Question about Kodak EASYSHARE Plus Series 3 Thermal Photo Printer
No Power Carefully unplugged, then packed in a suitcase to take on vacation. It never worked again. Tried many outlets etc. and NO POWER to the dock. I loved this thing, the printed pictures were the best. It's not even two years old.
  • Gayle Ashbach
    Gayle Ashbach May 11, 2010
    Did you try an uninstall and a clean of your software? What did you next plug it into? Let's just be clear-you never got power to it again? Do you have the manual? This is a very curious problem. I am wondering if there is some sort of reset you have to do. Had you ever moved it before?Did you send it on an airplane in checked baggage? I'm going to look for the manufacturer's info and get back to you.
  • 876 Answers
This is Kodaks suggestion:
Verify that the large end of the AC power cord is inserted fully into a power outlet.
Verify that the small end of the AC power cord is inserted fully into the DC-in port on the back of the printer.
Turn on any power strip or wall switch that is connected to the printer.
Here is a page that might be of some help to you:
http://www.kodak.com/global/en/service/publications/urg00467toc.jhtml?pq-path=7748
Good luck and let us know how it goes.
Posted on Aug 14, 2008
Lights shut off immediately
Bad transformer?
Copy following link for tips keeping the next power pack running longer, and warranty coverage on Intermatic/Malibu ML200 power pack.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Try plugging power pack into extension cord from different outlet,,, but if timer is keeping good time, I suspect the incoming voltage is adequate.
Gene
Jul 19, 2013 | Malibu Hardware & Accessories
ML600 won't turn off
The clock module for power pack is not sold separately.
Set timer to auto using override knob so lights are on, then plug power pack into cheap timer.
Check outlet with circuit analyzer.
Try connecting power pack to another outlet.
Copy following link for warranty information, tips to help power pack last longer, links to trippers, troubleshoot, etc.
Jul 15, 2012 | Malibu ML600TW - Low Voltage Power Pack -...
Malibu transformer 120w 1-8100-9120-01 transformer has no power and LCD is dark. Power plug was verified to be working. Unit is new, installed, configured and came back to see if lights came on during...
I don't have repair for defect timer, except return to Home Depot and exchange for another.
Try unplugging timer to see if will reset. There is no specific reset button on timer.
Test outlet with circuit analyzer to confirm there are no electrical problems.
The label shows advisories: Don't use extension cord, unplug unit when working on bulbs, and plug unit into GFCI protected outlet to protect from surge and short.
Other advisories not shown: Unplug power pack if breaker trips or if power goes out. Wait until power is on before plugging back in. First bulb should be 10 feet from unit. Do not wrap extra cord around power pack. Match bulb wattage and power pack wattage: 200 watt power pack should have 200 watts and not more or less. Replace bulbs as soon as they burn out.
These advisories should not affect initial operation of timer, but are things that shorten life of power packs,
Open following links for resources:
http://waterheatertimer.org/images/Malibu-8100-9045-01-large.jpg
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#dawn-dusk
Aug 28, 2011 | Intermatic Malibu 300W Power Pack...
My problem is with the ML 100T. It feell off its hanger while connected and the two wires fell off the transformer remaining connected to my electrical outlet. I hooked one up to the A terminal and one...
Plug another device into same receptacle and see if GFCI trips again.
If the Power Pack is only thing that trips GFCI, then you need a new Power Pack
If you have Terminal C, it is for photo-electric eye
The wires are reversible on the A and B terminals.
Malibulights.com has no troubleshooting section.
The power packs are sealed units, and when they stop working, you buy another.
Malibu does give some suggestions:
Wattage of power pack has to match total wattage of lights.
10 - 20 watt bulbs = 200 Watt power pack.
If you put 300 Watt power pack on 200Watts of bulbs, it will burn out bulbs and burn out power pack.
When bulbs burn out, replace them as soon as possible or it will burn out the other bulbs and burn out power pack.
When working on bulbs, unplug power pack or it could burn out power pack.
Oct 25, 2010 | Intermatic Malibu 300W Power Pack...
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
Power Pack Plug-In
The instruction manual asks for the arrow on the power lead to be at the top. Unfortunately not all of the leads are marked with an arrow but some have DC where the arrow should be. It is possible to put the plug in upside down so please inspect the plug and socket for two very small chamfers on both the plug prongs and the socket and line them up. This is the first step, however even with the lead fitted correctly some units still only work intermittently. Leaving it unplugged for 2 mins resets the unit. This works sometimes. I think Bose need to address this problem with an update or product recall. regards pcs
Dec 26, 2008 | Bose SoundDock digital music system...
Turning on i guess
It should work OK once you plug it back in. Note there are three places to check the power connection.
- The power pack has to be inserted firmly
- the cord that goes into the power pack
- the cord into the wall - be sure to check the wall outlet with a lamp or something to make sure it's not an overall power problem/breaker, etc.
Steve
Sep 11, 2008 | Lexmark X5470 All-In-One InkJet Printer
BLACK SCREEN NO BOOT ON HARD DRIVE OR O.S.
US has 110volt power outlet while other countries like Philippines have different power outlet outlet voltage of 220v. You cant use the same power adaptor that you use in the US but if you use a power regulator like a UPS device it wont have a problem
Jul 26, 2008 | Gateway MT6705 Notebook
Wii / No Power
or you can remove all of the plugs from the console: AC, remote sensor, AV. This is important: You must also unplug the AC from the electrical outlet. Then wait 45 seconds, then plug the AC adapter back into the wall and your console. Power On.
Dec 25, 2007 | Nintendo Wii Console
Kodak EASYSHARE Plus Series 3 Thermal Photo Printer Logo
55 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
