My plotter canon iPF710 hardware error 03130031-2F1F, how to solve the problem?
SOURCE: error 03130031-2F1F
03130031-2F1F: Purge motor HP error - Restart printer in Service Mode (Roll/Sheet Feed Button + Information button and then Power On button) to check without Cleaning cycle.
Posted on Mar 08, 2011
SOURCE: canon ipf710 error code 03130031-2f13
Posted on Dec 11, 2009
SOURCE: Error code 03130031-2F13
lol,, see this
  • 79 Answers
SOURCE: Cannon ipf710 - Hardware Error 03130031-4027
this code has to do with the carriage lifting position.
You have to check (on the right side of the machine) if a foreign object (paper) is blocking the carriage.
Then Check the encoder wheel and the encoder sensor.
The last you have to check is the motor that operates the lifting motor.
Posted on Dec 29, 2009
SOURCE: Canon Hardware Error 03130031-2F26
HI All,
Had this 03130031-2F26 problem on ipf8000, as well as:
03130031-2F13
03130031-4027
Carriage would stop suddenly with one of these three errors, sometimes would start up correctly, but could not print much at all and when it did it was blurry and would 'stagger' the print.
I am not an expert, but neither are Canon service agents apparently(!) so I stripped the machine down and had a poke around - it was a broken ribbon cable from carriage/printheads to mainboard. Break (on top ribbon cable) was just before ribbons are glued to enter inside machine (furthest point from carriage). Must be a stress point there.
Can I have $250/hr now??
Posted on May 21, 2011
Hardware error
hello, can you specify what error number is?...i have a service manual for this ipf710 plotter and i can tell u what is wrong with it or you can download the service manual from the below link:
http://goo.gl/daFE3c
good luck
Sep 11, 2013 | Canon imagePROGRAF IPF710 Printer
Error carriage
hello this error means that "A/D converter outside trigger output stop" you will need the service manual to help you it will save u $ when u have problems, you can download it from the below link:
http://goo.gl/lrcIW7
good luck
Sep 10, 2013 | Canon imagePROGRAF iPF710 InkJet Plotter...
When printing a file from Microsoft Project, it prints out halfway and then displays "Hardware error"??
Probably your project file is partially corrupted, apply fix ms project file
http://www.project2003.fixprojecttool.com automatically converts corrupted information from damaged MPP files in use into clean Microsoft Project files of corresponding format
Feb 18, 2013 | Canon imagePROGRAF iPF710 InkJet Plotter...
Tried upgrading Canon iPF710 firmware from 1.35 to 1.40 on 2 separate plotters and received a !Error E196-4040 Call for service message. Plotter will not come to a Online status.
Power off and unplug the printer for several minutes. On power on the printer had the same "ERROR E196-4040 Call For Service" after Initialization. Next start the printer in Service Mode, turn on the printer while holding down the [Paper Source/Feeder Selection] button and [Information] button until Initializing appeared in the display. An "S" will appear in the upper right of the version display. Power down and do a normal Power On and the printer should do a normal initialization and came On Line.
May 28, 2011 | Canon imagePROGRAF IPF710 Printer
Error-03130031-2F26
I have downloaded the drives for the canon ipf710 but cant seem to get the online connection working
Oct 29, 2010 | Canon IPF710 A0 Wide Format Plotter...
Canon ipf700 error 03130031-2f13.
if after the code you had to shutter down, and then the plotter made a head cleaning, we fix just putting a little of oil in the band, in the section were the head print moves.
Nov 16, 2009 | Canon imagePROGRAF IPF710 Printer
We have a Canon iPF710 - first received message: Problem with printhead (we performed steps per manual to clean) Now we are getting message: Prepare for maintenance cartridge replacement. Is this something...
Your Machines maintanance cartridge counter nearby full, you need to buy a new cartridge and just plugin in machine. your will be solved.
No need to call a technitian for that.
Jul 09, 2009 | Canon imagePROGRAF iPF710 InkJet Plotter...
Canon iPF 8000: Hardware Error 03800500-2F2F and 03800500-2F30
it's a multiple problem....there is no enough ink for the head managment sensor to understand the good function of the print head.
Print a nozzle check to see what is going on
Then come back for more information
Feb 10, 2009 | Canon Office Equipment & Supplies
1,630 people viewed this question
k24674
jasbo
jasbo
