My computer get a registry traces found.. 75 items found in my list
  • MarcellusA May 19, 2011
    Are you saying that an antivirus program has flagged some registry entries as viruses?
    Problem Solver:
  • 7 Answers
Sounds like you have some registry errors. If you do not have a program to repair registry errors go to http://www.glaryutilities.com/, and download their free program. Once the download is complete, install the program and start it. Choose registry cleaner and start scan. Once the scan is done choose repair. If something goes wrong during the process the program has a restore option to undo the repair.
Posted on May 19, 2011
I am tryign to uninstall fix it, get error 5006
Installation or uninstallation of an application or game fails and gives the following error code:
This issue is due to a previous installation not finishing properly
Solution 1. Rename the Installshield folder
Make sure you've enabled Show hidden files and folders.
Find and rename the Installshield folder:
Windows 32-bit: C:\Program Files\Common Files\Installshield
Windows 64-bit: C:\Program Files (x86)\Common Files\Installshield
If there is an Installshield file in the Common Files folder, rename that one also (e.g. to Installshield_OLD).
Solution 2. Remove all traces of previous uninstall
If renaming the Installshield folder had no effect, find and delete any traces of uninstalled applications.
Applications that can assist you are: Revo Uninstaller, Windows Installer Cleanup Utility , CCleaner.
Alternatively, do a manual clean-up:
Close all running programs. Then clear the Temp folder (found via input of %temp% in Start > Search or Start > Run).
Use the Windows registry editor to delete registry entries related to the program.
Restart the computer.
hope this helps
Sep 10, 2012 | Microsoft Windows Vista Home Basic Edition...
Whenver i installed yahoo mesenger 10 i got the pop box mentioning d3d9.dll not found
1. Reboot your computer.
2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab.
3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation.
4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list.
5. Click the "End Task" button. This will temporarily close all background applications on your system.
6. Click the "X" in the upper right corner to close the Task Manager window.
7. Install Yahoo! Messenger. You should not experience the same issue that you had before.
8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Dec 17, 2010 | Yahoo Messenger
Ym wont install on my computer...whats wrong?
  8. After Yahoo! Messenger is installed, reboot your system. All other background applications will return to their original configurations.
clean ur registry keys to solve the problem , use registry cleaner reg in out to solve the issue
Sep 14, 2010 | Yahoo Messenger
Everytime I start up Windows I an error message.
Well, the reason causing Rundll Error is probably that when you are surfing on line, some Trojan and malware attack your PC and modify the registry for malicious purpose. Though the anti-virus and anti-spyware can remove those Trojans and malware, they cann't repair the destroyed registry. So, Rundll Error happens! Of course, Rundll Error is not only caused by Trojans and malware. According to our research, mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause Rundll Error.
Thru serious test of our expert team, Perfect Optimizer can fix Rundll Error 100%, much higher than other registry products.Because Perfect Optimizer uses a high-performance detection algorithm that will quickly identify missing and invalid references in your Windows registry. With a few easy steps Perfect Optimizer will entirely scan your Windows registry for any invalid or obsolete entries and provide a list of the registry errors found. After that you can choose to clean list items with selection or automatically repair them all.
So when your PC got Rundll Error, it's highly recommended that you download Perfect Optimizer and repair Rundll Error. Anyone can do it like a computer guru within 5 minutes!
Jul 14, 2010 | Toshiba Satellite P105-S6227 Notebook
Hot sync problem for Garmin iQue 3600
If reinstalling on the same computer with your original cd doesnt' work then I suspect that your registry has gotten corrupted somehow.
I'd find another computer and try a totally new install to see if that works. This registry stuff is a headache.
If it works on a different computer then I'd go into the registry and remove all traces of Palm and ique and start all over. Always make a backup of your registry before messing around with it. If the original CD worked before then there's no reason to download newer versions unless you are wanting to solve some other problems.
Don
Jan 27, 2010 | Garmin iQue 3600 GPS Receiver
Dvd will not play on laptop laptop is new with out any problems.
First try the following steps:
  1. Click Start , and enter device manager into the Start Search field.
  2. Click the plus sign (+ ) next to DVD/CD-ROM Drives category.
  3. If a name for a CD/DVD drive does not appear or is listed with errors, close Device Manager.
    If the CD or DVD drive is listed, continue using these steps to troubleshoot.
