Question about V Communications ComSwitch 5500 (CS5500)
The unit can be programmed to behave differently than the out of the box configuration. however the manufacturer is out of business. are the programming codes available?
Did you get an answer as to where to find the programming codes for the DC5500
Posted on Aug 22, 2012
2 Suggested Answers
fxguy1005
  • 7 Answers
SOURCE: I am trying to configure a netgear switch (48
I'm not too familiar with Netgear switches, but if you told me you were having this issue with a Cisco switch, I'd tell you that after you change the IP address you need to save your configuration to NVRAM using the "copy run start" command. A Cisco switch will look to start using the configuration stored in NVRAM when it is booted. Changes are made to the configuration in RAM and are lost when reboot occurs unless they are first saved to NVRAM. Perhaps there is a similar command for the Netgear switch. Hope this helps
Posted on Jun 05, 2010
Is there any software that similar to hzd4b that will work with my hammer storage box and can run on windows 8.1
Hammer went out of business quite awhile ago. You would have to find the manufacture software for that particular unit which will be difficult given that the company is no longer in business.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/aaron_eefc4ebb3e929c59
Jul 07, 2015 | Computers & Internet
What is the A-coil that is compatible with furnace model KG7SC072D24B?
Looking at the model # it appears that you may have a 2 ton unit. Evaporator coils come in different sizes -
You should be able to get the correct size by providing the A/C repair company with the name of the manufacturer and the Model Number.
Generic coils, should you need one because yours is no longer being manufactured, do come in all different sizes.
I don't know if you want to replace the evaporator coil or have a service company do it. But if you do there are some things you need to know.
If the unit is an older unit the evaporator coil along with the box it sets in needs to be replaced because the drain pan is probably rusted out.
Additionally the box the new coil sits in is is going to be different in size then the original.
So a transition will need to be made from the furnace to the new A-coil box.
So with all that being said - if you have a credible A/C company replacing the coil you won't have any problems with them finding a replacement coil. They are in the business of doing this type of work and come across this situation all the time.
Oct 06, 2014 | Heating & Cooling
How do i switch to windows wireless configuration utility
If you are using Windows XP, Vista, or Server 2003, you have an option in how your wireless network card is managed. You can choose to use your manufacturer's Configuration Utility software, or you can use the configuration software built in to Windows.
If you wish to switch between your manufacturer's Wireless Configuration Utility and the Windows Wireless Zero Configuration service:
1. Go to Network Connections (from the left panel of My Network Places)
2. Right click on the icon for your wireless network card, and choose Properties
3. In the Properties dialog box, choose the middle "Wireless Networks" tab
4. Check or Uncheck the box on the top that enables Windows management of wireless connections
5. Click OK
A reboot is recommended. If you are using any form of WPA or 802.1X security, you will likely need to reboot the computer before you will be able to access your wireless Access Point -- even if it is configured correctly.
Even when both the manufacturer's software and the Wireless Zero Configuration services are running, the Configuration Utility should detect when Windows is not managing the connection and give you access to its own configuration options.
Likewise, Windows should detect when it is not enabled to control the wireless network configuration, and disable access to the Windows configuration options.
Advanced Troubleshooting:
Before proceeding, be sure to download a local copy of the manufacturer's software and driver should you find yourself with a disabled network card and a need to reinstall the software.
A. If you suspect that Windows is interfering with your wireless network, regardless of the setting, you can disable the underlying service. If the Wireless Zero Configuration service is disabled, Windows will not be able to manage the wireless network -- regardless of any setting. To permanently disable the Wireless Zero Configuration service, click Start, Run, and input services.msc and press Enter. In the Services window that follows, find the Wireless Zero Configuration service, double-click it, and change the startup option to Disabled. Reboot. If you still have issues, uninstall and reinstall your manufacturer's software now that the Wireless Zero Configuration Service is disabled. It should set itself up correctly now.
B. If the Manufacturer's configuration software is interfering with Windows' management of your wireless card, consider uninstalling your Manufacturer's software. Windows only needs the driver in order to communicate with your card and manage the wireless network. Everything else is optional. Remove the software from Add/Remove programs. The uninstall program might give you an option to uninstall everything except for the driver, or it might have separate Add/Remove Program entries for the utility. If it does not, then reinstall the software using the local copy you downloaded and look for an option that installs only the driver.
Mar 12, 2013 | Acer Aspire 5536-5224 Notebook
On our Panasonic KX-T7633 telephone, someone's light is steadily on, if they are talking or not. How do we turn it off when not in use?
The first thing you need to do is press PROGRAM and the lit button. Is it really the extension of the person who is always lit? An unconnected digital port does the same thing, so you could have a misprogrammed button. To reprogram the button press PROGRAM the button and dial 1+ext number and STORE.
The other thing is that certain versions of software behave differently. We still have some verson 2's and 3's that show busy, but the 5's don't.
Carl
Nov 04, 2010 | Panasonic KX-T7633 Corded Phone
How do i change my fax number
Changing the Fax Configuration
1 Click Start/Programs or All Programs/Accessories/ Communications/ Fax, and then click Fax Console.
2 In Fax Console, click Configure Fax on the Tools menu to start the Fax Configuration
Wizard.
3. On the Transmitting Subscriber Identification (TSID) screen, type the identification information (usually your fax number and your name or business name) in the TSID box. This information will appear in the header area of the faxes you send and identifies your
fax machine to the person who receives your faxes.
Aug 16, 2009 | Dell 942 All-In-One InkJet Printer
My desktop computer wont have sound i have a ca-4100
You will need to install the driver. It should be available from the manufacturers website under the support link. Hope this helps.
Aug 12, 2009 | Cyber Acoustics CA-4100 Computer Speakers
Need how to access bios setup utility -Panasonic CF-270 Notebook.
To access your BIOS Setup please restart your laptop then during the first boot process kindly press either the following:
1. F1
2. F2
3. F8
4. F12
5. F10
6. Del
7. Esc
Cause the bios setup is design in different manufacturer of laptop so the best thing to do is read the information during the first boot of your laptop it is always display the keyboard sequence to access the bios setup.
Thanks
Jul 31, 2009 | Computers & Internet
IBM T-40 issues
When you download the T40 device drivers, they need to be the XP versions.
When you run the driver programs they will be unzipped/expanded to the hard drive in a folder c:\drivers. Then you need to open the various folders and run the setup programs to install the various drivers.
NOTE - The T40 series laptops come with various different manufacturers devices (eg. there are a few different wireless model LANs) and if one version driver doesn't work you need to install a different one. It is a bit of trial and error to find the right one.
Jul 06, 2009 | IBM ThinkPad T40 2373 Notebook
Web configuration dows not work after reset
Perhaps you have to search for an upgrade to the WAPs firmware. The manufacturer may have a page in the web config that allows it to search for an updated firmware. If not, you should be able get one from the manufacturers website and apply it yourself from the download. The web config program should have an option to do so.
Apr 17, 2008 | CP International WAP-0006 (WAP0006)...
V Communications ComSwitch 5500 (CS5500) Logo
122 people viewed this question
Top V Communications Computers & Internet Experts
David Payne
David Payne
Are you a V Communications Computer and Internet Expert? Answer questions, earn points and help others
