Wireless activation in laptop
I just bought a Q2 laptop. I can't get the internal wireless card to work.
  • 69 Answers
Check connectivity with router. Make sure router is setup for wireless access point. Make sure the internal wireless card is setup for access point as well. hope this helps!
Posted on Aug 14, 2008
I need a wireless pci cardslot for my toshiba satellite m35x s109
Don't waste any more of your time trying to find one. Even if you found one, you more than likely wouldn't be able to get it to work well with a modern wireless router. Get a wireless USB adapter instead. You can get them for less than $10 from just about anywhere and it will actually work without hassle with your wireless router.
Jul 05, 2012 | Toshiba Computers & Internet
Just bought this laptop - cannot get the Wireless
If wireless card is listed in device manager under network adapters-that means you dont have to install it. If you running on vista, go to control panel and find ssomething like wireless contol manager or wireless assistant and see if its not disabled there. may also be disabled in bios settings. on windows xp-check if windows has possibility to manage wireless networks or its blocked by third party software. for example i use bt voyager wireless card and its managed by bt software. built in cards are likely managed by windows. type services.msc in run box and see if wireless zero configuration service is enabled.
Oct 21, 2009 | HP Compaq nc6000 Notebook
Wireless adapter not functioning-
Do the following :
  1. Turn Laptop off, then disconnect adapter and remove battery. Re assemble and restart.
  2. Try clicking the button activating the wireless card.
  3. Reinstall wireless card drivers, select drivers from Compaq Presario V6205NR Notebook PC
  4. If all that did not work, then the internal adapter is faulty. Buy an external wlan adapter:WLAN Adapter WL-167G-£12.90 new
Sep 26, 2009 | Compaq Presario Notebook
Dv2000 internal wireless adapter not detected. enabled in bios setting?? the internal wireless adapter is not detected and doesnt connect to the internet. however, i checked to see if the direct cable...
Is there a blue light to show that the wireless is active on the laptop? If not, switch the wireless connection on once windows has loaded. It may be that you have a faulty connection between the wireless card and the motherboard. Check out this link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277
and follow the instructions
Jun 08, 2009 | HP Pavilion zd7020US Notebook
Want to run - south-african vodacom SIM on Indian vodafone network
you need to contact your nearest vodashop or sp in South Africa to activate international roaming
May 21, 2009 | Vodafone Mobile Connect (055270) Wireless...
Sony VAIO internal wireless driver causes computer to lock up
There is a possibility you have a faulty wireless card. I would go with a external PCMCIA wireless card. Don't forget to disable the internal wireless card in the BIOS.
Feb 16, 2009 | Sony VAIO PCG-K23 Notebook
Wireless Problems!
The computer looks for the cable because wireless is not working.
If wireless card is usb try removing laptop battery, unplugging power adapter and wifi cards, connect in five minutes and see if it works
If it still does not work, reinstall wireless card drivers.
If you have a disk reinstall them from disk.
If you lost the disk download drivers from the Internet, post model on fixya to get the link.
If the wireless card does not work after reinstalling drivers then it is probably faulty.
Note: if you use laptop internal wireless, usually you need to activate a switch to get it working.
Sep 13, 2008 | Computers & Internet
How can i get my wireless rooter to work
Wireless cards come in many different forms: external USB devices, internal PCI Cards desktops, external PC (PCMCIA) Cards for laptops, and internal mini PCI cards for laptops.
What type of computer are wanting to make work with your wireless router? Laptop or PC?
Feb 01, 2008 | D-Link DI 514 Wireless Router (DI-514)
Acer notebook wireless just connects when near to the modem...
The connection between the laptop's internal wireless antenna and its wireless card may been disconnected. Best to take it in to a computer shop for fixing. If you want to fix it, open the PCI-E cover on the bottom of the laptop, then reconnect the antenna wire. If that doesn't work, get it serviced.
Jan 02, 2008 | Acer Aspire 5100 3010 Notebook
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