  4. Click the plus sign (+ ) next to DVD/CD-ROM Drives (or similar) category.
  5. Right-click the drive name and select Uninstall .
  6. Click Yes or OK to remove the CD or DVD listing. Do not restart the computer.
  7. Click on Action and then click on Scan for Hardware Changes.
  8. When Windows opens, wait until the Found new hardware wizard fully configures the drive.
  9. When done, use the CD or DVD drive again to see if it can read discs. If it works, you are done. If it does not, go to the next step.
  10. ************************************************************************
    If the CD/DVD Drives gives the error
    Clear the registry filters for Device Manager error codes 10 , 19 , 31 , 32 , 39 or 41 Click the following Microsoft Fix it Solution to clean the registry filters automatically: Microsoft Fit It
  11. Unplug all non-essential external plug and play devices, especially cameras.
  12. Click Start , and type "regedit " into the Start Search field. The registry editor window appears.
  13. Select Computer in the main window.
  14. Click File , Export , type a filename that is easy for you to remember, and click Save . A copy of the registry has saved for back-up purposes to the Documents folder. If problems occur after using these steps, browse to the file and double-click it to restore the registry.
  15. Click the plus sign (+ ) next to the following items in the list:
    • HKEY_LOCAL_MACHINE
    • SYSTEM
    • CurrentControlSet
    • Control
    • Class
  16. Select 4D36E965-E325-11CE-BFC1-08002BE10318 . Make sure you have selected this exact key name.
  17. Select the LowerFilters value and press the Delete key. Confirm the deletion by clicking Yes .
  18. If an UpperFilters value is also listed, select UpperFilters in the right window and press the Delete key. Confirm the deletion by clicking Yes .
  19. Delete all other UpperFilter and LowerFilter values within the 4D36E965-E325-11CE-BFC1-08002BE10318 key if they exist.
  20. Close the registry editor and restart the computer. The disc drive should now be recognized by Windows.
Jan 01, 2010 | Acer Computers & Internet
McAfee Trusted Programs
Please try the steps below:
Manage trusted lists
Use the Trusted Lists pane to trust or block items that have been
previously detected and trusted. You can also remove an item
from a trusted list so that VirusScan detects it again.
1 Open the Trusted Lists pane.
1. Under Common Tasks, click Home.
2. On the SecurityCenter Home pane, click Computer &
Files.
3. In the Computer & Files information area, click
Configure.
4. On the Computer & Files Configuration pane, ensure
that virus protection is enabled, and click Advanced.
5. Click Trusted Lists in the Virus Protection pane.
2 Select one of the following trusted list types:
�� Program SystemGuards
�� Windows SystemGuards
�� Browser SystemGuards
�� Trusted Programs
�� Trusted Buffer Overflows
3 Under I want to, do one of the following:
�� To allow the detected item to make changes to the
Windows registry or critical system files on your computer
without notifying you, click Trust.
�� To block the detected item from making changes to the
without notifying you, click Block.
�� To remove the detected item from the trusted lists, click
Remove.
If still you face any issue plz revert me
Sep 04, 2009 | Computers & Internet
Completly Uninstalling AVG8 Free edition
hi..still you might not have deleted some of the
folders,that's why you are not able to install it.
uninstall it completely.
check it out..
thank u..
rate me..
Feb 24, 2009 | Dell Dimension E520 PC Desktop
Cannot install omnipage se. wizard interupts process
When unistalled the previous Omnipage SE 4.0 and try to install new update vresion, an error message keep poping up saying a previous version of Omnipage is still installed in the computer and can not install the new version. No more trace is found for old version in Add/Remove screen. The problems are in the registry area. Just run regedit (export the registry as backup) and look for Scansoft under the software directory. Deleted all the Scansoft omnipage traces then restart the computer will solve the problem.
Nov 04, 2008 | Office Equipment & Supplies
How to change startup
its very very easy. down load ccleaner for free its a software which allows you to clean up all files which are not necessary, cleans registry and you can choose startup items which ones to start and make booting process faster
www.ccleaner.com
Jul 30, 2008 | Toshiba Satellite A85-S107 Notebook
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
