I am getting a P 0 2 error on my Canon mp250. Roomate spilled a drink on top of it and I think it is causing the ink cartridges to stick on the rod(or whatever) that the cartridges travel on. I can bang it and it will eventually start. But seems to be getting worse. Can I clean with alcohol and lubricate or something? I found only two screws on back and a clip to release the power supply, otherwise I can't get to the right areas. What can I do?
SOURCE: Lexmark P6250 black ink cartridge won t print
Write to Lexmark - you won't get any joy, but their reply might be interesting. I suspect that Lexmark builds a chip into their cartridges preventing it being refilled. When replying to me they did not admit this, but did not deny it, simply stating that their cartridges were designed for single use only. When I said that, apart from the cost, I wanted to minimise my impact on the environment by refilling cartridges, they pointed out their proud association with Planet Ark. I suspect that Planet Ark is happy to be an apologist for corporate vandals, and I seriously question their 'green' credentials. Order your next cartridges from Europe where the printer companies are not allowed to chip their products.
Posted on Sep 02, 2007
SOURCE: Canon MultiPass F20 - "Wrong Cartridge error msg" - not new but hardly used
Take both cartridges out and then you will see a grey lever in the front of the assembly that holds the two cartridges in it.
If you lift that lever up it will allow you to remove the print head assembly.
Soak that in some hot water, use a straw to help blow out any remaining ink residue in the holes that the ink flows throw and once it is dry again put it back in and see if the error goes away.
I'm just running a head cleaning, nozzle cleaning etc. now but I appear to be back in business.
Posted on Nov 19, 2007
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
  • 629 Answers
SOURCE: we have a Canon MP250 Pixma printer that recently
try to adjust the paper guides, then check the rollers for any damaged or dirt which you may need to clean with a dry cloth. make sure they are align, Then use new set of paper and test the printer again. It seems that something is causing the paper to tilt to the right side causing the paper jam.
Posted on Nov 15, 2010
kifuat90
  • 31 Answers
SOURCE: I have a canon pixma
its mean absorber full..(i think)
Check this steps :
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
1 Press the power button to turn off the printer.
  • 2 Hold the "Stop/Reset" button while pushing the power button. While still holding down the power button, release the "Stop/Reset" button and then push it twice in a row.
  • 3 Wait approximately 20 to 30 seconds until the LED shows 0.
  • 4 Push the "Stop/Reset" button four times in a row.
  • 5 Push the power button twice.
  • 6 Turn off the printer by pushing the power button one more time. The printer is now reset. Next comes resetting the counter on the cartridge.
  • 7 Unplug the power and the USB cables from the printer.
  • 8 Open the cartridge door and hold down the power button.
  • 9 Reconnect the power cables while still holding down the power button.
  • 10 Close the cartridge door and release the power button. The ink cartridge is now reset.
  • Posted on Aug 11, 2011
    Why will my canon pixma mp250 not reset a refilled color cartridge
    i dont think you where trying the right solutions. the mp250 catridge 511 can not be reset as far as i know. what you can do to get it to print is to long press the reset button. this disables the ink level check function and you can work. the procedure you stated is usually for resetting the ink absorber, not catridges.
    Good Luck!
    Jan 16, 2013 | Canon Pixma MP250 All-in-One Color InkJet...
    I have a canon pixma mp250 printer and i can't find the manual to explain how to replace the black ink cartridge.
    To change the ink, make sure that the printer is on (green light is lit). Then lift up the entire scanner unit and latch the support on the right. Wait for the cartridge carrier to move into the ink cartridge replacement position. Open the cartridge cover on the right hand side by pinching the front and the tab on the top together; then lift it upwards. The cover will rotate towards the back of the printer. Pull the empty cartridge back out of the slot. Open your new cartridge and peel off the protective tape. (Do not touch the electrical contacts or the nozzles.) Place the new cartridge in the slot (slide it forward). Then rotate the cartridge cover back down until it clicks. If you do not need to change the color cartridge, lift up on the scanner unit until the support unlocks. Then carefully lower the entire scanner unit to close it (don't pinch your fingers or drop the scanner unit). If the orange Alarm light comes on, check that the cartridges are correctly installed and the cover is in place. Wait until the printer recharges ink system before sending a print job or copying a page.
    Canon has the documentation for the MP250 on their site: http://usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mp250#BrochuresAndManuals (for the manuals) .
    I hope this helps.
    Apr 03, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
    Canon pixma mp250 showing fault code e05 will not print
    Try to stick with original cartridges... Generics only waists time and money
    Mar 15, 2012 | Canon Office Equipment & Supplies
    Canon Pixma Mp250 leaks ink
    cartridges tend to bleed when the ink waste pad gets full canon ink
    Jan 11, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
    Canon pixma printer 250 ,alarm lamp and power lapm glow and p 0-7 occur
    Ink Cartridge is not installed in the correct position. Refix the ink cartridge
    Sep 22, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    My canon mp250 is showing a E16 error and has the alarm constant orange and the B blinking. I tried removing and replacing the cartridges but it did not help. I cannot scan either.
    Error No. E16 is caused by Ink has run out / cartridge must be reset.
    To solve the problem here is your solution:
    Press the STOP / Reset for 5 - 15 seconds wait until the led display process.
    Aug 22, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    I have a canon pixma mp250 and error P07 flashing.Now,I refill blac and colour cartridges,and clean ink absorber,but still flashing P07.How to reset printer? Best regards, Misko
    Check this steps :
    3: Connect power.
  • Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    I refilled the ink cartridges on my canon mp250 copier because it stoped printing. The little info box said that the ink was running low now it still won't print . I 've re inserted the ink cartridges...
    originally, when u have ink cartridges in Canon product run low u need to buy new ones, because it was designed like that. even u have refilled the old cartridge full, it will detected low ink because the old cartridge already detected for the beginning. this designed to make Canon buyer to buy new ones ink cartridge. but, there some trick to make your old cartridge detected as new one, all u need just to reset the setting for cartridge recognition. try to visit this site:
    http://resetcanon.com/reset-canon-mp250-pixma-inkjet-all-in-one-printer/
    maybe this site can help your problem, regard riyan.
    Mar 09, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    Canon mp250 series can i print only in black and white i ran out of color ink.
    Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
    Nov 08, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
    How do you fix error code E04 for a Canon Mp250
    hi good morning don't worry this error code tell you to change your BLACK ink cartridge. have a nice day
    Oct 24, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
    146 people viewed this question
    k24674
    jasbo
    jasbo
