I want to locate thermostat inside house rather than in return air duct. what connections are available?
  • dsaxon169 May 19, 2011
    Thanks. The reason to I want to make the change is the return air ducts are in the wrong place to get a good sampling of the air. The result is that the areas we want controlled either gets continually hotter or colder (on either heating or cooling cycles). The thermostat is functional according to service people.
    All sevicemen admit the return air is badly located (in a hallway) but all are reluctant to make any changes. I did ask one service company to place a thermostat inside the house, but he ummed and aahed so much I got the message that he didn't really want to do the job. so..
    The outside unit is an Hitatachi Utopia, model EAS5HQE5, the roof unit is a Roberstson something.
    I know that to place a thermostat inside the room would negate measuring the average air, but with some trial and error I ought to be able to find a reasonable compromise position. That's what I am willing to try.
    Does this help?
  • dsaxon169 May 20, 2011
    It's in the realm of what I thought he might say. So OK.
  • 43,501 Answers
To be able to help you we will need to know much more about what type of a system you have and what equipment you have.
The existing thermostat probably will not be able to be used, you will need to buy a new t-stat...also the t-stat will then only be sampling the temperature of the space it is in and not getting a mixed or average temperature sampling. Therefore you could be getting into other issues by moving it.
Please comment back and I will try to guide you through what you can do...
heatman101
Posted on May 19, 2011
  • D. Floyd Kolb
    D. Floyd Kolb May 19, 2011
    What you are saying makes sense...do you know if the t-stat uses a sensor or if it has a probe that sticks into the ductwork?
    The other problem, will be getting the wiring to the new location...you will need to open the existing t-stat and find out how many wires are going to it.
    Then find out where the wires are running to...then you will have to figure out how to get the wiring to the spot where you would like to locate the t-stat...
    Once you have that done then you can mark all of the wires and then relocate the t-stat or install a new one if needed...
    heatman101
How do i put in a thermostat in 1999 cadillac deville
DeVille, Eldorado, Seville 1999-2005
Removal & Installation
Print
  1. Disconnect the negative battery cable.
  2. Drain the coolant.
  3. Remove the air intake duct.
  4. Disconnect the radiator hose
  5. Remove the thermostat housing.
  6. Remove the thermostat.
  7. Clean all sealing surfaces.
    Fig. Thermostat and housing-typical
To install:
  1. Install the thermostat.
  2. Install the thermostat housing using a new gasket.
  3. Install the thermostat housing bolts and tighten as follows:
    1. 1999 models: 15 ft. lbs. (20 Nm)
    2. 2000-05 models: 89 inch lbs. (10 Nm).
  4. Connect the radiator hose.
  5. Install the air intake duct.
  6. Refill the coolant.
  7. Connect the negative battery cable.
  8. Start the engine and check for leaks.
Jan 19, 2013 | Cars & Trucks
Maytag_Owners_Manuals PYE3300AYW
For the dryer to take to long to dry is usually a sign of the vent duct work being restricted with lint. Check the vent hose, outside vent door, and the internal duct for lint buildup.
Oct 21, 2011 | Dryers
One of my cold air returns is not working properly. Our house has the original duct system from 1978. We finally got a new furnace and a/c last june. Its been such an improvement that this issue was not...
I assume you mean a "supply" vent inside the house either on the floor or in the ceiling.
If there is no airflow out of the register then the supply duct to that register is disconnected, blocked, or crushed. Go in attic or basement or crawl space and check the supply duct to this register and it should be visually apparent what the problem. Since i don't know where your air handler is located, i don't know where your ductwork is located(hence the attic, basement, or crawl space). There is one other possibility, if you find your supply duct is intact from the main trunk to your supply boot, then you may have a collar with a damper where the supply duct is connected to the main trunk duct and the baffle may be closed. If the tab handle on the baffled collar is in line with the supply duct then it is open. If perpendicular to the supply duct it is fully closed.
Hope this helps.
