister is good and the control board is what the problem is....if the ohms is way lower or higher that 5-7,500 ohms the thermister is going to be what would need to be replaced.
Here is what the thermister looks like
I hope i have been able to help you fix your dryer,
GENE
Oct 31, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
WHER DO I GET A REPLACEMENT THERMISTER FOR WHIRLPOOL MODEL S25BRWW20AG NAME ON THERMISTER ISPRACONTROLS
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jul 09, 2011 | Whirlpool Washing Machines
Display shows E1 and shuts off
thermister shorted code just replace the thermister and you will be back drying again// thermister is located in the front behind toe panel and then remove lint screen housing
Sep 25, 2009 | Kenmore Elite HE4 Electric Dryer
Air condioner climbs to 86 degrees
These latest models rely on a cheap part called a thermister. Older ones used a mercury based cold control. A pc board sends a small amount of power through the thermister to judge the temp. As the temp changes the resistance inside the thermister changes. These el cheapo mexican thermisters are a dime a dozen. They have a quick connect. The thermister must be suspended near the coils but not directly on them or temps will not be judged correctly. Since a thermister is less than $10 bucks i would replace that first before calling someone.
Aug 21, 2009 | GE AJCQ08ACB Air Conditioner
Thetford caravan fridge freezes all food in fridge does anyone else have this problem / what can be done? Not sure of actual model but on manual says N80 - N150
Thats a Norcold compact fridge. The most likley problem would be the thermister. Need to do an ohms reading. From inside of the fridge remone the thermister from the fins and unplug the wires. With a VOM set it on Ohms, touch the wires with the probes/ does not matter which probe to wire/ hold the bulb end of the thermister between your fingers, your reading should stat at about 7000 Ohms. Stick the bulb end of the thermister in a glass of ice water, reading should start climbing and go to about 22000 Ohms. If this happens the thermister is good and you need to look elsewhere. If it does not test out you need to replace the thermister. The thermister is a thermostat that controls the heat source that makes the fridge cool. If the thermister reads good you may want to get the circuit board tested.
Hope this helps
Thank you for using Fixya
Jerry
Mar 29, 2009 | Refrigerators
001 error occur
error for faulty temp sensor we can try to clear 1st if it comes back you need to have the thermister changed..... inthis order press add func key / then 2 & 8 key at same time / then add function key again . ( you mayneed to do this acouple times) screen should change to serv mode then in this order touch copier / function / clear / err / ok turn off copier then turn on good lick
Jan 01, 2009 | Canon imageRUNNER 5000 Copier
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
