Question about HP Office Equipment & Supplies
I have a hp 2840 laser jet and it only prints half a page, on the right side. Only able to read half a document. Replaced drum and it didn't help. All colours toners have plenty of ink, can you please help
  • redhotchilli May 19, 2011
    I have a HP 2840 laserjet and it only prints half documents on the right hand side. I have recalibratyed and read HP trouble shooting info and there is no solution tips for this problem. I have replaced drum and toners have plenty of ink
  • 844 Answers
Welcome to FixYa!
Solution 1. Hard Reset the Printer. While the printer is ON. Disconnect the power cable and the USB cable at the back of your printer. Restart the computer. Try to print again.
Solution 2. The media/paper might be uneven. Try to use a different paper. Try to use a specified paper for laserjets. Paper can have factory defect, which does not allow laser printing on some surfaces.
Solution 3. Determine if this happens in an all back text and all colored text or in pictures only. If this happens in black or colored only, ink may be defective though it has plenty of ink.
Solution 4. Lastly, it might be a carousel dislocation problem. Usually left side does not print. In this case, the printer needs to be serviced as it requires special printer tools to adjust the carousel. Before servicing, make sure that you have done solution 1 to 3 to be certain that it is a carousel problem.
Thank you for using FixYa. Have a great day. Jas247
Posted on May 19, 2011
    Genius:
  • 1,157 Answers
Hi redhotchilli,
This is often caused by the carousel gears. There are some cases where 3rd party toner carts have caused the carousel alignment issues. Sometimes bushings and gears are aging and have begun to wear to the point that skipping of the gears becomes more and more common. Based on the degree of difficulty and cost of parts, it probably isn't indicated to proceed.
Hope it helps.
  • Reynaldo Labaguis Jr.
    Reynaldo Labaguis Jr. May 19, 2011
    Hi redhotchilli,
    Hope it helps.
  • 2,098 Answers
Hi redhotchilli,
This kind of symptom has many possibilities that are going to consider like print cartridges, imaging drum as what you've already replaced, printer calibration, print cartridge carousel. Instructions are very long to write here. I think best way to help you is to provide the copy of the service manual. Listed here the steps-by-steps instruction with picture to solved your problem. If you want a copy, then please give me your email add and I will send it to you for free.
Jdvillanueva
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
Hp color laser jet 2840 not printing on left side
Other than tec guy are not advisable to do this exercise :Corosol align disturbed,open the printer up to corosol mechanism check rotary swing shaft left and right gears, there are markings which was exactly matching with rotary right & left disc markings. If its disturbed print quality issue will developed. If you have service manual read carefully before opening the printer.. Best of luck.
Oct 17, 2011 | HP LaserJet 2840 Printer
Printer name :hp Laser jet 1300 the print
this printer prints a multipage document on 1 page everytime
Oct 21, 2009 | HP LaserJet 1300 Printer
I have a hp 2820 and it only prints on the right hand side
If you make a copy and it only prints one side, the problem is the CIS. The CIS is the strip that lights up when the paper goes through the document feeder. If it is only lighting on on one side, this is your problem. It could also be a problem with the laser unit.
If you print an internal document, such as a report or help page and it is only printing on one side, then the problem is most likely your drum unit or toner. Good luck
Jul 24, 2009 | HP LaserJet 2840 All-In-One Printer
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
Not printing on left side of page
The problem is that the revolving drum doesn't contact the OPC drum proberly. You have to open the left side off the machine and replace the little white gear on the shaft that drive revolving drum. The gear has "jumped"one step and the revolving drum isn't parallell to the OPC drum. I fixed my 2840 last night it takes some time but now it works perfect.
Feb 25, 2009 | HP LaserJet 2840 Printer
Hp 2550 prints only right side of page
printing only the right half of the drum
Nov 28, 2008 | HP LaserJet 2550L Printer
HP Laser Jet 2840
try to recalibrate the cartridge carousel. the central axel is twisted. there are more than 2 problems like this arownd...
Feb 27, 2008 | HP LaserJet 2840 Printer
51 people viewed this question
Seeker5211
Seeker5211