Sep 04, 2011 | Heating & Cooling
My furnace isn't heating my house. I was wondering if this was because there is a vent from my cold air duct to the outside thus drawing to much cold air into the system. Should this vent be closed in...
If this vent is connected to the return air duct line back to your furnace I would close it off. The only reason that I can see for having a vent to the outside is if you need more combustion air supply.Thank you.
Feb 21, 2011 | Heating & Cooling
Where is the thermostat located
Follow the top radiator hose to where it connects to the engine block. The thermostat is under the domed hose connection on top the motor.
replacing the thermostst involves.
  1. Partially drain the coolant, (until the level is below the thermostat).
  2. Remove or disconnect the following:
    • The air cleaner and duct assembly
    • The crossover exhaust pipe
    • The radiator hose from the thermostat housing
    • The thermostat housing bolts
    • Any remaining sealer from the bolt threads
  3. Rplacing the thermostst is as follows
  4. Install or connect the following:
    • The thermostat
    • The gasket NOTE: Apply RTV sealer, GM P/N 1052366 or the equivalent, to the thermostat housing bolt threads.
      1. Torque to: 18 ft. lbs. (25 Nm)
    • The radiator hose to the thermostat housing
    • The coolant
Feb 09, 2011 | 1999 Oldsmobile Silhouette
2003 CHEVROLET SILVERADO 2500HD 6.0 - thermostat location and replacement
4.8L, 5.3L & 6.0L Engines
  1. Remove the air inlet duct.
  2. Drain the cooling system.
  3. Remove the radiator outlet hose.
  4. Remove the thermostat housing bolts.
  5. Remove the thermostat from the water pump housing.
The O-ring seal is integral to the thermostat housing
Thermostat housing-4.8L, 5.3L and 6.0L engines
To install:
  1. Install the thermostat to the water pump housing making sure the spring side is inserted into the engine.
  2. Install the bolts.
    • Tighten the bolts to 11 ft. lbs. (15 Nm).
  3. Install the radiator outlet hose.
  4. Fill the cooling system.
  5. Install the air inlet duct.
  6. Test the system for leaks.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 26; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
Nov 13, 2010 | 2003 Chevrolet Silverado 2500HD
Keeps over heating, has water and coolant not sure where the thermostat is located because i don't have the manual. oil has been added but i dont have any other clues besides the water pump. Any advice?
Thermostat
To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of
    this section.
  2. Partially drain the coolant, (until the level is below the thermostat).
  3. Remove or disconnect the following:
    • The gasket
    • The thermostat
To Install:
  1. Install or connect the following:
    • The thermostat
    • The gasket
    • The coolant
  2. Thoroughly inspect the cooling system for leaks.
Oct 07, 2010 | 2003 Chevrolet Venture Passanger
Where do i find the thermostat and how do i replace it on a 2001 cadillac deville
The thermostat in the northstar engine is located at the bottom radiator hose (unlike most conventional cooling systems), the hose connects into the housing where you will also find the water pump.
Remove the hose from the housing,then remove the two bolts on the flange,the thermostat can then be pulled out.
Take note of the orientation of the thermostat as you remove it.
Don't forget the new gasket, you may have to order this separately.
Mar 30, 2010 | 2001 Cadillac DeVille
The lint filter was not changed and it got full, now the dryer doesn't heat up. What should I do?
HI, If the lint filter becomes full, this will not allow the air flow to properly escape the ventilation shoot, in return, causing the thermal fuse to blow. You will need to replace the hi limit thermostat, and the thermal fuse as well. this will correct the issue.
The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting. The hi limit thermostat is locate and mounted on the element housing.
Oct 07, 2009 | Kenmore Dryers
2000 Kia Sportage
yes it is very easy just remove the air intake duct located on the radiator (2 10mm bolts) this exsposes the thermostat housing it has 3 10mm bolt remove those and the top of the housing the the thermostat. clean off old gasket material, then replace the thermostat and gasket and reassemble the housing and air intake duct.
Dec 15, 2008 | 2000 Kia Sportage
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
