Question about Kohler Archer Clearflo 1-1/2in Bath Drain with Slotted Overflow Cover - K-7
I have a Kohler Overflow tub with a faceplate covering the screws that would allow me to get to the trip lever...the lever must be stuck "down" because the tub won't drain. How do I take off this plate without forcibly ripping it off?!
Hey, I think I've got the solution for your situation.
First off, you want to get a caulk remover and apply that on all the caulking between the tub and the faceplate. Let this soak for 20 minutes. Then you will want to take a utility knife to score around the edges of the faceplate between the faceplate and the tub. Be careful not to scratch the tub! When the caulking has been completely cut through all the way around the face plate, take putty knife and pry the faceplate from the side of the tub. Check out the lever, or see if it is just gunk build up on the filter. Either way I hope this helps, and good luck!
Posted on May 19, 2011
For a tub overflow washer (Part# PPC826-3) where should the "thick end" go - top or the bottom? Is pasting a little silicone recommended on it so that it has a better seal after I tighten the screw?
The thicker end goes up because of the sloped end of the bathtub. You should not need to apply any sealant - the gasket is compressed as the screw is tightened.
Dec 06, 2016 | Plumbing
Why does my gerberit push buttton waste and overflow not stay open when draining a full tub
Because the screw on cover on the side of the outlet is not tight enough. I changed one on Friday :>) When you press or pull the lever, there is a rod the goes through a screw down boss, and into the waste pipe to raise and lower the plug.
The suction on a full tub is pretty strong.
Google 'pop up P.O.'.
PO = (Patented Overflow).
Nov 28, 2016 | Plumbing
Kohler pop up plug staying closed
The plug has a little hole in the end - that rocker-arm lever fits through the hole. If the plug gets turned 90 degrees to the side before installing the lever, the lever won't go through the holeand the popup won't pop up. Pull the lever back out, rotate the plug 90 degrees with your fingertips or thumb, and put it back in. It may take several tries.
Feb 05, 2014 | Kohler Plumbing
Drain stuck in closed position
Generally the drains that are controlled from the
OVER-FLOW do indeed have a rod that goes down
from the face of the overflow... which lifts (opens)
the drain by lifting a hollow (typically plastic) sleeve
from in front of the outflow of the drain...
It is hollow to allow the OVERFLOW to work at all times.
The version you seem to have... WOULD have a
bellows like device that pushes on a plug lever...
More complex... but I seriously believe both may be
serviced through the OVERFLOW
(will attach a drawing below)...
OBVIOUSLY you will want to block the drain before rolling & dropping screws in, on & around the drain HOLE...
Once you see the diagram of the drain MECHANISM...
you will be able to see that jamming in a coat-hanger
was a terrible idea.
You can still most likely remove and repair the
mechanism ... (from the over-flow)
ELSE
You are looking at buying a new one and installing the entire drain from the bottom (hopefully).
Diagram of drains:
Go to Bing homepage
Carnac the Magnificent
Mar 22, 2017 | Maax Plumbing
Tub drain would not work . pulled on metal rod with vicegrips and it opened the eyehook connect it to the stopper. i can get it to grab on the stopper , but not enough to get it out. what can i do?
kohler hooks on to kinda of a coiled spring that you just unscrew,after you take the two screws out of the trip lever keep turning it to the left until it pulls right out.the stopper for the water slides into that spring at the height to make it go up and down with the trip lever,Ive done lots of them but its hard to explain. if not can you get at it in the basement?
Jan 07, 2011 | Kohler CLEARFLO BATH DRAIN K-7160-TF-BV
Drain in the close position the drain handle is not working
Remove the 2 screws on the drain cover in the bath tub to gain access. Drain plug should be connected to trip lever on drain cover probably using a cotter pin with ends bent to keep it on. Do not yet remove the cotter pin.
To know for sure if it is the trip lever broken, you can hold the trip lever down and tub will drain. If you let go, trip lever on cover returns to upright position and stops draining. You can also feel the spring tension stay on it when you press the trip lever down. Most likely, the drain trip lever (spring action) which is a part of the cover itself is broken.
First have ice pick, thin screwdriver, (even a large paper clip (or 2 for strength) bent straight may do) or anything small enough to go through same hole in drain assembly as cotter pin, while long enough to go across hole in bathtub to hold drain assembly up till you install new drain cover attaching it to assembly with same or new cotter pin.
Now unbend the cotter pin (sort of looks like a heavy duty metal bobby pin) ends using pliers. Using pliers pull cotter pin out while holding drain assembly so it will not fall back into tub wall.
Next secure assembly using the above ice pick or large paper clip while you take trip lever (which is the cover)
to hardware store, etc. to pick up generic tub trip lever.
CHANCES ARE THE ABOVE SOLVED PROBLEM, BUT IN CASE IT WAS NOT THE TRIP LEVER WHEN YOU TESTED USING THE METHOD ABOVE TO DIAGNOSE THEN BELOW IS HOW TO REMOVE ENTIRE TUB DRAIN ASSEMBLY
There is a metal stem with a threaded rod coming up in it with a nut on it, and on the end of this is a round metal weight looking much like a very small upside down can. you will not be able to see all this unless it is neccesary to remove entire drain assembly which you can then take it to a Home Depot or Lowes type store to replace. Most can be replaced with a generic tub drain.
Now to get the assembly out once you've removed the 2 screws gently work metal stem assembly up and out at a slight angle. You may have to move nut on assembly to shorten the length in order to get it to clear the tub. IMPORTANT! If so, 1st mark the position of the nut on the threaded rod so you can put it back in same position when reinstalled before lowering assembly all the way back into tub wall.
Apr 17, 2010 | Home
I have an american standard tub and it constantly clogs. I used drane-o and it worked for a little bit but I think its the drain in the tub. How Can I tell if thats the problem?
Take screws out of plate on tub over flow and pull up trip lever. sometimes they move and need adjusting . It shoul dhave 2 bolts holding the plate on tub at overflow and work with it to remove trip lever assembly once out run some water down drain to let you know if that is th eproblem then you can adjust on trip lever assembly by moving the little barrel like plug near the handle a little will increase water flow out of tub once you put it back in you can adjust it out it back in with out bolting back turn water on and move lever to see if it drains any better.
They can be tricky but you can do it.
Mar 21, 2010 | American Standard 1583.470.020 Universal...
Tub drain wont stay open
If this is a trip lever waste type of drain it can be adjusted, Remove the 2 screws that hold the adjusting lever, this will allow you to remove the stopper. Clean the stopper of hair and sludge and replace. This will usually fix the problem. If not then adjust the linkage for the stopper.
Nov 23, 2009 | American Standard Scala Bathtub Only ...
Bath tub drain
You need to replace the overflow cover with the lever on it.You can replace the entire piece or just the faceplate.There is a spring on most of these that holds the lever in place when thrown and that is the piece that is broken causing your issue. Thanks for using Fix Ya.
Mar 02, 2009 | Delta T13420 Chrome Classic Single Handle...
When water level is above the handle on the wall it goes down
The cover is called a trip lever and Over flow to stop you from over filling the tub or when you get in the tub to equalise the water level. And prevent water from pouring down on the floor
Mark
Dec 23, 2008 | Kohler Home
Kohler Archer Clearflo 1-1/2in Bath Drain with Slotted Overflow Cover - K-7 Logo
656 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
