I am having the same problem earlier described as ''Macbook pro does not detect dig 002 rack'',...
(More)
I am having the same problem earlier described as ''Macbook pro does not detect dig 002 rack'', although the system is different. I have an Imac running Snow Leopard (10.6) with Pro Tools 7.4.2., and I am trying to run Itunes through the digi hardware. This is a new computer, and a fresh install of PT. PT works fine, although the firewire interface is having to be daisy chained through an external drive to convert the 002's FW 400 to FW 800 (the only FW port offered on this Imac). The Core Audio program recognizes the 002, as well as an older Mbox, but neither appear in the Apple >Sound >Other preferences...inexplicably the Mbox 2 and Mbox2 Pro do appear however. clicking on these to attempt to reset the sound preferences will make the 002 appear in the Sound Preferences under internal, but not an icon in Other, and nothing seems to allow Itunes to work this way. restarting doesn't work, Itunes seems to always reset the sound preference to internal. Any ideas? I would delete associated preferences if I knew which ones to delete. Also curious if there might not be a Digidesign 7.4.x update that will solve this bug since it seems like a PT glitch. Thanks in advance to anyone offering an easy fix to what seems a common problem
i followed the instructions in the manual on how to replace the blade. it works for a bit but it...
(More)
i followed the instructions in the manual on how to replace the blade. it works for a bit but it just doesn't cut like it used to when the machine was new. it cuts but very poorly almost like a connect the dots looking kind of line.
When I try to import music from a disc to ITunes I get an error message from Microsoft.It appears to...
(More)
When I try to import music from a disc to ITunes I get an error message from Microsoft.It appears to be a file issue
Hi I also have a problem with the sound. I use a laptop with 4meg of memory. I get the sound from...
(More)
Hi I also have a problem with the sound. I use a laptop with 4meg of memory. I get the sound from the Laptop mic, but whin I change it, I get a response of 'Time Stamp' I disabled the mic, then I got the video working but still no sound? In Device Manager it shows 'USB EMP Audio Device' is this correct? I have been trying to fix/use this for hours, but can't get to work? Please help!
