Question about Battery Biz Hi-Capacity AC Adapter for: Medion MD40700
Need a compatable ac charger adaptor for medion MD97310 240V
Won't turn on, no lights, no nothing
I guess you need some electronic testers that most probably you don't have because assume you are not a computer tech. Should you have another laptop of similar characteristics, you could test the charger else I see no other option but visit the computer shop where you bought your new charger and get them verify the device as part of warranty
Apr 21, 2015 | Dell Computers & Internet
I need a ac power adaptor
Amazon show one for about US $99.00
But you can get a compatible one on eBay for US 10.59 + Shipping
e.g. http://www.ebay.co.uk/itm/AC-Adaptor-Charger-for-Samsung-Camcorder-AA-E9-AD44-00116B-Power-Supply-Cord-PSU-/350944902138?pt=Batteries_Chargers&hash=item51b5f23bfa
Dec 10, 2014 | Video Cameras
I have an acer aspire 5100 and here recently the
Could be a bad battery and/or charger/AC Adaptor/DC Connector. Try to isolate the problem by removing the battery and then plugging the laptop charger in and starting the pc up. It should boot on the AC adapter alone. If it won't boot on the AC adaptor or it flickers and flashes while on the AC adaptor, I would first suspect the AC adaptor or the DC connector on the laptop (try wiggling the power plug at the PC to try and check the connector). If it behaves while on the AC adaptor without the battery present, I would suspect the battery. Either way, you may have to replace something.
Sep 04, 2014 | Computers & Internet
Bought my headphones in South Africa, now living in the UK. My AC adaptor to power my charger of my headphones is not functioning properly. Could this be caused by the incorrect power adaptor, as it...
Welcome to Fixya. You can check if the power output in South Africa and UK is the same. If you have 110 or 240V in africa check if the Voltage in UK is 110 or 220V aswell. If it is the same it only means that the adaptor is bad. If you can go to a store in UK find an adapter that is compatible with the headphone you can test it and see if it will work.
Thanks for using Fixya.
Mar 12, 2011 | Sennheiser RS 110 Consumer Headphones
Need a replacement ac battery pack for SDVD7110
U mean a litium battery for a portable DVD player or A/C power adaptor charger for the battery ?Yes,tries websites like Partstore.com,Ebay.com,Amazon.com to buy a battery or compatible one also an a/c adaptor charger.
Feb 08, 2011 | Sylvania Televison & Video
The manual says "your camera comes with a compatible charger, your only required to put the battery into the charger and charge the lithium battery directly from the outlet" The camera came with an AC...
You put the battery into the camera. Put the USB end from your computer cord into the end of the AC adapter hook it up to your camera. Ta-da! Everything should be working smoothly in the battery/charger department. :)
Dec 26, 2009 | Vivitar ViviCam 8025 Digital Camera
I lost my camera charger and i wont to put some pics up but it wont turn on what should i do
you need to purchased a charger or 5V AC Adaptor for the camera. sing this 5v AC adaptor you can charged the camera or Turn On the camea
Nov 15, 2009 | Kodak EasyShare M853 Digital Camera
Ac Adaptor not working??
as u said that when u plugged in the ac adaptor into the laptop it recognises that the ac adaptor is connected but it does not charge the laptop in this case what u can do is that if have the same charger extra then u can try with the another charger and if the other charger also does the same thing then in this case u need to replace the mmotherboard and if the other charger is working fine in this laptop then definately chage ur aac adaptor.....good luck...
thanks
Jan 25, 2009 | HP Pavilion dv6000z Notebook
AC adaptor
Dear anjuli
You need to first make sure weather the charger is working fine next thing u should notice weather ur battery is charging or not. If u have been often running it on Batteries then u might need to replace the battery.
Feb 07, 2008 | Durabrand PDV-705 Portable DVD Player
Battery Biz Hi-Capacity AC Adapter for: Medion MD40700 Logo
Top Battery Biz Computers & Internet Experts
Steven Conroy
Steven Conroy
Lawrence Oravetz
Gil Shultz
Are you a Battery Biz Computer and Internet Expert? Answer questions, earn points and help others
